bob88
Posted: Sun Nov 30, 2014 5:28 am Post subject: Yaw Damper |
I noticed that Garmin has a yaw damper for the -10 now. For those flying, is this needed? Is the plane unstable in yaw axis or dutch roll in turbulence enough to justify the yaw damper?
arplnplt(at)gmail.com Guest
Posted: Sun Nov 30, 2014 5:41 am Post subject: Yaw Damper |
With out a doubt. No.
I sometimes feel a tiny tail waggle after a bit of turbulence when loaded very after CG, but even then it is very brief and does not continue.
Dave Leikam
| Quote: | On Nov 30, 2014, at 7:28 AM, bob88 <marty.crooks(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=435088#435088
Posted: Sun Nov 30, 2014 5:45 am Post subject: Yaw Damper |
A yaw damper is not needed. It does improve the stability, but very few -10's have yaw dampers and most will say that it is fine without.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
| Quote: | On Nov 30, 2014, at 8:28 AM, bob88 <marty.crooks(at)comcast.net> wrote:
davidsoutpost(at)comcast. Guest
Posted: Sun Nov 30, 2014 7:06 am Post subject: Yaw Damper |
No need IMHO. The -10 is a very stable plane.
Sent: Sunday, November 30, 2014 8:28:29 AM
Subject: Yaw Damper
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net>
bsp; - MATRONICS WEB FORUMS -<======
stein(at)steinair.com Guest
Posted: Sun Nov 30, 2014 11:51 am Post subject: Yaw Damper |
As others have said, it's not "needed", but those who have them will tell
you it sure is "nice", especially when you basically get free rudder trim
out of the deal. It also depends on where/how you fly (and how the plane is
loaded obviously) and who is in the back seat. Front seat folks will rarely
notice the waggle, and well heeled small airplane passengers in the back
also won't really notice, but if you have folks who are either not
accustomed to small aircraft or prone to not liking the slight waggle that
you occasionally get, then it's a nice addition.
I've seen several dozen of these installed, and yet to hear a complaint from
those using them....but as previously mentioned (like many things in the
planes), it's not a "must have", but it is a "nice to have". Kind of like
Heated Seats for some of us!
Stein
rv10(at)texasrv10.com Guest
Posted: Sun Nov 30, 2014 1:54 pm Post subject: Yaw Damper |
Wife wants it. I have it, not installed yet. Stein describes the reasons perfectly.
Gaylon Koenning
[quote] On Nov 30, 2014, at 1:48 PM, Stein Bruch <stein(at)steinair.com> wrote:
Stein
Kelly McMullen
Posted: Mon Dec 01, 2014 6:54 am Post subject: Yaw Damper |
Does anyone know if there is a stand alone yaw damper or one compatible with the Dynon Skyview system?
On Sun, Nov 30, 2014 at 2:51 PM, RV10(at)TEXASRV10.COM (RV10(at)TEXASRV10.COM) <rv10(at)texasrv10.com (rv10(at)texasrv10.com)> wrote:
[quote]--> RV10-List message posted by: "RV10(at)TEXASRV10.COM (RV10(at)TEXASRV10.COM)" <rv10(at)texasrv10.com (rv10(at)texasrv10.com)>
Gaylon Koenning
> On Nov 30, 2014, at 1:48 PM, Stein Bruch <stein(at)steinair.com (stein(at)steinair.com)> wrote:
> --> RV10-List message posted by: "Stein Bruch" <stein(at)steinair.com (stein(at)steinair.com)>
> Cheers,
> Stein
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Mon Dec 01, 2014 7:14 am Post subject: Yaw Damper |
Not that I am aware of.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Dec 1, 2014, at 9:49 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Does anyone know if there is a stand alone yaw damper or one compatible with the Dynon Skyview system?
Gaylon Koenning
> Cheers,
> Stein
Posted: Mon Dec 01, 2014 7:30 am Post subject: Yaw Damper |
At the moment I think TruTrak and Garmin have the only systems available, and neither as standalone as far as I know.
Stein
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Monday, December 01, 2014 8:49 AM
Subject: Re: Yaw Damper
Gaylon Koenning
[quote] On Nov 30, 2014, at 1:48 PM, Stein Bruch <stein(at)steinair.com (stein(at)steinair.com)> wrote:
Stein
johngoodman
Posted: Tue Dec 02, 2014 6:48 am Post subject: Re: Yaw Damper |
I have never noticed the need for a yaw damper, but it's very rare that my back seats are occupied. My wife much prefers the heated seats, same here. Besides, I'm a little more nose heavy that most, which would reduce the issue.
Nice to see that manufacturers are paying attention to the experimental market....
aerosport1
Posted: Tue Dec 02, 2014 12:23 pm Post subject: Yaw Damper |
Being involved with the RV-10 for over 8 years now. I have never seen or
heard of anyone other than
Trutrak that ever had a yaw damper installed. This has been a discussion
many times at Oshkosh RV-10
Headquarters and other RV get together. I have yet to know anyone has that
installed one. The consensus was it was not a needed
Item at all and would be a waste of money. This was from most people that
had been flying their 10's for at least a year or more.
I would be interested to hear how many people actually have the Trutrak or
some other yaw damper installed in the RV-10.
Since Garmin just came out with theirs I would say only a few Garmin have
been installed in aircraft for testing.
Just Curious
Geoff Combs
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Tim Olson
Posted: Tue Dec 02, 2014 12:39 pm Post subject: Yaw Damper |
I haven't heard of many either, but I'll add my comments I guess.
Personally, I would not spend the money and add the weight.
It's not something that you NEED on an RV-10, but,
I do notice in turbulence that it can wag it's tail.
I just use my feet then to keep it more stable.
But, if you have the one in a hundred wives who just can't
stand any waggle, then it is something you may be interested
in trying. So, while I would never justify it for myself,
and I would never recommend someone buy it BEFORE they fly
their RV-10 for a while, I can see that there may be the
occasional person who could benefit from it.
So, if you think you need it, after flying, go ahead.
If you're not flying yet, I'd say hold off and gather some
good experience first.
Just Curious
Geoff Combs
woxofswa
Posted: Wed Dec 03, 2014 10:55 am Post subject: Re: Yaw Damper |
If I were building again and Dynon had an option that was equivelent in cost to combined electric rudder and aileron trim, I would do it, and just delete the aileron trim which hasn't proved necessary. I see the value of the damper products in the trim feature (which is useful) and not the damper.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
bob88
Posted: Wed Dec 03, 2014 12:04 pm Post subject: Re: Yaw Damper |
Related question:
If one has the Garmin aileron servo, is the Van's aileron trim needed?
Posted: Wed Dec 03, 2014 1:05 pm Post subject: Yaw Damper |
While the autopilot is engages, it "could" probably be used to trim the
airplane, but that's not a good way to do things - it's better to have the
stand alone trim and either then let the A/P trim it for you, or manually
trim the plane so that the forces on the control surfaces are neutral (at
least from a flight control rigging standpoint).
Stein
