kearney
Posted: Sun Mar 08, 2015 7:00 am Post subject: Hot EGT on # 1 Cylinder |
Hi
I have been putting hours on my new engine and in the process have noticed something that may or may not be odd. While taxing I try to lean the engine to keep the plugs from fouling. I have noticed that the #1 cylinder goes hot far faster than the others.
Fr example, when leaning on the ground yesterday cyls #2-6 were +/- 1050 F while number 1 spiked quickly to 1385F. I simply en-richened somewhat to bring it down.
I am perplexed as to why CYL # 1 would react tgis way.
In the air I don't see this type of behavior, only on the ground.
Any wisdom from the intelligentsia? Do I even care about this?
Cheers
Les
rleffler
Posted: Sun Mar 08, 2015 7:22 am Post subject: Hot EGT on # 1 Cylinder |
What are your cht's? I wouldn't worry about egt temps on the ground.
| Quote: | On Mar 8, 2015, at 11:00 AM, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=439153#439153
_________________ Bob Leffler
N410BL - Phase I
cooprv7(at)yahoo.com Guest
Posted: Sun Mar 08, 2015 7:32 am Post subject: Hot EGT on # 1 Cylinder |
Les,
Many people have experienced hotter temps on the front two cylinders due to the design of the dam in front being too large and after cutting it back the problem is solved. Seems like more of an issue in the air, but could be impacting you as well. Might be leaning a bit too much on taxi as well, just a thought. Might need to go for a slightly larger injector on #1 as well, but your in-flight numbers would be what really drives that change.
Enjoy your testing!
Marcus
| Quote: | On Mar 8, 2015, at 12:00 PM, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
kearney
Posted: Sun Mar 08, 2015 7:42 am Post subject: Re: Hot EGT on # 1 Cylinder |
Rob / Marcus
Thanks for the note. My CHTs, are fine, including in flight. I used silicon to seal the baffles and have followed the list advice as to how to keep the front cyls (#1 & 2) cool.
My issue is strictly to do with taxing. Perhaps I am being too aggressive with my ground leaning,
Cheers
Les
Posted: Sun Mar 08, 2015 8:16 am Post subject: Hot EGT on # 1 Cylinder |
Yep - same issue with my #3 cylinder.
After balancing the cylinder fuel injectors, all cylinders reach peak EGT
within 0.1 GPH fuel flow (standard cruise conditions, 2350 RPM and MP 23" or
whatever I can get at altitude). On the ground when I lean for taxi (just
enough gas to keep the engine running) all EGTs climb but #3 climbs more.
I talked to Air Flow Performance on this and he asked me to do a high power
lean run to verify the cylinders still peak at about the same fuel flow -
they do. He ask me to do this to eliminate any issue with the spider (e.g.
spring/flow/clog).
Note - CHTs while leaning on the ground really don't change much.
So - if not done already recommend you proceed with the in flight injector
balancing, then take a look at where you are after that. Injectors of
various sizes are available from Air Flow Performance for $21 each. For
reference, the standard injector in a Vans IO-540 is 0.028". For my engine,
this is the injector set up I ended up with (your engine will be different):
#1 (.028) #2 (.029) #3 (.027) #4 (.027) #5 (.029) #6
(.0275)
Before balance I had a 0.8 GPH spread between the cylinders for fuel flow at
peak EGT. Lean of peak operation yielded a very rough engine. Now standard
cruise is 20-30 degrees LOP, 11.5 GPH and CHTs are 30 degrees cooler than
when ROP.
Carl
jump2(at)sbcglobal.net Guest
Posted: Sun Mar 08, 2015 8:23 am Post subject: Hot EGT on # 1 Cylinder |
Have you checked for intake leak on that cyl. Little leak at idle will show up as high temp since it'll leaned fuel mixture out and at full power it is small enough you might not notice it. What's your mp at idle? If it's around 15" -17" you prob. have a leak.
Just my thoughts and as we know it's not worth much.
Patrick Thyssen
| Quote: | On Mar 8, 2015, at 10:42 AM, kearney <kearney(at)shaw.ca> wrote:
Rob / Marcus
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=439160#439160
amekler
Posted: Sun Mar 08, 2015 8:25 am Post subject: Hot EGT on # 1 Cylinder |
You might try cleaning that injector or swapping it with the richest injector
Alan
| Quote: | On Mar 8, 2015, at 11:27 AM, Marcus Cooper <cooprv7(at)yahoo.com> wrote:
Les,
Enjoy your testing!
Marcus
> Hi
> Cheers
> Les
Bob Turner
Posted: Sun Mar 08, 2015 8:29 am Post subject: Re: Hot EGT on # 1 Cylinder |
check the intake gaskets on #1 for any sign of leaks. Do you see this behavior in the air at low throttle settings? At low MP there is a bigger differential between outside air presure and MP making leaks more obvious.
