Posted: Tue Mar 03, 2015 5:09 am Post subject: Infinity grip switch driving S702 starter relay |
Anyone else using an Infinity grip switch to actuate a S702 starter relay?
According to the specs of the Infinity grip switches, the contacts are rated at 6Amp.
| Quote: | From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts works out
to 5.6Amps...and that would be a max since the battery would provide less at cranking
time.
The numbers say it should be OK - I'm looking to find out if anyone is doing it for
real - and how is it working for you?
Ralph Capen
Posted: Tue Mar 03, 2015 5:50 am Post subject: Infinity grip switch driving S702 starter relay |
Interesting - I'll look in to this....
How many are out there interfacing the Infinity grip switch to the Starter relay?
Still want to hear if anyone is using my stated configuration though....
recapen(at)EARTHLINK.NET Guest
Posted: Tue Mar 03, 2015 6:40 am Post subject: Infinity grip switch driving S702 starter relay |
Linn,
Good points made!
I currently have it on a relay that the hand-grip activates with a safety interlock
switch - my line of thinking is to simplify by removing the relay and driving it direct.
My initial line of thinking for putting it on the hand-grip was for an in-flight restart -
which would require one hand on the stick while the other works throttle and mixture.
What I currently have works very well - but it is complex and I am trying to simplify...
Looking for evidence of the problem you alluded to.
Ralph
Posted: Tue Mar 03, 2015 6:55 am Post subject: Infinity grip switch driving S702 starter relay |
Ralph,
On the RV-8A the first version had the bottom push button on the stick being
the start button, providing power to the starter solenoid. This button does
not have the capacity to operate the starter solenoid directly. I installed
a small 12VDC relay (100ma coil, ~$1.50 from Allied Electronics) in the
circuit such that the stick button operated the relay, the relay then
provided power to the starter solenoid.
But - this setup was quickly changed as twice during the first flights I
inadvertently bumped the stick start button while the engine was running. I
kept the relay set up and just added a small momentary pushbutton out of the
way at the top of the right side switch/breaker panel to use instead of the
stick button.
On the RV-10 I just used the standard 10amp panel pushbutton for engine
start to directly provide power to the starter solenoid.
Bottom line - recommend not using the stick buttons to operate the starter
solenoid.
Carl
Posted: Tue Mar 03, 2015 7:16 am Post subject: Infinity grip switch driving S702 starter relay |
Carl,
Thanks for your input.
I have a secondary safety switch to prevent the accidental activation along
with the relay like you described currently installed.
My intent was to simplify by removing the relay. Sounds like my best bet
is to leave it as is! It works great for me.....
Ralph
Posted: Tue Mar 03, 2015 7:17 am Post subject: Infinity grip switch driving S702 starter relay |
David,
Thanks for the info. I'll probably leave mine as is since the relay and safety switch work well!
Ralph
