markandrhonda(at)harveyfa Guest
ptag.dev(at)talktalk.net Guest
Posted: Thu Dec 11, 2014 2:18 pm Post subject: Kit 451 Fly's |
Congratulations Mark from Bob Harrison. G-PTAG Trike 914
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of markandrhonda(at)harveyfarm.net.au
Sent: 11 December 2014 21:13
Subject: Kit 451 Fly's
I’m proud to say there is one more Europa in the sky. It tends to drop the left wing with hands off which I will have to work on but other than that It flew lovely. First flight was on the 10/12/14 but we have had bad weather since and work tends to get in the way so haven’t been up since. Looking forward to the next flight.
Mark
Qld Australia
[img]cid:~WRD000.jpg[/img]
This email is free from viruses and malware because avast! Antivirus protection is active.
| Quote: | | www.aeroelectric.com | 012345678901234567
823 Bytes |
16784 Time(s) |
dpark748(at)icloud.com Guest
Posted: Thu Dec 11, 2014 3:39 pm Post subject: Kit 451 Fly's |
Congratulations from Dave Park G-LDVO
On 11 Dec 2014, at 10:18 pm, Bob Harrison <ptag.dev(at)talktalk.net (ptag.dev(at)talktalk.net)> wrote:
[quote]v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au)
Mark
Qld Australia
<~WRD000.jpg>
012345678901234567
max8992
rlborger(at)mac.com Guest
Posted: Thu Dec 11, 2014 5:10 pm Post subject: Kit 451 Fly's |
Mark,
Congratulations on your success. Now go play with it!!
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Dec 11, 2014, at 3:13 PM, markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au) wrote:
Mark
Qld Australia
ward.t(at)xtra.co.nz Guest
Posted: Thu Dec 11, 2014 5:33 pm Post subject: Kit 451 Fly's |
Hi Mark,
Congratulations on your first flight. Another Antipodean Europa flying is great to hear.
My one also had a slow left wing drop. Not so with a passenger. There has been talk on the website about this problem. I just put a trim tab on the port wing and that fixed it.
A new chapter opens when it comes to fly the beast! As advertised it does everything well and a delight to go touring in.
All the best with the test flying.
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Ph 64 3 3515166
Mob 0210640221
On 12/12/2014, at 10:13 am, <markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au)> <markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au)> wrote:
[quote] I’m proud to say there is one more Europa in the sky. It tends to drop the left wing with hands off which I will have to work on but other than that It flew lovely. First flight was on the 10/12/14 but we have had bad weather since and work tends to get in the way so haven’t been up since. Looking forward to the next flight.
Mark
Qld Australia
ot;">www.aeroelectric.com
books.com"">www.buildersbooks.com
quot;">www.homebuilthelp.com
quot;">www.mypilotstore.com
">www.mrrace.com
a-List"">http://www.matronics.com/Navigator?Europa-List
//forums.matronics.com
Posted: Thu Dec 11, 2014 11:44 pm Post subject: Kit 451 Fly's |
Thanks every one.
Tim it sounds like I might be better off leaving the aileron trim until I fly with a passenger and I have been following the forum with the trim adjustments. This forum has been unbelievable. Nearly every time I have had an issue with the build someone has bought up the same issues that I have been having. I’ve only had to post a couple of times in the last two years. A big thanks to all the people that take the time out to help others. It’s greatly appreciated. there’s a lot of very smart people out there.
Mark
Sent: Friday, December 12, 2014 11:32 AM
Subject: Re: Kit 451 Fly's
Hi Mark,
Tim Ward 12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
| Quote: | I’m proud to say there is one more Europa in the sky. It tends to drop the left wing with hands off which I will have to work on but other than that It flew lovely. First flight was on the 10/12/14 but we have had bad weather since and work tends to get in the way so haven’t been up since. Looking forward to the next flight.
Mark
Qld Australia
">www.mrrace.com
ectric.com
builthelp.com
lotstore.com
m
ics.com
This email is free from viruses and malware because avast! Antivirus protection is active. [quote][b]
Cassel
Posted: Fri Dec 12, 2014 8:02 am Post subject: Kit 451 Fly's |
Hi Stephan
Pictures would be good if you can
Regards Mark
Qld Australia
Sent: Friday, December 12, 2014 6:42 PM
Congratulations Mark,
>It tends to drop the left wing hands off.....
Quite normal and easy to fix with a spring connected to the control system.
