yakxx21
Posted: Fri Nov 14, 2014 7:23 am Post subject: Re: loss of main air |
Thanks guys....excellent and I did all that and found that one of the non return valves was leaky...
stripped it and found one of the crush Ali washers was broken....but how to get a replacement ?? so I machined one up to size but it was 1.2mm thick....the original is 0.5.
So I put the one I made up in and put it all back together,,,didnt work ...non return.....returned !
stripped it again and having spent hours rubbing down the washer to the right thicknes , it nor works fine...so I have learnt that the thickness is critical.
Question ..where can I buy some correct Crush washers and a new o ring seal ...(I think the O ring is standard) the washers are soft Ali and are 20x16x0.5
If anybody can guid me I would appreciate it because I would really like it back as original....
Finally...anybody know where to buy a new Air main tank...mine looks a bit grotty inside..Im told they all look a bit corroded but I sure dont like it and would like to buy a new one....
hungarian guys sell used ones...not good.
Tried the usual UK sources but seems cannot get one ...I think its 6 or 7 litres...
any leads ...again much appreciatied
Good Yaking