_________________ Bob Turner
RV-10 QB |
Tim Olson
Posted: Sun Mar 08, 2015 8:34 am Post subject: Hot EGT on # 1 Cylinder |
One note:
There is no such thing as leaning too aggressively on the ground for taxi. You SHOULD be leaning it SO FAR that if you try to get more than 1500-1800 RPM the engine stumbles and shudders and wants to die. That way you cannot possibly take off without going rich, and you are not leaving extra unburned fuel to foul the plugs and cylinders.
Rob / Marcus
Cheers
Les
kearney
Posted: Sun Mar 08, 2015 8:48 am Post subject: Re: Hot EGT on # 1 Cylinder |
Hi Carl
I have done the GAMI test. If I am interpreting the data correctly, my front two cyls peak at a FF of .5 & .7 GPH sooner than the remaining 4 which all peak within .1 GPH of each other. I think I'll give AFP a call and discuss.
I was wondering if I should consider GAM injectors but if I can get the same result from AFP injectors at a fraction of the cost, that would be much, much better.
Cheers
Les
| carl.froehlich(at)verizon wrote: | Yep - same issue with my #3 cylinder.
spring/flow/clog).
(.0275)
when ROP.
Carl
kearney
Posted: Sun Mar 08, 2015 8:51 am Post subject: Re: Hot EGT on # 1 Cylinder |
Hi Alan
I should have mentioned that I have done both already with no change. I also plan to confirm the EGT distance from the valve as well as swap probes t see if it is a probe variance.
Cheers
Les
| amekler wrote: | You might try cleaning that injector or swapping it with the richest injector
Alan
| Quote: | On Mar 8, 2015, at 11:27 AM, Marcus Cooper <cooprv7> wrote:
Les,
Enjoy your testing!
Marcus
> On Mar 8, 2015, at 12:00 PM, kearney <kearney> wrote:
> Hi
> Cheers
> Les
Posted: Sun Mar 08, 2015 9:21 am Post subject: Hot EGT on # 1 Cylinder |
If a cylinder peaks early it is not getting enough fuel compared with the
other cylinders. So you can either put a larger nozzle in #1 and #2, or
leave them at 0.028 and put smaller ones in your other cylinders (like
0.027").
If you are striving for around 12 GPH in cruise, then I suspect AFP will
recommend going smaller in cylinders 3, 4, 5 and 6. Keep in mind this is an
iterative process. Change the injectors in the one or two cylinders that
are the most out, do another data run, repeat. It took me three runs. I
have the SkyView system so it's automatic data collection really made this
easy. AFP makes injectors in wide range, typical increment is 0.0005"
While I have no issue with GAMI injectors, I never saw the value in the very
high price when the same result is achievable using $21 AFP nozzles.
Carl
rv10flyer(at)live.com Guest
Posted: Sun Mar 08, 2015 11:46 am Post subject: Hot EGT on # 1 Cylinder |
Les
I had the same issues. Thanks to Don McDonald, initially and David Brown (GAMI instructor) and his knowledge he helped interpret my settings and I was able to get everything to .3 from richest to leanest.
What I discovered is
You change one injector the others move around as well.
You cut an air dam and the LOP goes out the window.
I always had a hot #6 cyl and my #1 ran second hottest. When I cut down the dam in front of #1, temps went down across the board. When I got the LOP final set the temps all run much cooler.
My suggestion is talk to Don and hear his suggestions, probably tell you to get .0270 or ..0275 for the four and see how everything balances after that change.
It's worth the effort!
Pascal
| Quote: | On Mar 8, 2015, at 9:54 AM, kearney <kearney(at)shaw.ca> wrote:
Hi Carl
Cheers
Les
> spring/flow/clog).
> (.0275)
> when ROP.
> Carl
http://forums.matronics.com/viewtopic.php?p=439167#439167
taildragon(at)msn.com Guest
Posted: Sun Mar 08, 2015 12:08 pm Post subject: Hot EGT on # 1 Cylinder |
I'll go with Patrick on this one. I had high EGT on #4 on an idling brand new factory fresh IO-540! Turned out to be an "out of round" intake manifold so that the hose was not sealing completely. We found it by spraying with a light mist bottle while at idle and noticing the EGT change. Once we rounded out the manifold with a rounding plug, seal was complete and all was fine.
Roger Standley
N291RV
| Quote: | From: jump2(at)sbcglobal.net
Subject: Re: Re: Hot EGT on # 1 Cylinder
Date: Sun, 8 Mar 2015 11:16:17 -0500
--> RV10-List message posted by: Patrick Thyssen <jump2(at)sbcglobal.net>
Patrick Thyssen
> --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca>
> Rob / Marcus
> Cheers
> Les
Kellym
Posted: Sun Mar 08, 2015 12:31 pm Post subject: Hot EGT on # 1 Cylinder |
I agree with the possibility of small leak as a cause. The other
possibility, but likely to show up at all power settings is a single
spark plug firing intermittently or not at all.
