ploucandco
Posted: Thu Feb 05, 2015 6:19 am Post subject: Integrating an ipad mini in the panel |
Hello all,
Just wanted to share some pictures of the outstanding work that Dirk Oyen, the builder of OO-145, did by integrating an ipad mini in his panel. A new left panel fiberglass made in which you just slide in the ipad mini.
On top of that, a dedicated converter takes the ipad lightning connector digital audio information and transforms it to analog in order to enter the aux input of the Funke ATR833 radio.
So Skydemon as moving map and the ipad music player as entertainment source. The cable on the pictures is the original one without audio interface.
Have fun, Jacques
617.82 KB |
14027 Time(s) |
650.27 KB |
14027 Time(s) |
641.18 KB |
14027 Time(s) |
498.57 KB |
14027 Time(s) |
412.18 KB |
14027 Time(s) |
281.01 KB |
14027 Time(s) |
298.89 KB |
14027 Time(s) |
max8992
Posted: Thu Feb 05, 2015 8:05 am Post subject: Integrating an ipad mini in the panel |
Hi Jacques,
Great job! How can we reproduce it?
Max Cointe
mcointe(at)free.fr
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 540 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1660 heures
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de ploucandco
Envoyé : jeudi 5 février 2015 15:20
À : europa-list(at)matronics.com
Objet : Integrating an ipad mini in the panel
--> <jacques(at)platisource.com>
Hello all,
Have fun, Jacques
http://forums.matronics.com/viewtopic.php?p=438074#438074
http://forums.matronics.com//files/img_1483_159.jpg
http://forums.matronics.com//files/img_1484_358.jpg
http://forums.matronics.com//files/img_1487_203.jpg
http://forums.matronics.com//files/img_1489_162.jpg
http://forums.matronics.com//files/img_1491_181.jpg
http://forums.matronics.com//files/20150202_205135_101.jpg
http://forums.matronics.com//files/20150202_205238_193.jpg
_________________ Max8992
Europa XS #560 F-PMLH |
Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Thu Feb 05, 2015 10:33 am Post subject: Re: Integrating an ipad mini in the panel |
Very Nice Job.
How is the GPS Reception into the Ipad?
I found mounting the Ipad similar to yours, that the GPS reception was poor. To get over the poor reception I had to use a bluetooth GPS receiver.
Another problem I had was powering the Ipad. The plug into the 12V power outlet (cigarette lighter socket) Different units produced static interference over the head set. I could not find one that did not cause a problem. I would be interested in knowing how you have got over the problem and what interface you used for powering your Ipad.
Your work looks very neat. Any information you may want to share would be very gratefully received.
_________________ Richard Wheelwright
G-IRPW
First Flight 24th July 2013 |
pmorgans
Posted: Thu Feb 05, 2015 1:01 pm Post subject: Integrating an ipad mini in the panel |
Hi Jaques,
Nice panel; interesting to see that the trim switch has been installed so that the operation matches the position indicator - ie.,'up' against 'up' - contrary to the manual. I've turned my switch around as well and it's certainly more instinctive, and hence safer for me, than the original configuration.
Kind Regards
Peter
Sent: Thursday, 5 February 2015, 14:19
Subject: Integrating an ipad mini in the panel
--> Europa-List message posted by: "ploucandco" <jacques(at)platisource.com (jacques(at)platisource.com)>
Hello all,
Have fun, Jacques
http://forums.matronics.com//files/20150202_205238_193.jpg href="http://www.matronics.com/Navigator?Europa-List" target="_blank">p; -Matt Dralle, Libution" =======
_________________ The Titanic was built by professionals; the Ark by an amateur |
dpark748(at)icloud.com Guest
Posted: Thu Feb 05, 2015 2:51 pm Post subject: Integrating an ipad mini in the panel |
Richard,
I use my Mini Ipad fitted to right hand inst panel powered by cigarette lighter socket direct from battery thru fuse on engine side of firewall. The lighter socket also serves as a convenient way to charge the battery. No probs with interference.
Regards Dave G-LDVO
| Quote: | On 5 Feb 2015, at 18:33, Richard Wheelwright <rpwheelwright(at)yahoo.co.uk> wrote:
Very Nice Job.
Your work looks very neat. Any information you may want to share would be very gratefully receve.
