pedroagua(at)yahoo.com Guest
Posted: Wed Jun 28, 2006 7:56 pm Post subject: Clearances for Vetterman 4-pipe on Older RV-4 O-360 |
Guys,
I've got an older RV-4, 1988 vintage, with an O-360 and a fixed-pitch prop (and cowling). My old exhaust system had to go due to cracks, and I'm trying to install a Vetterman 4-pipe system that I bought. My concern is, the ball joint of the pipe off the number 2 cylinder comes to within about 1/2 to 3/8 inch of the cowling fiberglass. Larry Veterman's instructions say that the pipes should be 3/4 inch from the cowling, minimum.
Anybody got any experience with this? After all the metal-bending I've down so far, I don't feel like switching to a crossover... and I might end up with the same problem.
Pedro
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1˘/min.
| - The Matronics RV4-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV4-List |
PGLong
Posted: Thu Jun 29, 2006 4:24 am Post subject: Clearances for Vetterman 4-pipe on Older RV-4 O-360 |
Had the same problem with my -4. Cowling got so warm in one area it turned almost to jelly. Glued a piece of foil coated (asbestos?) fabric to the cowling in this area and problem solved. If your interested, I could find out from my race car friend what it was and where he got it.
Pat Long
PGLong(at)aol.com
N120PL
RV4
Bay City, Michigan
3CM
_________________ Pat Long
RV-4, N120PL
Bay City, MI |
Robin Marks
![](images/avatars/138089392343e4d67c48b9a.jpg)
Joined: 10 Jan 2006 Posts: 24 Location: San Luis Obispo, CA
Posted: Thu Jun 29, 2006 7:22 am Post subject: Clearances for Vetterman 4-pipe on Older RV-4 O-360 |
Pat,
I am interested in the product name & source plus the best choice of adhesive!
Robin
RV-4 Sold
RV-6A 300 Hours
RV-10 Building
From: owner-rv4-list-server(at)matronics.com [mailto:owner-rv4-list-server(at)matronics.com] On Behalf Of PGLong(at)aol.com
Sent: Thursday, June 29, 2006 5:22 AM
To: rv4-list(at)matronics.com
Subject: Re: Clearances for Vetterman 4-pipe on Older RV-4 O-360
Pat Long
PGLong(at)aol.com
N120PL
RV4
Bay City, Michigan
3CM
_________________ RV-4 Sold
RV-6A 0-360 - C/S Flying |
smokyray(at)yahoo.com Guest
Posted: Thu Jun 29, 2006 11:41 am Post subject: Clearances for Vetterman 4-pipe on Older RV-4 O-360 |
Robin, Try Wicks Aircraft supply, the product is called Thermocool...
RR
Robin Marks <robin(at)mrmoisture.com> wrote:
Robin
RV-4 Sold
RV-6A 300 Hours
RV-10 Building
Pat Long
PGLong(at)aol.com
N120PL
RV4
Bay City, Michigan
3CM
How low will we go? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
mbick(at)carolina.rr.com Guest
Posted: Thu Jun 29, 2006 11:43 am Post subject: Clearances for Vetterman 4-pipe on Older RV-4 O-360 |
Summit racing has a pretty good online store
http://store.summitracing.com/egnsearch.asp?N=4294923429+4294923290+115+4294853962
Sent: Thursday, June 29, 2006 8:22 AM
Pat Long
PGLong(at)aol.com
N120PL
RV4
Bay City, Michigan
3CM
PGLong
Posted: Fri Jun 30, 2006 10:19 am Post subject: Clearances for Vetterman 4-pipe on Older RV-4 O-360 |
Hi Robin
Checked into the product I used for heat problems with my exhaust. Here it is. It's called Heatscreen #DSN010401 made by Design Engineering, Inc., and was purchased from Motorstate Distributors. Their web site is Motorstate.com and phone is 800-772-2678. The product is described as aluminized radiant heat screen, good for temperatures up to 2000 degrees on the aluminum side, and 1000 degrees on the fabric side. I used the red high temperature silicon to make it stick to my cowl. Would highly recommend it for those close clearance exhaust problems. This material is roughly 1/16" to 3/32" thick. Hope this solves your heat problem.
Pat Long
PGLong(at)aol.com
N120PL
RV4
Bay City, Michigan
3CM
RV-4, N120PL
Bay City, MI |