Soap bubbles is one method. Another now being used in auto industry is a
smoke generator that floods the manifold with smoke under slight
pressure and you look for any escaping. Supposed to be more sensitive to
small leaks than soap bubbles.
On 3/8/2015 1:05 PM, Roger Standley wrote:
| Quote: | I'll go with Patrick on this one. I had high EGT on #4 on an idling
Roger Standley
N291RV
> To: rv10-list(at)matronics.com
> Patrick Thyssen
> Sent from my iPad
> > Rob / Marcus
> > Cheers
> > Les
> > Read this topic online here:
KCHD |
Posted: Sun Mar 08, 2015 2:25 pm Post subject: Hot EGT on # 1 Cylinder |
Intake leaks can be easier to spot if you take a clean (read that word again) shop vac and hook it up to blow air into the intake and spray soapy water over the intake system. You can put rags around the hose to seal it a little. Much easier to spot bubbles than changes in EGT.
Linn
On 3/8/2015 4:05 PM, Roger Standley wrote:
[quote] I'll go with Patrick on this one. I had high EGT on #4 on an idling brand new factory fresh IO-540! Turned out to be an "out of round" intake manifold so that the hose was not sealing completely. We found it by spraying with a light mist bottle while at idle and noticing the EGT change. Once we rounded out the manifold with a rounding plug, seal was complete and all was fine.
Roger Standley
N291RV
> From: jump2(at)sbcglobal.net (jump2(at)sbcglobal.net)
> To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
> --> RV10-List message posted by: Patrick Thyssen <jump2(at)sbcglobal.net> (jump2(at)sbcglobal.net)
> Patrick Thyssen
> Sent from my iPad
> > On Mar 8, 2015, at 10:42 AM, kearney <kearney(at)shaw.ca> (kearney(at)shaw.ca) wrote:
> > --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca> (kearney(at)shaw.ca)
> > Rob / Marcus
> > Cheers
> > Les
amekler
Posted: Sun Mar 08, 2015 3:17 pm Post subject: Hot EGT on # 1 Cylinder |
Les,I also used Don Rivera at AFP after unsuccessfully trying GAMIs. I even send my Spider back to Mattituck for recalibration.
Don had me start with his injectors.I emailed him the flight data and after 3 flights with changing injectors have a .3 gallon spread and it runs fine LOP.
I suggest to go to his web site and collect the flight data. He is great to work with.
Also helpful is https://www.savvyanalysis.com/ to look at your data.
good luck
Alan
| Quote: | On Mar 8, 2015, at 12:51 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>Hi AlanI should have mentioned that I have done both already with no change. I also plan to confirm the EGT distance from the valve as well as swap probes t see if it is a probe variance.CheersLesamekler wrote: | Quote: | You might try cleaning that injector or swapping it with the richest injectorAlanSent from my iPhone | Quote: | On Mar 8, 2015, at 11:27 AM, Marcus Cooper wrote: Les, Many people have experienced hotter temps on the front two cylinders due to the design of the dam in front being too large and after cutting it back the problem is solved. Seems like more of an issue in the air, but could be impacting you as well. Might be leaning a bit too much on taxi as well, just a thought. Might need to go for a slightly larger injector on #1 as well, but your in-flight numbers would be what really drives that change. Enjoy your testing! Marcus | Quote: | | On Mar 8, 2015, at 12:00 PM, kearney wrote:HiI have been putting hours on my new engine and in the process have noticed something that may or may not be odd. While taxing I try to lean the engine to keep the plugs from fouling. I have noticed that the #1 cylinder goes hot far faster than the others.Fr example, when leaning on the ground yesterday cyls #2-6 were +/- 1050 F while number 1 spiked quickly to 1385F. I simply en-richened somewhat to bring it down.I am perplexed as to why CYL # 1 would react tgis way. In the air I don't see this type of behavior, only on the ground.Any wisdom from the intelligentsia? Do I even care about this?CheersLesRead this topic online here:http://forums.matronics.com/viewtopic.php?p=439153#439153 |
| Read this topic online here:http://forums.matronics.com/viewtopic.php?p=439168#439168
kearney
Posted: Sun Mar 08, 2015 4:28 pm Post subject: Hot EGT on # 1 Cylinder |
Hi Alan
I have AFP injectors / spider as well. I will give them a call after I confirm that I don't have an induction leak.I suspect that given that cyl#1 peaks first in flight, it just may be a flow issue but I need to confirm.
Cheers
Les
Sent: Sunday, March 8, 2015 5:14:01 PM
good luck
Alan
