Bourke engine
williamtsullivan(at)att.n
PostPosted: Sun Jan 25, 2015 9:18 am    Post subject: Bourke engine Reply with quote
Click on various stuff in this link. My brother sent it to me, thinking I'd be interested. With Rotax dropping the small 2-strokes, there is a need for replacements. The weight to HP ratio looks pretty good. Does anyone have any experience/comments on this one?
http://www.bourke-engine.com/ani
Bill Sullivan
ceengland7(at)gmail.com
PostPosted: Sun Jan 25, 2015 10:49 am    Post subject: Bourke engine Reply with quote
I'd suggest finding an independent engineering evaluation. My thoughts:
Consider how severe the imbalance will be with both pistons moving the
same direction, then how much the counterweight will weigh to counteract
that force (without contributing any power). Then consider how long a
sliding line-contact sliding bearing is going to last when subjected to
those forces. The claim is 1/4 pound (0.25 lb) per hp/hr. This is better
by about 30% than the most efficient internal combustion engine ever
built, and it's still a 2 stroke engine. Isn't it a bit strange that a
design that's been around long enough for the patents to expire, and is
super clean, and beats the best tech out there by 30%, hasn't taken over
every engine market on the planet? And it uses 'detonation' to extract
more energy from the fuel? What happens to a piston when you have
detonation in the combustion chamber? (Answer help: nothing good.)
Current technology in 4 strokes can come pretty close to the same
power/weight ratio as old tech 2 strokes. Just need someone to make them
available at an affordable price.
undoctor
PostPosted: Sun Jan 25, 2015 11:09 am    Post subject: Bourke engine Reply with quote
Remember back in the 50s or 60s when the Wenkel Rotary engine was introduced? One triangular piston with rotary rather than reciprocating motion and very few moving parts?
Good idea and it could spin very high revs. Problem is, they can't keep the tips from wearing on the triangular piston, so very limited application in the real world.
Also remember a ceramic engine on the drawing boards which was to rival sliced bread for greatness. Haven't heard any more about that one. That's OK. Just keep inventing, many out there ideas have been successful.
Dave Kulp
Bethlehem, PA
Sent from my Verizon Wireless 4G LTE Smartphone
<div>-------- Original message --------</div><div>From: Charlie England <ceengland7(at)gmail.com> </div><div>Date:01/25/2015 1:48 PM (GMT-05:00) </div><div>To: kolb-list(at)matronics.com </div><div>Subject: Re: Kolb-List: Bourke engine </div><div>
</div>
rickofudall
PostPosted: Sun Jan 25, 2015 3:06 pm    Post subject: Bourke engine Reply with quote
Bourke built many examples of his engine for trucks, outboard motors, and aircraft. They all worked, ran for hundreds of hours with little wear to any parts, and produced the advertised horsepower. One of the aircraft engines is in the EAA museum.Like any engine the start up costs going into production would be astronomical and for an aircraft engine then there are certification costs. All for a small diminishing market. Sad to say it won't happen, but that's the way it is.
Rick Girard
On Sun, Jan 25, 2015 at 1:09 PM, undoctor <undoctor(at)ptd.net (undoctor(at)ptd.net)> wrote:
Dave Kulp
Bethlehem, PA
Subject: Re: Bourke engine
--> Kolb-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
--> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)>
available at an affordable priceolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-Listhttp://www.matronics.com==================
Believe those who are seeking the truth, doubt those who find it.
-Andre Gide
patrickjladd(at)hotmail.c
PostPosted: Tue Jan 27, 2015 3:48 am    Post subject: Bourke engine Reply with quote
<<Remember back in the 50s or 60s when the Wenkel Rotary engine was introduced? One triangular piston with rotary rather than reciprocating motion and very few moving parts?>>
I had a car with a Wankel engine. A beautiful car with the super smooth non vibrating engine.It would run happily on very low grade petrol but only gave about 25miles to the gallon. Acceleration was nothing to write home about but the non reciprocating design made for super smooth running. As you say the wearing of the ceramic tips of the three point rotor was its downfall. Great pity. I remember that it had a manual gear shift but no clutch pedal. The clutch was operated electrically when you held the knob on the top of the gear stick. So the act of changing gear automatically operated the clutch. It had a device which matched the engine speed to the wheel speed when you changed gear.
There were several Wankel aero engines being played with a few years ago but they seem to have fallen by the wayside. Pity, it had such promise.
Pat
Sent: Sunday, January 25, 2015 11:05 PM
Bourke built many examples of his engine for trucks, outboard motors, and aircraft. They all worked, ran for hundreds of hours with little wear to any parts, and produced the advertised horsepower. One of the aircraft engines is in the EAA museum. Like any engine the start up costs going into production would be astronomical and for an aircraft engine then there are certification costs. All for a small diminishing market. Sad to say it won't happen, but that's the way it is.
Rick Girard
Dave Kulp
Bethlehem, PA
-Andre Gide
Herbgh(at)nctc.com
PostPosted: Tue Jan 27, 2015 5:29 am    Post subject: Bourke engine Reply with quote
Pat
  If memory serves,I believe, Mazda has solved most of the technical problems with the Wankel.
  an early problem, from memory, came about when the factory decided to use standard auto engine oil to lubricate the apex seals...and side seals...  That resulted in some necessary  oil burning and a build up of carbon...  One can imagine the debate when engineers suggest that low ash two stroke oil be used...?
  The power and fuel consumption came from the two stroke design... From my memory... Herb
On 01/27/2015 05:47 AM, Patrick Ladd wrote:
[quote] <<Remember back in the 50s or 60s when the Wenkel Rotary engine was introduced? One triangular piston with rotary rather than reciprocating motion and very few moving parts?>>
Pat
Rick Girard
Dave Kulp
Bethlehem, PA
-Andre Gide
undoctor
PostPosted: Tue Jan 27, 2015 8:05 am    Post subject: Bourke engine Reply with quote
Good to hear from you, Pat. How are things across the pond?  Still grounded?  I am and I don't like it. Hope to change that early flying season.
Sorry I misspelled Wankel. Memory gets fuzzy from years ago.
