		bobbarrow
				 Posted: Wed Jan 28, 2015 6:53 pm    Post subject: Z14 with different bus voltages ? |
				I have a Vans RV7A (finished but not yet flying) with the Z14 architecture (dual buses with crossfeed contactor). The only deviation from Z14 is that the system does not automatically crossfeed between buses at engine start).
 Bus 1 has a B&C LR3C voltage regulator, a B&C L40 alternator and an Odyssey PC680 AGM battery (17 Amphours). The aircraft starts on Bus 1 and all heavy current users are on this bus.
 Bus 2 has a B&C LR3C voltage regulator, a B&C SD20 alternator and an Odyssey PC310 AGM battery (8 Amphours). This bus supports only the primary EFIS and one LightSpeed EI (magneto on the other ignition side).
 The LR3C regulators are both factory set to approx 14.4 volts but there is likely to be a very small difference in the settings. In practical terms this means that when the crossfeed contactor is activated one alternator will tend to hog the load but the other alternator will tend to flicker on and off. I think that this cannot be desirable.
 Odyssey Batteries have advised me that the optimum bus voltage for charging either the PC310 or PC680 is 14.4 volts but that the recommended min/max is 13.6 to 14.8 volts. The B&C installation manual for the LR3C regulator says that the voltage can be manually adjusted up and down. So here are my questions:
 1. Should I create a voltage spread between the LR3C regulators such that when the crossfeed contactor is activated the L40 takes all the load and the SD20 justs sit idle in the background as a true standby alternator. In other words Bus 1 and Bus 2 would run at different voltages when the crossfeed is NOT activated.
 2. If the answer to question 1 is YES then what would be the optimum differential voltages for the alternators to achieve a satisfactory outcome. Would say running the L40 at 14.6 volts and the SD20 at 14.1 volts (thus creating a spread of 0.5 volts) be desirable.
 Bob Barrow
		user9253
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Wed Jan 28, 2015 8:05 pm    Post subject: Re: Z14 with different bus voltages ? |
				Yes, adjust the regulators to achieve a 1/2 volt difference.  Adjust L40 to 14.2 volts and SD20 to 13.7 volts.  That is just an educated guess on my part.  Bob N is the expert.  Since the small battery is not intended for starting, it will not be discharged very much.  13.7 volts will keep the small battery charged if the cross feed contactor is not energized.  And 14.2 volts is optimum for the big battery.
 Joe
  _________________ Joe Gores |
		yellowduckduo(at)gmail.co Guest
				 Posted: Thu Jan 29, 2015 4:56 am    Post subject: Z14 with different bus voltages ? |
				I do not close the crossfeed unless one alternator has quit and
 therefore don't have any concern about running the same voltage on both
 systems. Seems little point of having dual systems if a failure in one
 can affect the other.  My crossfeed does auto close during cranking but
 again not an issue.
 Ken
 On 28/01/2015 9:53 PM, bobbarrow wrote:
  Bob Barrow
  http://forums.matronics.com/viewtopic.php?p=437794#437794
				 Posted: Thu Jan 29, 2015 5:39 am    Post subject: Z14 with different bus voltages ? |
				At 06:55 2015-01-29, you wrote:
 both systems. Seems little point of having dual systems if a failure
 in one can affect the other.  My crossfeed does auto close during
 cranking but again not an issue.
 Ken
    That was the spirit and intent of the Z-14 architecture.
    Two batteries for cranking . . . if useful . . . but
    if the failure gods smile on your airplane with benevolence,
    the cross-feed contactor is never closed in flight.
    They are intended to be separate, independent systems
    with the capability to share if needed . . . but no
    more.
    If you DO operate with the contactor closed, then you
    have Z-12 with two batteries. In that case the smaller
    alternator should be regulated with an SB-1 regulator
    set up to conduct operations as an always-on but
    relaxed, stand-by alternator with active notification
    of activation.
    In that case, the standby regulator is set for 13.5
    volts and never intended to charge batteries.
