Smarter aircraft instrumentation can save you 1000of dollars
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
Pable Mackenzie
PostPosted: Wed Nov 26, 2014 11:22 pm    Post subject: Smarter aircraft instrumentation can save you 1000of dollars Reply with quote
Hi,Dear Friend,
I like to share my knowlege with you and want to gain more if you are have same interest related Aircraft's Spare Parts.
Smarter aircraft instrumentation can save you thousands of dollars
Flying your own aircraft is a thrill like none other and these owners are very careful the keep their aircraft in peek condition.
Immediate Release September 24, 2014 - Peak condition however, is a relative term because there are factors within an aircraft that are just not visible or factors that cannot be heard or felt. Take for example engine wear and tear. Wouldn't it be nice if you had instruments in your cluster that provided just little tinny weenie bit more information on what was happening inside your aircraft engine?
Wouldn't you love to know what kind of internal combustion pressures are exerted relative to your LOP? Take the EDM 800 engine analyzer for example. When operated in LOP mode, it displays the exhaust gas and cylinder head temperatures for each cylinder from the top of the display downward in "icicle" format as opposed to the usual bottom up format.
If you knew more about this or want know about other related parts, please feel free to write me.
Best Regards
Pable Mackenzie
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
 Filesize:  24.42 KB
 Viewed:  4398 Time(s)
 Filesize:  47.33 KB
 Filesize:  53.09 KB
 Filesize:  28.79 KB
 Filesize:  106.71 KB
 Filesize:  106.71 KB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