Richard Wheelwright
G-IRPW
http://forums.matronics.com/viewtopic.php?p=438087#438087
rlborger(at)mac.com Guest
Posted: Thu Feb 05, 2015 3:13 pm Post subject: Integrating an ipad mini in the panel |
Gents,
FWIW, I use an iPad2 on a RAM mount attached to the right side of the instrument panel. Power comes from a USB terminal on the back of my GRT Sport to which I have added an extension which comes around to the left side of the display.
[img]cid:A1698416-A939-4FE1-A27B-1C622F928729[/img]
Ya, it’s kinda ungainly from the cockpit with a USB line running from one side of the panel to the other, but for now it works. No noise, no interference, no problems at all. Eventually, I may see if I can obtain a longer USB extension and bring it out the right side of the right panel close to the iPad. But that’s for future work on the panels. Right now I need to start an annual condition inspection so I can see if, in 2015, I can fly more than double the 25 hrs I flew in 2014.
Blue skies & tailwinds Y'all,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Feb 5, 2015, at 4:49 PM, david park <dpark748(at)icloud.com (dpark748(at)icloud.com)> wrote:--> Europa-List message posted by: david park <dpark748(at)icloud.com (dpark748(at)icloud.com)>Richard,I use my Mini Ipad fitted to right hand inst panel powered by cigarette lighter socket direct from battery thru fuse on engine side of firewall. The lighter socket also serves as a convenient way to charge the battery. No probs with interference.Regards Dave G-LDVOSent from my iPhone | Quote: | | On 5 Feb 2015, at 18:33, Richard Wheelwright <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)> wrote:--> Europa-List message posted by: "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)>Very Nice Job. How is the GPS Reception into the Ipad?I found mounting the Ipad similar to yours, that the GPS reception was poor. To get over the poor reception I had to use a bluetooth GPS receiver.Another problem I had was powering the Ipad. The plug into the 12V power outlet (cigarette lighter socket) Different units produced static interference over the head set. I could not find one that did not cause a problem. I would be interested in knowing how you have got over the problem and what interface you used for powering your Ipad. Your work looks very neat. Any information you may want to share would be very gratefully receve.--------Richard WheelwrightG-IRPWFirst Flight 24th July 2013 |
129.12 KB |
13965 Time(s) |
ploucandco
Posted: Thu Feb 05, 2015 3:23 pm Post subject: Re: Integrating an ipad mini in the panel |
Hello Richard, the Funke ATR833 is very sensitive to interferences (EMC) and so we had to go for an expensive TomTom 12V to high power USB adapter.
Is your panel metal or fiberglass that you had GPS issues? This one is fiberglass for not blocking GPS signal.
If you want more infos, you can send me a private message to receive Dirk's e-mail.
Jacques.
Remi Guerner
Posted: Fri Feb 06, 2015 1:19 am Post subject: Re: Integrating an ipad mini in the panel |
Richard,
I have had a lot of interferences from the iPad power cable, especially at the lower radio frequencies, typically 121 MHz and below. My friend and Europa builder Denis Mangeot designed and provided a filtering circuitry which, after many hours of testing and modifying, finally solved the problem. Attached is a picture of the final version of this filter. I do not have a circuit diagram and component list available right now but I could work at it if anyone is interested.
Remi
<<<<<<The>>>>>>>
485.96 KB |
13937 Time(s) |
peterz(at)zutrasoft.com Guest
Posted: Fri Feb 06, 2015 5:51 am Post subject: Integrating an ipad mini in the panel |
Hi Remi,
After many attempts I have found a charger which was clean enough to not cause interference for my radios, but I still definitely would be very interested in a schematic and parts list if possible.
Many thanks!
Pete
a239
| Quote: | On Feb 6, 2015, at 4:19 AM, Remi Guerner <air.guerner(at)orange.fr> wrote:
Richard,
Remi
http://forums.matronics.com/viewtopic.php?p=438107#438107
http://forums.matronics.com//files/p1000075a_720.jpg
Richard Wheelwright
Posted: Fri Feb 06, 2015 10:21 am Post subject: Re: Integrating an ipad mini in the panel |
David,
My 12v power output is set up exactly as you describe. I too did it this way to provide easy charging of the battery when needed.
I have tried different USB power adapters but all give bad static in the headset. When I was on the quest of finding a good USB power out-put, I was more looking towards a hard wiered output instead of just a plug into a 12v socket version.
Jacques,
Yes you are correct the ATR833 is very sensitive but a quality product, and I have no regrets in fitting it. I would be intrested in which version of the TomTom you used. I Will PM you for your contact details. My panel is fiberglass but I did have problems in receiving the GPS signel.
G-IRPW