Herb, I was aware Mazda used the Wankel; do they or anyone still?
Dave Kulp
Bethlehem, PA
Date:01/27/2015 8:29 AM (GMT-05:00)
Pat
Pat
Rick Girard
Dave Kulp
Bethlehem, PA
-Andre Gide
PostPosted: Tue Jan 27, 2015 8:17 am    Post subject: Bourke engine Reply with quote
I'm currently installing a Mazda Renesis rotary in an RV-7, and know quite a few people that are flying the Renesis and the older 13B/20B engines quite successfully.
The engine is a true 4 stroke engine; not 2 stroke. But because of the design, each rotor face goes through all 4 'strokes' in one complete rotation of the rotor (but the rotor rotates at 1/3 of the rpm of the eccentric shaft (crankshaft). Apex seal wear in a Wankel rotary hasn't been a problem in over 30 years. Tracy Crook (recently retired from building engine controllers and reduction drives) put about 900 hours in an RV-4 on a junkyard 13B, and had barely measurable wear on any of the seals at tear down (removed to install a Renesis in that airframe). Sticking seals due to using crankcase oil to lube the apex seals can still be a problem in some Mazda RX7/RX8 cars with some maintenance practices (lack of). Racers (and aircraft installers) disable the supply from the crankcase, and either add a source of 2 stroke oil to the apex seal lube pump, or remove the pump and do a very light (3/4--1 oz per gallon) 2 stroke oil premix with fuel. There's still regular automotive oil in the crankcase. Fuel economy in the Mazda rotaries used in aircraft is typically about 10% worse than a properly leaned Lycoming. Since most Lyc drivers are afraid to lean properly, the real world fuel economy is pretty close to the same as a Lyc.
There are some European sources of smaller Wankel designs (light enough and with low enough HP to work on a Kolb) that are coming into more common use, but it's rare to see them in the USA. In the 150-250 HP range, no one's demonstrated another auto conversion engine that's as light as the rotary and can stand up to the high duty cycle of a/c use. My installation weighs ~320 lbs all-up, prior to adding fluids. This is comparable to a Lyc 160 HP installation, but the Renesis is easily capable of 190-210 HP in a/c use.
While the Bourke engine may 'work', the performance claims on that web site are far outside the bounds of rational thought. It's not just a few technical problems to overcome, like apex seal wear in a rotary. The claims exceed what's achievable without violating the laws of thermodynamics. Smile
Charlie
On 1/27/2015 7:29 AM, Herb wrote:
[quote] Pat
Pat
Rick Girard
Dave Kulp
Bethlehem, PA
-Andre Gide
PostPosted: Tue Jan 27, 2015 8:26 am    Post subject: Bourke engine Reply with quote
Here's one project that should get the attention of Kolb drivers:
http://www.hybridcars.com/mazda-could-produce-mazda2-ev-with-rotary-range-extender/
There's also a repeatedly resurfacing rumor that they will re-introduce the RX7/RX8 sports car with a 16X rotary engine (the engine is already developed).
http://www.mazda.com/stories/rotary/16x/
Charlie
On 1/27/2015 10:04 AM, undoctor wrote:
[quote] Good to hear from you, Pat. How are things across the pond?  Still grounded?  I am and I don't like it. Hope to change that early flying season.
Dave Kulp
Bethlehem, PA
Pat
Pat
Rick Girard
Dave Kulp
Bethlehem, PA
-Andre Gide
Herbgh(at)nctc.com
PostPosted: Tue Jan 27, 2015 8:42 am    Post subject: Bourke engine Reply with quote
Its all coming back to me...I chatted with Tracy some 20 years ago...at length...for he was all too happy to share his rotary experiences...  and I recall that Mazda fixed the oil problem with new and improved seals working with other companies in Japan..
   Herb
On 01/27/2015 10:16 AM, Charlie England wrote:
[quote] I'm currently installing a Mazda Renesis rotary in an RV-7, and know quite a few people that are flying the Renesis and the older 13B/20B engines quite successfully.
Charlie
Pat
Pat
Rick Girard
Dave Kulp
Bethlehem, PA
-Andre Gide
undoctor
PostPosted: Tue Jan 27, 2015 9:10 am    Post subject: Bourke engine Reply with quote
Great rundown, Charlie. Thanks!
Date:01/27/2015 11:25 AM (GMT-05:00)
Charlie
Dave Kulp
Bethlehem, PA
Pat
Pat
Rick Girard
Dave Kulp
Bethlehem, PA
-Andre Gide
PostPosted: Tue Jan 27, 2015 9:11 am    Post subject: Bourke engine Reply with quote
His issues are just like the issues that anyone doing a 'one-off' design is going to encounter. *All* alternative engine installations are by nature, one-offs, and almost always done by those (including me) who don't have the training and experience to get it right the first time. Starting with a turbo (an entire development process on its own) on an alternative engine as a 1st iteration is begging for failure at best, with disaster likely. And it's not just alternative engines that face the problem; pilots are just very good at ignoring the ongoing issues with 'conventional' power plants. There's the recent thread on this list about excessive wear on a Rotax oil control lever. Lycs have been installed in a/c since the beginning of time, and they *still* have issues with cracking cooling baffles, exhaust systems, carb air cleaner adapter plates, oil cooler mounts, engine mounts, *CRANKSHAFTS*, etc etc etc. I know, because I've flown them for over 20 years. But that stuff is 'normal maintenance' to a Lyc driver.
13B's are really are loud like a 2 stroke, because of the way the exhaust port snaps open (just like a piston-ported 2 stroke). The newer Renesis is much quieter due to the re-designed exhaust port. I've got friends from TX and KY, both flying Renesis engines on RV-7A's, and they almost sound like turbines. They are quieter than Lycs, with prop noise is louder than the engine.
Sorry for the double detour from regularly scheduled Kolb programming.
