Tailcone Question- Bulkhead Holes
stevefarner(at)gmail.com
PostPosted: Mon Dec 08, 2014 4:41 pm    Post subject: Tailcone Question- Bulkhead Holes Reply with quote
Hi All- Quick Tailcone question. I am on page 10-11. I understand that
no drilling should be done on the F-1006 bulkhead until it gets attached
to the fuselage. I'm not clear if this includes the forward most hole
of the two longerons which have the bulkhead part in common, or the
forward most hole of the top stiffeners (F1047 A, B-L, B-R). Does it
make a difference either way? I'm tempted to do it now so that the
longeron can be countersunk, but wanted to check first. Thank you,
-Steve Farnerrv
Kellym
PostPosted: Mon Dec 08, 2014 5:00 pm    Post subject: Tailcone Question- Bulkhead Holes Reply with quote
I'd recommend you read step 3 very literally and not drill anything
associated with that bulkhead for now. When the tail gets attached to
the fuselage, you match up all that stuff and do any
dimpling/countersinking in that chapter.
that no drilling should be done on the F-1006 bulkhead until it gets
attached to the fuselage. I'm not clear if this includes the forward
most hole of the two longerons which have the bulkhead part in common,
or the forward most hole of the top stiffeners (F1047 A, B-L, B-R).
Does it make a difference either way? I'm tempted to do it now so
that the longeron can be countersunk, but wanted to check first.
Thank you, -Steve Farnerrv
Kelly McMullen
KCHD
dmaib@me.com
PostPosted: Mon Dec 08, 2014 5:52 pm    Post subject: Re: Tailcone Question- Bulkhead Holes Reply with quote
I agree with Kelly. I found out the hard way a couple of times that one should heed instructions that specifically say not to do something at a particular point.
David Maib
RV-10 #40559
New Smyrna Beach, FL
PostPosted: Mon Dec 08, 2014 6:21 pm    Post subject: Tailcone Question- Bulkhead Holes Reply with quote
Thanks Kelly & David- To clarify, I believe I am supposed to drill the
3/32nd hole in the longeron (step #2), but hold off on the others,
including the J-channel holes on top. I'm still wondering how this
longeron hole gets countersunk at a later date if I've riveted around it.
Steve
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=435510#435510
