dpark
Posted: Sun Dec 21, 2014 9:30 am Post subject: Epoxy Dispeser. |
Too old to start building another aircraft, couldn't get permission anyway!!!.
So my Adjustable Epoxy Dispenser is available Model AR-100 originally from J & B Products, USA. Spare tanks.
Would need a good clean up. Any offers?
Dave G-LDVO
Sent from my iPad
_________________ Dave Park G-LDVO Europa XS Trike 912uls |
iancook_1(at)hotmail.com Guest
Posted: Sun Dec 21, 2014 1:59 pm Post subject: Epoxy Dispeser. |
Dave,
I am just about to start on a build, where are you based do you
have an idea of what you are looking for ?
Ian Cook
Andover Hants
07912944536
tonyrenshaw268(at)gmail.c Guest
Posted: Sun Dec 21, 2014 2:08 pm Post subject: Epoxy Dispeser. |
Its worth mentioning that these pumps do not solve all problems, and create a few of their own. They gum up which effects the volume of the hardener, so you have to cap off the outlets. They scale where air is allowed to effect the hardener. You will have ongoing anxiety that things are not right, and when you do test it, you’ll often find it will need adjustment. My view, they are rubbish. Don’t do it! Sorry Dave, I’ll compensate by paying the trash fee. Nothing beats a set of digital scales.
Tony Renshaw
[quote] On 22 Dec 2014, at 8:58 am, Ian Cook <iancook_1(at)hotmail.com> wrote:
Dave,
Ian Cook
Andover Hants
07912944536
Fred Klein
Posted: Sun Dec 21, 2014 3:04 pm Post subject: Epoxy Dispeser. |
| Quote: | On Dec 21, 2014, at 2:08 PM, Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:
I too have a discarded and gummed up resin dispenser pump…and though i have no weigh (just couldn’t resist) of precisely comparing my balance beam w/ a digital scale, one of the advantages of the balance beam is that its use completely eliminates the necessity of precise quantity measurements of both resin and hardener…a very useful advantage when “just enough” epoxy is required…and as for sensitivity, it’s always gratifying to see the beam balancing out after adding only the tiniest amount of hardener.
It was quite easy to mark the beam so it could be used for different epoxy ratios.
I would not trade my balance for even the priciest of digital scales.
Fred
spcialeffects
Posted: Sun Dec 21, 2014 3:09 pm Post subject: Re: Epoxy Dispeser. |
I don't agree Tony. I have been using one for two years now. I keep it in a cupboard with a little white garden heater to keep the temperature about 25 degrees C and every time I check its ratio it's been spot on to the day I set it. As I'm building a classic with wet wings it's been invaluable. In my opion a great time saver. Ian, my advice.......for the few pounds it will cost to buy, get it and use it and make your own mind up.
Frank
dpark748(at)icloud.com Guest
Posted: Sun Dec 21, 2014 4:45 pm Post subject: Epoxy Dispeser. |
Europa based at Sleap and I live South manchester near airport.
Will send pics tomo
Dave
Sent from my iPad
[quote] On 21 Dec 2014, at 21:58, Ian Cook <iancook_1(at)hotmail.com> wrote:
Dave,
Ian Cook
Andover Hants
07912944536
Posted: Sun Dec 21, 2014 4:52 pm Post subject: Epoxy Dispeser. |
Just seen the other posts, so will bin it.
It is true you have to keep it clear of gumming up. The more you use it the better and check the dispensing with samples.
Dave
Sent from my iPad
Dave,
Ian Cook
Andover Hants
07912944536
