Pable Mackenzie Guest
Posted: Thu Dec 04, 2014 9:47 pm Post subject: Aircraft Gauges |
Hi,Dear Friend,
I like to share my knowlege with you and want to gain more if you are have same interest related Aircraft's Spare Parts
Sensors linked to aircraft engine data management system can help record several critical engine parameters and it can do this several times during a flight. Modern sensors can monitor such vital characteristics as pressures, temperatures, speeds, vibration and also flow levels to ensure they are within known tolerances limits. The health of rotating components can be detected via vibration sensors. Similarly there are other sensors available to assess the health of Egt Gauges, fuel filters, metering valves, oil pumps and oil filters.
Modern aircraft engine data management systems not only store information onboard via internal hard-drives or high-capacity SD Cards, they also enable the smooth transfer of stored data to computers on the ground. Transferred data can be analyzed resulting in a diagnosis and usually also a prognosis. An engine that shows slow deterioration over a period of time could be scheduled for full inspection in the months ahead. On the other hand if a dramatic deterioration is detected, a full engine inspection might be recommended as soon as possible.
Modern aircraft engine data management system makes it so much easier to enjoy your flight, fly the aircraft at optimum settings and also maintain it intelligently. It is definitely a money and Aircraft Gauges saver.
If you knew more about this or want know about other related parts, please feel free to write me.
Best Regards
Pable Mackenzie
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