Charlie
On 1/27/2015 10:43 AM, Rick Neilsen wrote:
[quote] Scott Trask a long time Kolb MKIIIC owner built a RV7A with a Wankel engine in it. He flew it a few years but changed to a conventional engine. The Wankel engine builder sent him a engine a year late that didn't run right. Seems like it had a turbo that didn't work right also. He had the new engine rebuilt without the turbo and flew it. Seemed like he was continually fixing broken wires, cracking brackets and such related to a very high frequency vibration. The plane sounded like it had a screaming (much louder than normal) two stroke in it. Later with the new engine he flew it down for a winter visit from the UP of Michigan to Venice Florida in 7 hours.
Rick Neilsen
Redrive VW Powered MKIIIC
On Tue, Jan 27, 2015 at 6:47 AM, Patrick Ladd <patrickjladd(at)hotmail.com (patrickjladd(at)hotmail.com)> wrote:
Pat
Rick Girard
Dave Kulp
Bethlehem, PA
russk50(at)gmail.com
PostPosted: Wed Jan 28, 2015 8:47 am    Post subject: Bourke engine Reply with quote
Undoctor — you should know that your posts come thru as gibberish. At least on a Mac.
On Jan 27, 2015, at 12:09 PM, undoctor <undoctor(at)ptd.net (undoctor(at)ptd.net)> wrote:
PGh0bWw+PGhlYWQ+PG1ldGEgaHR0cC1lcXVpdj0iQ29udGVudC1UeXBlIiBjb250ZW50PSJ0ZXh0 L2h0bWw7IGNoYXJzZXQ9VVRGLTgiPjwvaGVhZD48Ym9keSA+PGRpdj5HcmVhdCBydW5kb3duLCBD aGFybGllLiBUaGFua3MhPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48 ZGl2IHN0eWxlPSJmb250LXNpemU6OXB4O2NvbG9yOiM1NzU3NTciPlNlbnQgZnJvbSBteSBWZXJp em9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+PC9kaXY+PGJyPjxicj48ZGl2Pi0t LS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IENoYXJsaWUg RW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFpbC5jb20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yNy8yMDE1 ICAxMToyNSBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmlj cy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwv ZGl2PjxkaXY+PGJyPjwvZGl2PgogICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5IZXJl J3Mgb25lIHByb2plY3QgdGhhdCBzaG91bGQgZ2V0IHRoZQogICAgICBhdHRlbnRpb24gb2YgS29s YiBkcml2ZXJzOjxicj4KPGEgY2xhc3M9Im1vei10eHQtbGluay1mcmVldGV4dCIgaHJlZj0iaHR0 cDovL3d3dy5oeWJyaWRjYXJzLmNvbS9tYXpkYS1jb3VsZC1wcm9kdWNlLW1hemRhMi1ldi13aXRo LXJvdGFyeS1yYW5nZS1leHRlbmRlci8iPmh0dHA6Ly93d3cuaHlicmlkY2Fycy5jb20vbWF6ZGEt Y291bGQtcHJvZHVjZS1tYXpkYTItZXYtd2l0aC1yb3RhcnktcmFuZ2UtZXh0ZW5kZXIvPC9hPjxi cj4KICAgICAgPGJyPgogICAgICBUaGVyZSdzIGFsc28gYSByZXBlYXRlZGx5IHJlc3VyZmFjaW5n IHJ1bW9yIHRoYXQgdGhleSB3aWxsCiAgICAgIHJlLWludHJvZHVjZSB0aGUgUlg3L1JYOCBzcG9y dHMgY2FyIHdpdGggYSAxNlggcm90YXJ5IGVuZ2luZSAodGhlCiAgICAgIGVuZ2luZSBpcyBhbHJl YWR5IGRldmVsb3BlZCkuPGJyPgogICAgICA8YSBjbGFzcz0ibW96LXR4dC1saW5rLWZyZWV0ZXh0 IiBocmVmPSJodHRwOi8vd3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvIj5odHRwOi8v d3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvPC9hPjxicj4KICAgICAgPGJyPgogICAg ICBDaGFybGllPGJyPgogICAgICA8YnI+CiAgICAgIE9uIDEvMjcvMjAxNSAxMDowNCBBTSwgdW5k b2N0b3Igd3JvdGU6PGJyPgogICAgPC9kaXY+CiAgICA8YmxvY2txdW90ZSBjaXRlPSJtaWQ6bzk1 aXBzbGwwdHNvYmcybWRrNWRnbHdkLjE0MjIzNzQ2OTc1MDhAZW1haWwuYW5kcm9pZC5jb20iIHR5 cGU9ImNpdGUiPgogICAgICA8bWV0YSBodHRwLWVxdWl2PSJDb250ZW50LVR5cGUiIGNvbnRlbnQ9 InRleHQvaHRtbDsgY2hhcnNldD11dGYtOCI+CiAgICAgIDxkaXY+R29vZCB0byBoZWFyIGZyb20g eW91LCBQYXQuIEhvdyBhcmUgdGhpbmdzIGFjcm9zcyB0aGUgcG9uZD8KICAgICAgICAmbmJzcDtT dGlsbCBncm91bmRlZD8gJm5ic3A7SSBhbSBhbmQgSSBkb24ndCBsaWtlIGl0LiBIb3BlIHRvIGNo YW5nZSB0aGF0CiAgICAgICAgZWFybHkgZmx5aW5nIHNlYXNvbi4mbmJzcDs8L2Rpdj4KICAgICAg PGRpdj48YnI+CiAgICAgIDwvZGl2PgogICAgICA8ZGl2PlNvcnJ5IEkgbWlzc3BlbGxlZCBXYW5r ZWwuIE1lbW9yeSBnZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLiZuYnNwOzwvZGl2PgogICAgICA8 ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+SGVyYiwgSSB3YXMgYXdhcmUgTWF6ZGEg dXNlZCB0aGUgV2Fua2VsOyBkbyB0aGV5IG9yIGFueW9uZQogICAgICAgIHN0aWxsPzwvZGl2Pgog ICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+RGF2ZSBLdWxwPC9kaXY+CiAg ICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+ CiAgICAgIDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgPGRpdj48YnI+CiAgICAgIDwv ZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+CiAgICAgICAgPGRp diBzdHlsZT0iZm9udC1zaXplOjlweDtjb2xvcjojNTc1NzU3Ij5TZW50IGZyb20gbXkgVmVyaXpv bgogICAgICAgICAgV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmU8L2Rpdj4KICAgICAgPC9kaXY+ CiAgICAgIDxicj4KICAgICAgPGJyPgogICAgICA8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3Nh Z2UgLS0tLS0tLS08L2Rpdj4KICAgICAgPGRpdj5Gcm9tOiBIZXJiIDxoZXJiZ2hAbmN0Yy5jb20+ IDwvaGVyYmdoQG5jdGMuY29tPjwvZGl2PgogICAgICA8ZGl2PkRhdGU6MDEvMjcvMjAxNSA4OjI5 IEFNIChHTVQtMDU6MDApIDwvZGl2PgogICAgICA8ZGl2PlRvOiA8YSBjbGFzcz0ibW96LXR4dC1s aW5rLWFiYnJldmlhdGVkIiBocmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iPmtv bGItbGlzdEBtYXRyb25pY3MuY29tPC9hPiA8L2Rpdj4KICAgICAgPGRpdj5TdWJqZWN0OiBSZTog S29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9k aXY+CiAgICAgIFBhdDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgSWYgbWVtb3J5IHNlcnZl cyxJIGJlbGlldmUsIE1hemRhIGhhcyBzb2x2ZWQgbW9zdCBvZiB0aGUKICAgICAgdGVjaG5pY2Fs IHByb2JsZW1zIHdpdGggdGhlIFdhbmtlbC48YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7IGFu IGVhcmx5IHByb2JsZW0sIGZyb20gbWVtb3J5LCBjYW1lIGFib3V0IHdoZW4gdGhlIGZhY3RvcnkK ICAgICAgZGVjaWRlZCB0byB1c2Ugc3RhbmRhcmQgYXV0byBlbmdpbmUgb2lsIHRvIGx1YnJpY2F0 ZSB0aGUgYXBleAogICAgICBzZWFscy4uLmFuZCBzaWRlIHNlYWxzLi4uJm5ic3A7IFRoYXQgcmVz dWx0ZWQgaW4gc29tZSBuZWNlc3NhcnkmbmJzcDsgb2lsCiAgICAgIGJ1cm5pbmcgYW5kIGEgYnVp bGQgdXAgb2YgY2FyYm9uLi4uJm5ic3A7IE9uZSBjYW4gaW1hZ2luZSB0aGUgZGViYXRlCiAgICAg IHdoZW4gZW5naW5lZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ugb2lsIGJlIHVz ZWQuLi4/IDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgVGhlIHBvd2VyIGFuZCBmdWVsIGNv bnN1bXB0aW9uIGNhbWUgZnJvbSB0aGUgdHdvIHN0cm9rZQogICAgICBkZXNpZ24uLi4gRnJvbSBt eSBtZW1vcnkuLi4gSGVyYiA8YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7Jm5ic3A7IDxicj4K ICAgICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5PbiAwMS8yNy8yMDE1IDA1OjQ3IEFN LCBQYXRyaWNrIExhZGQKICAgICAgICB3cm90ZTo8YnI+CiAgICAgIDwvZGl2PgogICAgICA8Ymxv Y2txdW90ZSBjaXRlPSJtaWQ6QkFZMTY3LURTNTA2RUM3QTRCRjhDMjA2RUI1MDk5Q0RFMzIwQHBo eC5nYmwiIHR5cGU9ImNpdGUiPgogICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgPGRp diBzdHlsZT0iRk9OVC1TSVpFOiAxMnB0OyBGT05ULUZBTUlMWTogJ0NhbGlicmknOyBDT0xPUjoK ICAgICAgICAgICAgIzAwMDAwMCI+CiAgICAgICAgICAgIDxkaXY+PGZvbnQgZmFjZT0iVGltZXMg TmV3IFJvbWFuIj4mbHQ7Jmx0O1JlbWVtYmVyIGJhY2sgaW4KICAgICAgICAgICAgICAgIHRoZSA1 MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcwogICAgICAgICAgICAg ICAgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJhdGhlcgog ICAgICAgICAgICAgICAgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQgdmVyeSBmZXcgbW92 aW5nCiAgICAgICAgICAgICAgICBwYXJ0cz8mZ3Q7Jmd0OzwvZm9udD48L2Rpdj4KICAgICAgICAg ICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgPGRpdj48Zm9udCBmYWNlPSJUaW1lcyBO ZXcgUm9tYW4iPkkgaGFkIGEgY2FyIHdpdGggYSBXYW5rZWwKICAgICAgICAgICAgICAgIGVuZ2lu ZS4gQSBiZWF1dGlmdWwgY2FyIHdpdGggdGhlIHN1cGVyIHNtb290aCBub24KICAgICAgICAgICAg ICAgIHZpYnJhdGluZyBlbmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cgZ3Jh ZGUKICAgICAgICAgICAgICAgIHBldHJvbCBidXQgb25seSBnYXZlIGFib3V0IDI1bWlsZXMgdG8g dGhlIGdhbGxvbi4KICAgICAgICAgICAgICAgIEFjY2VsZXJhdGlvbiB3YXMgbm90aGluZyB0byB3 cml0ZSBob21lIGFib3V0IGJ1dCB0aGUgbm9uCiAgICAgICAgICAgICAgICByZWNpcHJvY2F0aW5n IGRlc2lnbiBtYWRlIGZvciBzdXBlciBzbW9vdGggcnVubmluZy4gQXMKICAgICAgICAgICAgICAg IHlvdSBzYXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiB0aGUgdGhyZWUKICAg ICAgICAgICAgICAgIHBvaW50IHJvdG9yIHdhcyBpdHMgZG93bmZhbGwuIEdyZWF0IHBpdHkuIEkg cmVtZW1iZXIKICAgICAgICAgICAgICAgIHRoYXQgaXQgaGFkIGEgbWFudWFsIGdlYXIgc2hpZnQg YnV0IG5vIGNsdXRjaCBwZWRhbC4gVGhlCiAgICAgICAgICAgICAgICBjbHV0Y2ggd2FzIG9wZXJh dGVkIGVsZWN0cmljYWxseSB3aGVuIHlvdSBoZWxkIHRoZSBrbm9iCiAgICAgICAgICAgICAgICBv biB0aGUgdG9wIG9mIHRoZSBnZWFyIHN0aWNrLiBTbyB0aGUgYWN0IG9mIGNoYW5naW5nCiAgICAg ICAgICAgICAgICBnZWFyIGF1dG9tYXRpY2FsbHkgb3BlcmF0ZWQgdGhlIGNsdXRjaC4gSXQgaGFk IGEgZGV2aWNlCiAgICAgICAgICAgICAgICB3aGljaCBtYXRjaGVkJm5ic3A7IHRoZSBlbmdpbmUg c3BlZWQgdG8gdGhlIHdoZWVsIHNwZWVkIHdoZW4KICAgICAgICAgICAgICAgIHlvdSBjaGFuZ2Vk IGdlYXIuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5l dyBSb21hbiI+VGhlcmUgd2VyZSBzZXZlcmFsIFdhbmtlbAogICAgICAgICAgICAgICAgYWVybyBl bmdpbmVzIGJlaW5nIHBsYXllZCB3aXRoIGEgZmV3IHllYXJzIGFnbyBidXQgdGhleQogICAgICAg ICAgICAgICAgc2VlbSB0byBoYXZlIGZhbGxlbiBieSB0aGUgd2F5c2lkZS4gUGl0eSwgaXQgaGFk IHN1Y2gKICAgICAgICAgICAgICAgIHByb21pc2UuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8 ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5ldyBS b21hbiI+UGF0PC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAg ICAgICAgICA8ZGl2PgogICAgICAgICAgICAgIDxkaXYgc3R5bGU9IkZPTlQtU0laRTogc21hbGw7 