Housai engine lift/hoist ring... ?
draftsjust417(at)gmail.co
PostPosted: Wed Jan 28, 2015 10:12 am    Post subject: Housai engine lift/hoist ring... ? Reply with quote
Ladies and gents, I am in need of a screw-on lifting/hoist ring for a Housai engine.
Does anyone have one to donate or sell?
Justin
Seattle/KPAE
N13472(at)aol.com
PostPosted: Wed Jan 28, 2015 10:41 am    Post subject: Housai engine lift/hoist ring... ? Reply with quote
Are you having eng. troubles?
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Justin Drafts
Sent: Wednesday, January 28, 2015 10:11 AM
To: yak-list(at)matronics.com
Subject: Re: Housai engine lift/hoist ring... ?
Justin
Seattle/KPAE
dantpayne(at)icloud.com
PostPosted: Wed Jan 28, 2015 11:03 am    Post subject: Housai engine lift/hoist ring... ? Reply with quote
Justin,
If you drill/attach two pieces of angle iron onto the generator studs (have a hole drilled through each of the vertical sides of angle iron) you can attach one end of a lift strap to the pad, and the other to the prop shaft. Doug Sapp informed me of this method when I was changing the engine mount rubbers on 4024N. Works well! Good luck!
Keep 'em Flyin',
Dan
On Jan 28, 2015, at 1:40 PM, Tom Elliott <N13472(at)aol.com (N13472(at)aol.com)> wrote:
[quote] <![endif]--> <![endif]-->
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Justin Drafts
Justin
Seattle/KPAE
jonboede(at)hotmail.com
PostPosted: Wed Jan 28, 2015 11:07 am    Post subject: Housai engine lift/hoist ring... ? Reply with quote
Attached is a pdf of a generator base plate that you can use to lift the engine if nobody has a lifting ring.
Jon
Date: Wed, 28 Jan 2015 10:10:56 -0800
Justin
Seattle/KPAE
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
Generator_Base_Plate.pdf
Download
 Filename:  Generator_Base_Plate.pdf
 Filesize:  15.92 KB
 Downloaded:  432 Time(s)
dsavarese0812(at)bellsout
PostPosted: Wed Jan 28, 2015 11:27 am    Post subject: Housai engine lift/hoist ring... ? Reply with quote
Here's one that George and Cliff Coy use. Imade one years ago and it
worked great.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Jon
Housai engine.
Justin
Seattle/KPAE
ENGINE_HOIST_DETAILS.pdf
Download
 Filename:  ENGINE_HOIST_DETAILS.pdf
 Filesize:  748.76 KB
PostPosted: Wed Jan 28, 2015 11:34 am    Post subject: Housai engine lift/hoist ring... ? Reply with quote
Ah, good idea Dan!
Will keep that in mind.
Thankfully the engine on my CJ is doing great, but someone generous recently gave me an old Housai, no history or papers, but ideal for the odd spare part.
Its sitting vertical/upright at moment, ideal for lifting w/ a ring. It'd be a challenge, at this point, to get it horizontal single-handedly.  Hoping to get it cleaned up and preserved asap.
Lifting rings are avail in China but... $$$.
Thanks!!!    -Justin
On Wed, Jan 28, 2015 at 11:03 AM, Dan Payne <dantpayne(at)icloud.com (dantpayne(at)icloud.com)> wrote:
[quote]Justin,
Keep 'em Flyin',
Dan
Subject: Yak-List: Re: Housai engine lift/hoist ring... ?
Justin
Seattle/KPAE
PostPosted: Wed Jan 28, 2015 11:41 am    Post subject: Housai engine lift/hoist ring... ? Reply with quote
Excellent, thx Jon!
On Wed, Jan 28, 2015 at 11:06 AM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
[quote] Attached is a pdf of a generator base plate that you can use to lift the engine if nobody has a lifting ring.
Jon
From: draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)
Justin
Seattle/KPAE