				 Posted: Thu Jan 29, 2015 8:46 am    Post subject: Z14 with different bus voltages ? |
				On 1/29/2015 8:38 AM, Robert L. Nuckolls, III wrote:
  <nuckolls.bob(at)aeroelectric.com>
 > Ken
 It took me awhile to fully understand the spirit and intent of a
 straight up Z-14 but  I have been operating that way for over year now
 and am very satisfied.  The (2) 960s give me what I  need to reliably
 turnover my cold IO540 with the lightweight starter....
    more.
 ..and the peace of mind of having 2 separate electrical systems that
 can be linked if ever needed.
 Given the (3) EFISs and the rest of the 'kitchen sink' panel I have, I
 can turn the key parts on, do all my flight plan entry and clearance
 work, and know that I still have at least 1 fresh battery to cross feed
 with the somewhat discharged 2nd battery for a reliable start.  This
 capability was very important to me and my flying based on previous
 experience with my Maule.
 FWIW, I don't have any auto cross feed function during the start. That
 would have been undesirable based on early experiences with the EFISs
 re-booting due to low voltage during some cross feed starts. I learned
 to do single battery starts in certain situations to avoid the (longish)
 reboots - the same situations where a 2 battery start would otherwise be
 most desirable.  I eliminated that situation by adding a power
 stabilizer to maintain adequate voltage levels during the start for the
 EFISs.  Now, an auto cross feed during the start would be nice but not
 necessary.
 Bill "the happy RV10 driver" Watson
		bobbarrow
				 Posted: Sun Feb 01, 2015 1:52 am    Post subject: Re: Z14 with different bus voltages ? |
				 	  | nuckolls.bob(at)aeroelect wrote: | 	 		     That was the spirit and intent of the Z-14 architecture.
    more.
    of activation.
    Bob . . . |
 It is not my intent to fly around with the crossfeed contactor closed for normal operations. However there might be circumstances where it is closed, such as for testing, or if inadvertently left on after a 2 battery start.
 In that case one alternator is going to hog the load. Therefore wouldn't it make sense to ensure that a preferred alternator (in my case the bigger L40) simply takes all the load and the second alternator is not rapidly flickering on and off incessantly (which can't be good for it).
 Is there a perceived problem with setting the SD20 to a slightly lower voltage? If there is no problem then what would be an ideal voltage spread.
 Cheers Bob
				 Posted: Sun Feb 01, 2015 8:21 am    Post subject: Z14 with different bus voltages ? |
 voltage spread.
     No, that IS the way it's done in Z-12.
     The 'standby' alternator is set lower such
     that it relaxes but high enough to prevent
     discharge of the second battery . . . which
     guarantees that the second battery doesn't
     get fully charged unless the cross-feed is
     closed.
     Two alternators set to the same voltage generally
     don't 'argue' with each other but when we do that
     on purpose, it's usually done with regulators
     designed to effect load-sharing between paralleled
     alternators. If the SD-20 is 'higher' . . . it would
     pick up loads to the limit of its capacity whereupon
     bus voltage sags and the other alternator starts
     picking up the difference . . . no spectacular
     or annoying events.
     "Left on after a two-battery start"? I really
     dislike that word "inadvertently". It's like
     "I inadvertently let IAS decay and spun the
     sucker in" . . . we're pilots. We are encouraged . . .
     indeed expected to pay attention to critical things
     and either automate potentially distracting
     conditions . . . or design them out of the system.
     If that's a real concern, perhaps "X_FEED CLOSED"
     should be an item on your annunciator panel.
     If you want single-battery start for the purpose
     of avoiding brown-out resets . . . then your
     airplane is a dual-battery/dual-alternator
     split bus system for all but the most pressing
     circumstances with rarified probabilities.
     Given the disparity of battery sizes, two-battery
     starts are probably in that rarified category
     managed best by better management of the main
     battery's condition.
     I suggest that the two systems be treated as
     completely independent. Both set to 14.4v and
     the cross-feed switch ignored until you encounter
     a situation where remembering that it's there
     may be useful to you. With prudent preventative
     maintenance and given the demonstrated reliability
     of modern electrics, it seems likely that you'll
     never need to close that switch.