IFRFWFQtREVDT1JBVElPTjogbm9uZTsKICAgICAgICAgICAgICAgIEZPTlQtRkFNSUxZOiAmcXVv dDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAgICAgICAgICAgICAgQ09M T1I6ICMwMDAwMDA7IEZPTlQtU1RZTEU6IG5vcm1hbDsgRElTUExBWTogaW5saW5lIj48Yj5Gcm9t OjwvYj4KICAgICAgICAgICAgICAgIDxhIG1vei1kby1ub3Qtc2VuZD0idHJ1ZSIgdGl0bGU9ImFz bHNhLnJuZ0BnbWFpbC5jb20iIGhyZWY9Im1haWx0bzphc2xzYS5ybmdAZ21haWwuY29tIj5SaWNo YXJkIEdpcmFyZDwvYT4gPC9kaXY+CiAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iRk9OVDogMTBw dCB0YWhvbWEiPgogICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iQkFDS0dST1VORDogI2Y1ZjVm NSI+CiAgICAgICAgICAgICAgICAgIDxkaXY+PGI+U2VudDo8L2I+IFN1bmRheSwgSmFudWFyeSAy NSwgMjAxNSAxMTowNSBQTTwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2PjxiPlRvOjwvYj4g PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiB0aXRsZT0ia29sYi1saXN0QG1hdHJvbmljcy5jb20i IGhyZWY9Im1haWx0bzprb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSI+a29sYi1saXN0QG1hdHJvbmlj cy5jb208L2E+CiAgICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2 PjxiPlN1YmplY3Q6PC9iPiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lPC9kaXY+CiAgICAg ICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8ZGl2 PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgPGRpdiBzdHlsZT0i Rk9OVC1TSVpFOiBzbWFsbDsgVEVYVC1ERUNPUkFUSU9OOiBub25lOwogICAgICAgICAgICAgIEZP TlQtRkFNSUxZOiAmcXVvdDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAg ICAgICAgICAgIENPTE9SOiAjMDAwMDAwOyBGT05ULVNUWUxFOiBub3JtYWw7IERJU1BMQVk6IGlu bGluZSI+CiAgICAgICAgICAgICAgPGRpdiBkaXI9Imx0ciI+Qm91cmtlIGJ1aWx0IG1hbnkgZXhh bXBsZXMgb2YgaGlzIGVuZ2luZQogICAgICAgICAgICAgICAgZm9yIHRydWNrcywgb3V0Ym9hcmQg bW90b3JzLCBhbmQgYWlyY3JhZnQuIFRoZXkgYWxsCiAgICAgICAgICAgICAgICB3b3JrZWQsIHJh biBmb3IgaHVuZHJlZHMgb2YgaG91cnMgd2l0aCBsaXR0bGUgd2VhciB0bwogICAgICAgICAgICAg ICAgYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9yc2Vwb3dlci4gT25l CiAgICAgICAgICAgICAgICBvZiB0aGUgYWlyY3JhZnQgZW5naW5lcyBpcyBpbiB0aGUgRUFBIG11 c2V1bS4KICAgICAgICAgICAgICAgIDxkaXY+TGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1cCBj b3N0cyBnb2luZyBpbnRvCiAgICAgICAgICAgICAgICAgIHByb2R1Y3Rpb24gd291bGQgYmUgYXN0 cm9ub21pY2FsIGFuZCBmb3IgYW4gYWlyY3JhZnQKICAgICAgICAgICAgICAgICAgZW5naW5lIHRo ZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMuIEFsbCBmb3IgYQogICAgICAgICAgICAg ICAgICBzbWFsbCBkaW1pbmlzaGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29uJ3QgaGFwcGVu LAogICAgICAgICAgICAgICAgICBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuPC9kaXY+CiAgICAg ICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5SaWNrIEdp cmFyZDwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5kbyBub3QgYXJjaGl2ZTwvZGl2PgogICAg ICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX2V4dHJhIj4K ICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICA8ZGl2IGNs YXNzPSJnbWFpbF9xdW90ZSI+T24gU3VuLCBKYW4gMjUsIDIwMTUgYXQgMTowOQogICAgICAgICAg ICAgICAgICBQTSwgdW5kb2N0b3IgPHNwYW4gZGlyPSJsdHIiPiZsdDs8YSBtb3otZG8tbm90LXNl bmQ9InRydWUiIGhyZWY9Im1haWx0bzp1bmRvY3RvckBwdGQubmV0IiB0YXJnZXQ9Il9ibGFuayI+ dW5kb2N0b3JAcHRkLm5ldDwvYT4mZ3Q7PC9zcGFuPgogICAgICAgICAgICAgICAgICB3cm90ZTo8 YnI+CiAgICAgICAgICAgICAgICAgIDxibG9ja3F1b3RlIGNsYXNzPSJnbWFpbF9xdW90ZSIgc3R5 bGU9IlBBRERJTkctTEVGVDoKICAgICAgICAgICAgICAgICAgICAxZXg7IE1BUkdJTjogMHB4IDBw eCAwcHggMC44ZXg7IEJPUkRFUi1MRUZUOiAjY2NjCiAgICAgICAgICAgICAgICAgICAgMXB4IHNv bGlkIj4KICAgICAgICAgICAgICAgICAgICA8ZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRp dj5SZW1lbWJlciBiYWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlCiAgICAgICAgICAgICAg ICAgICAgICAgIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyBpbnRyb2R1Y2VkPyBPbmUKICAgICAg ICAgICAgICAgICAgICAgICAgdHJpYW5ndWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyIHRo YW4KICAgICAgICAgICAgICAgICAgICAgICAgcmVjaXByb2NhdGluZyBtb3Rpb24gYW5kIHZlcnkg ZmV3IG1vdmluZyBwYXJ0cz88L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7 PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2Pkdvb2QgaWRlYSBhbmQgaXQgY291bGQg c3BpbiB2ZXJ5IGhpZ2ggcmV2cy4KICAgICAgICAgICAgICAgICAgICAgICAgUHJvYmxlbSBpcywg dGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20KICAgICAgICAgICAgICAgICAgICAgICAgd2Vh cmluZyBvbiB0aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkKICAgICAgICAgICAgICAgICAg ICAgICAgbGltaXRlZCBhcHBsaWNhdGlvbiBpbiB0aGUgcmVhbCB3b3JsZC4gPC9kaXY+CiAgICAg ICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAg PGRpdj5BbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24gdGhlIGRyYXdpbmcKICAgICAg ICAgICAgICAgICAgICAgICAgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCBzbGljZWQgYnJlYWQg Zm9yCiAgICAgICAgICAgICAgICAgICAgICAgIGdyZWF0bmVzcy4gSGF2ZW4ndCBoZWFyZCBhbnkg bW9yZSBhYm91dCB0aGF0CiAgICAgICAgICAgICAgICAgICAgICAgIG9uZS4gVGhhdCdzIE9LLiBK dXN0IGtlZXAgaW52ZW50aW5nLCBtYW55IG91dAogICAgICAgICAgICAgICAgICAgICAgICB0aGVy ZSBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4gPC9kaXY+CiAgICAgICAgICAgICAgICAgICAg ICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRpdj5EYXZlIEt1bHA8 L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAg ICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAg IDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5i c3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAg ICAgICAgICAgICAgICAgPGRpdj4KICAgICAgICAgICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0i Rk9OVC1TSVpFOiA5cHg7IENPTE9SOiAjNTc1NzU3Ij5TZW50CiAgICAgICAgICAgICAgICAgICAg ICAgICAgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+CiAg ICAgICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+CiAg ICAgICAgICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9Img1Ij48YnI+CiAgICAgICAgICAgICAg ICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIDxkaXY+LS0tLS0tLS0g T3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgICAg IDxkaXY+RnJvbTogQ2hhcmxpZSBFbmdsYW5kIDwvZGl2PgogICAgICAgICAgICAgICAgICAgICAg ICAgIDxkaXY+RGF0ZTowMS8yNS8yMDE1IDE6NDggUE0gKEdNVC0wNTowMCkgPC9kaXY+CiAgICAg ICAgICAgICAgICAgICAgICAgICAgPGRpdj5UbzogPGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBo cmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iIHRhcmdldD0iX2JsYW5rIj5rb2xi LWxpc3RAbWF0cm9uaWNzLmNvbTwvYT4KICAgICAgICAgICAgICAgICAgICAgICAgICA8L2Rpdj4K ICAgICAgICAgICAgICAgICAgICAgICAgICA8ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEJv dXJrZSBlbmdpbmUgPC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8 L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgICAgICAtLSZndDsgS29sYi1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiBDaGFybGllCiAgICAgICAgICAgICAgICAgICAgICAgICAgRW5nbGFuZCAmbHQ7 PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBocmVmPSJtYWlsdG86Y2VlbmdsYW5kN0BnbWFpbC5j b20iIHRhcmdldD0iX2JsYW5rIj5jZWVuZ2xhbmQ3QGdtYWlsLmNvbTwvYT4mZ3Q7PGJyPgogICAg ICAgICAgICAgICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICBPbiAx LzI1LzIwMTUgMTE6MTggQU0sIHdpbGxpYW0gc3VsbGl2YW4gd3JvdGU6PGJyPgogICAgICAgICAg ICAgICAgICAgICAgICAgICZndDsgLS0mZ3Q7IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieToK ICAgICAgICAgICAgICAgICAgICAgICAgICB3aWxsaWFtIHN1bGxpdmFuICZsdDs8YSBtb3otZG8t bm90LXNlbmQ9InRydWUiIGhyZWY9Im1haWx0bzp3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQiIHRh cmdldD0iX2JsYW5rIj53aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ8L2E+Jmd0Ozxicj4KICAgICAg ICAgICAgICAgICAgICAgICAgICAmZ3Q7PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZn dDsmbmJzcDsmbmJzcDsmbmJzcDsgQ2xpY2sgb24gdmFyaW91cyBzdHVmZiBpbiB0aGlzIGxpbmsu Jm5ic3A7CiAgICAgICAgICAgICAgICAgICAgICAgICAgTXkgYnJvdGhlciBzZW50IGl0IHRvIG1l LCB0aGlua2luZyBJJ2QgYmUKICAgICAgICAgICAgICAgICAgICAgICAgICBpbnRlcmVzdGVkLiZu YnNwOyBXaXRoIFJvdGF4IGRyb3BwaW5nIHRoZSBzbWFsbAogICAgICAgICAgICAgICAgICAgICAg ICAgIDItc3Ryb2tlcywgdGhlcmUgaXMgYSBuZWVkIGZvciByZXBsYWNlbWVudHMuJm5ic3A7CiAg ICAgICAgICAgICAgICAgICAgICAgICAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwcmV0 dHkgZ29vZC4mbmJzcDsKICAgICAgICAgICAgICAgICAgICAgICAgICBEb2VzIGFueW9uZSBoYXZl IGFueSBleHBlcmllbmNlL2NvbW1lbnRzIG9uCiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhp cyBvbmU/PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZndDs8YnI+CiAgICAgICAgICAg ICAgICAgICAgICAgICAgJmd0OyA8YSBtb3otZG8tbm90LXNlbmQ9InRydWUiIGhyZWY9Imh0dHA6 Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5i b3Vya2UtZW5naW5lLmNvbS9hbmk8L2E+PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZn dDs8YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgJmd0Ozxicj4KICAgICAgICAgICAgICAg ICAgICAgICAgICBJJ2Qgc3VnZ2VzdCBmaW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVyaW5n CiAgICAgICAgICAgICAgICAgICAgICAgICAgZXZhbHVhdGlvbi4gTXkgdGhvdWdodHM6IDxicj4K ICAgICAgICAgICAgICAgICAgICAgICAgICBDb25zaWRlciBob3cgc2V2ZXJlIHRoZSBpbWJhbGFu Y2Ugd2lsbCBiZSB3aXRoCiAgICAgICAgICAgICAgICAgICAgICAgICAgYm90aCBwaXN0b25zIG1v dmluZyB0aGUgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIHNhbWUgZGlyZWN0aW9uLCB0 