Forgot to install bolts in 7V2-5, Upper Strut Fitting
pdelano(at)telus.net
PostPosted: Sat Jan 24, 2015 10:50 am    Post subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting Reply with quote
Hi all,
I rivetted the trailing edge of the nose skin to the spar on the bottom side. But realize now I cannot get that upside down bolt in the upper strut fitting because the skin is rivetted tight in this position. On the right wing I was sure to get it on and the bolts torqued before I rivetted on the skin, thought I would get smart on the left wing, not so. Has anybody else done this, and is there an alternative to drilling out 40 some A4 rivets to get this bolt in.
Perry