Same approach all RV builders/fliers use.
I can send you pictures if you want.
BTW the drop will probably increase after Christmas
Best regards
Stephan
LN-STE Mono 556 Norway
Posted: Fri Dec 12, 2014 8:32 am Post subject: Kit 451 Fly's |
Congratulations
Will
William Daniell
LONGPORT
+57 310 295 0744
On Thu, Dec 11, 2014 at 4:13 PM, <markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au)> wrote:[quote] I’m proud to say there is one more Europa in the sky. It tends to drop the left wing with hands off which I will have to work on but other than that It flew lovely. First flight was on the 10/12/14 but we have had bad weather since and work tends to get in the way so haven’t been up since. Looking forward to the next flight.
Â
Mark
Qld Australia
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
budyerly(at)msn.com Guest
Posted: Sat Dec 13, 2014 7:21 pm Post subject: Kit 451 Fly's |
Great job Mark. How about some photo's.
Trimming isn't hard. It's on my website.
Bud Yerly
www.customflightcreations.com
From: markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au)
Sent: Thursday, December 11, 2014 4:13 PM
Mark
Qld Australia
href="http://www.mypilotstore.com">www.mypilotstore.com
href="http://www.mrrace.com">www.mrrace.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Sun Dec 14, 2014 10:53 am Post subject: Kit 451 Fly's |
Thanks Bud
I tried to send some photo’s with my first email but they just sat in my out box. See if this works.
I didn't get around to thank you for the fuel cap which you organised some time ago[Thank you] I'm not the best on a computer so tend to put if off.
Had a quick look at your website regarding the trimming and as soon as I get a chance I will get back out to the airport. Between work and bad weather and Christmas coming up [going away] it maybe after Christmas.
Regards Mark
Sent: Sunday, December 14, 2014 1:21 PM
Bud Yerly
Mark
Qld Australia
ectric.com
builthelp.com
lotstore.com
m
ics.com
2.38 MB |
16725 Time(s) |
db308
Posted: Sun Dec 14, 2014 11:26 am Post subject: Kit 451 Fly's |
Congratulations Mark! Enjoy the flying.
John Baker,
South Australia.
On 15 Dec 2014, at 5:21 am, <markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au)> <markandrhonda(at)harveyfarm.net.au (markandrhonda(at)harveyfarm.net.au)> wrote:
[quote] Thanks Bud
Regards Mark
Bud Yerly
Mark
Qld Australia
<IMG_0952.JPG>
Posted: Sun Dec 14, 2014 11:42 am Post subject: Kit 451 Fly's |
That worked Mark,
where in Australia are you?
Graham
From: "markandrhonda(at)harveyfarm.net.au" <markandrhonda(at)harveyfarm.net.au>
Sent: Sunday, 14 December 2014, 18:51
Subject: Re: Europa-List: Kit 451 Fly's
Thanks Bud
Regards Mark
Bud Yerly
Mark
Qld Australia
ectric.com
builthelp.com
lotstore.com
m
ics.com
Posted: Mon Dec 15, 2014 1:41 am Post subject: Kit 451 Fly's |
HI Graham.
I’m in Kingaroy QLD
From: GRAHAM SINGLETON (grahamsingleton(at)btinternet.com)
Sent: Monday, December 15, 2014 5:38 AM
That worked Mark,
Graham
Thanks Bud
Regards Mark
Bud Yerly
Mark
Qld Australia
ectric.com
builthelp.com
lotstore.com
m
ics.com
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Mon Dec 15, 2014 2:21 am Post subject: Kit 451 Fly's |
Hi Mark
Very well done, now the fun starts. I’m in Sydney in February, where is Qld?
Richard
G-CGZV
Sent: Thursday, December 11, 2014 9:13 PM
Mark
Qld Australia
Posted: Tue Dec 16, 2014 8:32 pm Post subject: Kit 451 Fly's |
Mark,
Nice looking bird. Your computer skills may not be good, but your airplane craftsmanship shows.
Weather in QLD will be improving. Go slow, take your time and you will be rewarded. Flight testing, just like building is done in building steps. When trimming, fix/adjust one thing at a time and evaluate.
Best Regards,
Bud Yerly
Sent: Sunday, December 14, 2014 1:51 PM
Thanks Bud
Regards Mark
Bud Yerly
Mark
Qld Australia
ectric.com
builthelp.com
lotstore.com
m
ics.com