aGVuIGhvdyBtdWNoIHRoZQogICAgICAgICAgICAgICAgICAgICAgICAgIGNvdW50ZXJ3ZWlnaHQg d2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICB0 aGF0IGZvcmNlICh3aXRob3V0IGNvbnRyaWJ1dGluZyBhbnkgcG93ZXIpLgogICAgICAgICAgICAg ICAgICAgICAgICAgIFRoZW4gY29uc2lkZXIgaG93IGxvbmcgYSA8YnI+CiAgICAgICAgICAgICAg ICAgICAgICAgICAgc2xpZGluZyBsaW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdvaW5n CiAgICAgICAgICAgICAgICAgICAgICAgICAgdG8gbGFzdCB3aGVuIHN1YmplY3RlZCB0byA8YnI+ CiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhvc2UgZm9yY2VzLiBUaGUgY2xhaW0gaXMgMS80 IHBvdW5kICgwLjI1IGxiKQogICAgICAgICAgICAgICAgICAgICAgICAgIHBlciBocC9oci4gVGhp cyBpcyBiZXR0ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IGFib3V0IDMwJSB0 aGFuIHRoZSBtb3N0IGVmZmljaWVudCBpbnRlcm5hbAogICAgICAgICAgICAgICAgICAgICAgICAg IGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ1 aWx0LCBhbmQgaXQncyBzdGlsbCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QKICAgICAgICAgICAg ICAgICAgICAgICAgICBpdCBhIGJpdCBzdHJhbmdlIHRoYXQgYSA8YnI+CiAgICAgICAgICAgICAg ICAgICAgICAgICAgZGVzaWduIHRoYXQncyBiZWVuIGFyb3VuZCBsb25nIGVub3VnaCBmb3IgdGhl CiAgICAgICAgICAgICAgICAgICAgICAgICAgcGF0ZW50cyB0byBleHBpcmUsIGFuZCBpcyA8YnI+ CiAgICAgICAgICAgICAgICAgICAgICAgICAgc3VwZXIgY2xlYW4sIGFuZCBiZWF0cyB0aGUgYmVz dCB0ZWNoIG91dCB0aGVyZQogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IDMwJSwgaGFzbid0 IHRha2VuIG92ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGV2ZXJ5IGVuZ2luZSBt YXJrZXQgb24gdGhlIHBsYW5ldD8mbmJzcDsgQW5kIGl0CiAgICAgICAgICAgICAgICAgICAgICAg ICAgdXNlcyAnZGV0b25hdGlvbicgdG8gZXh0cmFjdCA8YnI+CiAgICAgICAgICAgICAgICAgICAg ICAgICAgbW9yZSBlbmVyZ3kgZnJvbSB0aGUgZnVlbD8gV2hhdCBoYXBwZW5zIHRvIGEKICAgICAg ICAgICAgICAgICAgICAgICAgICBwaXN0b24gd2hlbiB5b3UgaGF2ZSA8YnI+CiAgICAgICAgICAg ICAgICAgICAgICAgICAgZGV0b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQW5z d2VyCiAgICAgICAgICAgICAgICAgICAgICAgICAgaGVscDogbm90aGluZyBnb29kLik8YnI+CiAg ICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIEN1 cnJlbnQgdGVjaG5vbG9neSBpbiA0IHN0cm9rZXMgY2FuIGNvbWUKICAgICAgICAgICAgICAgICAg ICAgICAgICBwcmV0dHkgY2xvc2UgdG8gdGhlIHNhbWUgPGJyPgogICAgICAgICAgICAgICAgICAg ICAgICAgIHBvd2VyL3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QKICAg ICAgICAgICAgICAgICAgICAgICAgICBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIDxicj4KICAg ICAgICAgICAgICAgICAgICAgICAgICBhdmFpbGFibGUgYXQgYW4gYWZmb3JkYWJsZSBwcmljZW9s Yi1MaXN0IgogICAgICAgICAgICAgICAgICAgICAgICAgIHRhcmdldD0iX2JsYW5rIiZndDs8YSBt b3otZG8tbm90LXNlbmQ9InRydWUiIGNsYXNzPSJtb3otdHh0LWxpbmstZnJlZXRleHQiIGhyZWY9 Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0aHR0cDovL3d3dy5t YXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP0tvbGItTGlzdGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbT09PT09PT09PT09PT09 PT09PTwvYT48YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAg ICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICA8YnI+CiAgICAgICAg ICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPC9kaXY+CiAgICAg ICAgICAgICAgICAgICAgPC9kaXY+CiAgICAgICAgICAgICAgICAgIDwvYmxvY2txdW90ZT4KICAg ICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAg PGJyIGNsZWFyPSJhbGwiPgogICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAg ICAgICAgICAgIC0tIDxicj4KICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX3NpZ25h dHVyZSI+CiAgICAgICAgICAgICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgICAgICAg ICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rp dj4KICAgICAgICAgICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9ImFyaWFsLCBzYW5zLXNlcmlm Ij48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM3B4Ij5CZWxpZXZlIHRob3NlIHdobyBhcmUKICAg ICAgICAgICAgICAgICAgICAgICAgICBzZWVraW5nIHRoZSB0cnV0aCwgZG91YnQgdGhvc2Ugd2hv IGZpbmQgaXQuPC9zcGFuPjwvZm9udD48L2Rpdj4KICAgICAgICAgICAgICAgICAgICA8ZGl2Pjxm b250IGZhY2U9ImFyaWFsLCBzYW5zLXNlcmlmIj48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM3B4 Ij4tQW5kcmUgR2lkZTwvc3Bhbj48L2ZvbnQ+PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgPGJy PgogICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAg ICAgICAgIDwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgIDwvZGl2PgogICAgICAg IDwvZGl2PgogICAgICA8L2Jsb2NrcXVvdGU+CiAgICA8L2Jsb2NrcXVvdGU+CiAgICA8YnI+CiAg CgoKPHByZT48Yj48Zm9udCBzaXplPSIyIiBjb2xvcj0iIzAwMDAwMCIgZmFjZT0iY291cmllciBu ZXcsY291cmllciI+CgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsIEZv cnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJy b3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlw dGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICZhbXA7IERvd25sb2FkLCA3LURheSBCcm93c2UsIENo YXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0t Jmd0OyA8YSBocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlz dCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3Q8L2E+Cl8tPQpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUg Z3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0g ICAtLSZndDsgPGEgaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIj5odHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb208L2E+Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENv bnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlz dCBBZG1pbi4KXy09ICAgLS0mZ3Q7IDxhIGhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24iPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb248L2E+Cl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09Cgo8L2ZvbnQ+PC9iPjwvcHJlPjwvYm9keT4=
class="">http://www.matronics.com/Navigator?Kolb-List
class="">http://forums.matronics.com
class="">http://www.matronics.com/contribution
undoctor
PostPosted: Wed Jan 28, 2015 9:10 am    Post subject: Bourke engine Reply with quote
Huh, never heard that before. Anyone else having a problem?
Russ, what kind of gibberish?
Date:01/28/2015 11:46 AM (GMT-05:00)
rlaird
PostPosted: Wed Jan 28, 2015 9:19 am    Post subject: Bourke engine Reply with quote
He's sending out Android multipart messages...  Most email systems decode it just fine.  Here's the header:
----_com.android.email_362066747291730
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: base64
I'll bet if you viewed his messages on a different email program, it would look fine (like it does for most of us).
  -- Robert
On Wed, Jan 28, 2015 at 11:10 AM, undoctor <undoctor(at)ptd.net (undoctor(at)ptd.net)> wrote:
[quote]Huh, never heard that before. Anyone else having a problem?
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
PostPosted: Wed Jan 28, 2015 9:34 am    Post subject: Bourke engine Reply with quote
Russ' copied text is gibberish, but Undoctor's looks fine on a Win7 PC. Another attempt by Apple to drive everyone into the hive? Smile
n 1/28/2015 11:10 AM, undoctor wrote:
[quote] Huh, never heard that before. Anyone else having a problem?
���~���,�g���M4�G�q���z����.�'�8*�[.+-f��Z+�`��axƭ���r���^jÛ«z�Z�(�������Ƕ�j|���n�)b�'���!j���'�+����ب�r�y'���C� å¡§{ ����,x(Z�P���!j���ٮr�r��j�|���� &j��',r��5�â�«h��%l���m���� ���'���o�j��j�+*�[.+-�0�8�Ia�T1 jg���r��z{Z�����i�^�&���lZ+�k�y����+�k&j��',r������+�k&j��',r��h��B�{k������y�������ʋ����������.��+����jY^.+-٢����i��0�f����r�(��(���n�b�xm���� &j��',r��r���&�*'���'��k{��w/�tml=[b]
stuart(at)harnerfarm.net
PostPosted: Wed Jan 28, 2015 4:04 pm    Post subject: Bourke engine Reply with quote
I am running Outlook 2010 on a Windows machine and undoctor’s messages are always blank for me.
However, if I log onto the Matronics web site and view them in the forum, they are fine. Also, if someone does a reply and leaves undoctor’s comments in the reply, I USUALLY (but not always) see the text of the original message.
Very strange, I have always been curious as to what causes this.
Stuart
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of kinne russ
Sent: Wednesday, January 28, 2015 10:47 AM
class="">http://www.matronics.com/Navigator?Kolb-Listclass="">http://forums.matronics.comclass="">http://www.matronics.com/contribution
rlaird
PostPosted: Wed Jan 28, 2015 4:43 pm    Post subject: Bourke engine Reply with quote
I could explain it, but you'd fall asleep before you finished reading!  Smile
Anyway, it's not Kolb-related.
  -- Robert
P.S.  Email directly if you _really_ want to know!  Smile
On Wed, Jan 28, 2015 at 6:03 PM, Stuart Harner <stuart(at)harnerfarm.net (stuart(at)harnerfarm.net)> wrote:
Stuart
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of kinne russ
Robert Laird
Houston, TX area
PostPosted: Wed Jan 28, 2015 5:30 pm    Post subject: Bourke engine Reply with quote
When in doubt, blame Outlook.
Smile
Seriously, check on whether Outlook is set to display only plain text, or some similar setting.
Charlie
Win7 using Thunderbird email client
On 1/28/2015 6:03 PM, Stuart Harner wrote:
[quote] <![endif]--> <![endif]-->
Stuart
