Oil Hose
MJKTuck(at)cs.com
PostPosted: Mon Mar 02, 2015 9:00 pm    Post subject: Oil Hose Reply with quote
Hi All,
I'm looking to replace my oil hoses. The one from the pump to the
radiator has a 90 deg bend in it. I had noted that it was suggested I
contact Lockwood as they have a metal 90 deg adapter to which regular
hose could be fitted. I contacted them and they said just to use 'an AN
fitting size -8'. Looking at the manual though the thread seems to be
14.4mm so I'm not sure what they meant now. I wonder if they meant to
make a 90 deg elbow using AN fittings. I couldn't figure the parts I
would need though.
Any help as to what others have done would be appreciated.
Also, are there any US sources for the rubber engine mounts or are they
uniquely Europa, in which case I would contact the factory in the UK.
Martin Tuck
N152MT
Wichita, KS
alanb(at)dpy01.co.uk
PostPosted: Mon Mar 02, 2015 11:08 pm    Post subject: Oil Hose Reply with quote
Replaced mine last year and used normal oil hose with no bends and no 90 deg bend on the pump.
route of hose work ok without any kinks or tight bends.
Alan
G-OBJT
On 3 Mar 2015, at 04:59, Martin Tuck <MJKTuck(at)cs.com> wrote:
Hi All,
I'm looking to replace my oil hoses. The one from the pump to the radiator has a 90 deg bend in it. I had noted that it was suggested I contact Lockwood as they have a metal 90 deg adapter to which regular hose could be fitted. I contacted them and they said just to use 'an AN fitting size -8'. Looking at the manual though the thread seems to be 14.4mm so I'm not sure what they meant now. I wonder if they meant to make a 90 deg elbow using AN fittings. I couldn't figure the parts I would need though.
Also, are there any US sources for the rubber engine mounts or are they uniquely Europa, in which case I would contact the factory in the UK.
Martin Tuck
N152MT
Wichita, KS
max8992
PostPosted: Tue Mar 03, 2015 12:49 am    Post subject: Oil Hose Reply with quote
So did I with normal (but adequate) oil hose. Just take of care of the route
you give to it and avoid short turns!
Max Cointe
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 540 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1660 heures
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de Alan Burrill
Envoyé : mardi 3 mars 2015 08:08
À : Europa Forum Forum
Objet : Re: Oil Hose
bend on the pump.
Alan
G-OBJT
Hi All,
Martin Tuck
N152MT
Wichita, KS
Max8992
Europa XS #560 F-PMLH
h&jeuropa
PostPosted: Tue Mar 03, 2015 5:08 am    Post subject: Re: Oil Hose Reply with quote
Martin,
You need a AN8-M14.5 adaptor. The old Rotax PN was 956641 but it doesnt appear in the parts list any longer.
You can buy them at lots of places. I often use Summit Racing for AN fittings. The page with the adaptor is
http://www.summitracing.com/search/part-type/an-to-metric-adapter-fittings/fitting-size-2/14mm-x-1-5/fitting-size-1/minus-8-an?N=4294920733%2B4294920642%2B4294947250&SortBy=Default&SortOrder=Default
You will also need a 90 deg hose end and I purchased Aeroquip FNC0820 hose for this. Works fine.
Jim
mau11(at)orange.fr
PostPosted: Tue Mar 03, 2015 12:21 pm    Post subject: Oil Hose Reply with quote
One very good solution for the oil hose is "Parker Push-lok 836" 1/2 "
colour blue 150°C max
Michel AUVRAY
Le 03/03/2015 05:59, Martin Tuck a écrit :
Hi All,
UK.
Martin Tuck
N152MT
Wichita, KS
paul.the.aviator(at)gmail
PostPosted: Tue Mar 03, 2015 2:08 pm    Post subject: Oil Hose Reply with quote
Hello Everyone,
Although slightly off topic, I did go down the route of replacing all of my hoses with AN fittings and very flexible steel braided hose from Pegasus Racing. Frans did the same but he used the Kevlar version of the hose which is even more flexible.
I had to TIG weld on some fittings onto my oil tank and make a banjo for the sump, although I believe there is a Rotax part for this.
It's an expensive exercise, it cost me about $500 at the time, but I no longer have to be concerned about hoses chaffing or getting too hot.
I have attached the bill of materials and the part numbers are from the Pegasus catalogue
Paul
Europa_AN_Fitting_BOM.XLSX
 Filename:  Europa_AN_Fitting_BOM.XLSX
 Filesize:  11.58 KB
 Downloaded:  505 Time(s)
MJKTuck(at)cs.com
PostPosted: Tue Mar 03, 2015 6:35 pm    Post subject: Oil Hose Reply with quote
Thank you all who responded for taking the time to provide some very
helpful information.
Martin Tuck
On 3/3/2015 4:06 PM, Paul McAllister wrote:
Hello Everyone,
Paul
