Tim Olson
Posted: Mon Feb 16, 2015 12:53 pm Post subject: RV-10 Quadrant Mounting Hole Dimensions |
Hey all,
If there's anyone who has their RV-10 throttle quadrant
not installed who could measure the spacing
in both directions for the mounting holes on the top,
I'm in need of the measurements.
I'm going to have to modify the RV-14 a bit probably,
as they haven't planned for a quadrant at this time,
and I'm thinking I'll just use the RV-10 quadrant.
I just need to see how much I'll have to shuffle things
around to make it fit.
Also, if you have the distance from the forward
most (skinny end, not lever end) holes, to the
furthest forward part of the quadrant, that would
be good too, so I know how far it sticks up into
the forward fuselage forward of the panel.
The RV-14 has a goofy fuse box pillar (that I
will also have to modify) in that area so I need
to modify that as well. So I'm verifying fit.
Thanks!
Tim Olson
Posted: Tue Feb 17, 2015 11:09 am Post subject: RV-10 Quadrant Mounting Hole Dimensions |
Just circling back. I did get the info I needed.
On 2/16/2015 2:49 PM, Tim Olson wrote:
Hey all,
Thanks!
