Peter Barthold
Posted: Wed Jun 28, 2006 4:04 am Post subject: fuel tanks again |
Hello Listers,
I thought, I'll ask while the topic is about fuel sending units. I am in the process of building my own HDS wing tanks. Got the sheet metal clecoed in form and now it's time to buy components and fittings. Is there any reason why I should not use a automotive tubular fuel sender instead of the standard floating lever unit? I expect a better dampening than with a free floating lever. Some of these tubular senders even have fuel pumps integrated (old BMW 3 series).
I will use mogas on my VW conversion.
Any thoughts?
Carlos, if you read this, did you test your tanks for leakage yet? How did they come out? Are you going to use mogas?
Thanks and
Best Regards from Germany
Peter Barthold
HDS td VW conv.
Tail done, Wing in progress
www.petersprojekt42.de
dredmoody(at)cox.net Guest
Posted: Wed Jun 28, 2006 9:44 am Post subject: fuel tanks again |
I used a capacitance type sender in my ultralight and it has been a pain in the butt to keep it calibrated. That's just one isolated experince, mind you,
Ed Moody II
Rayne, LA
601XL / wings
moorecomp(at)yahoo.com Guest
Posted: Wed Jun 28, 2006 11:23 am Post subject: fuel tanks again |
Peter,
I assume the tubular sender is one with the float
inside the tube? The one thing I can think of that
might be a problem would be that if the sender is not
perfectly vertical, friction may prevent the float
from moving freely. If you get one and do some tests,
it may be a non issue. I agree that the damping would
be better due to the small hole that the fuel column
is flowing through.
Best regards,
Craig Moore A&P
701 builder wannabe
Hello Listers,
Any thoughts?
going to use mogas?
Thanks and
Peter Barthold
HDS td VW conv.
http://forums.matronics.com/viewtopic.php?p=43538#43538
