Water Coolant Sensor location?
MJKTuck(at)cs.com
PostPosted: Thu Mar 19, 2015 6:06 pm    Post subject: Water Coolant Sensor location? Reply with quote
Hi guys,
Where do you think I should put the EIS water/coolant temperature sensor?
I'm thinking in the long hose that runs from the radiator to the
'distributor pot' on top of the engine.
Martin Tuck
N152MT
rlborger(at)mac.com
PostPosted: Thu Mar 19, 2015 6:19 pm    Post subject: Water Coolant Sensor location? Reply with quote
Martin,
Yes, just after the coolant exits the “pot� on the way to the radiator.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
[quote]On Mar 19, 2015, at 8:05 PM, Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)> wrote:
--> Europa-List message posted by: Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)>Hi guys,Where do you think I should put the EIS water/coolant temperature sensor?I'm thinking in the long hose that runs from the radiator to the 'distributor pot' on top of the engine.Regards,Martin TuckN152MT
MJKTuck(at)cs.com
PostPosted: Thu Mar 19, 2015 7:22 pm    Post subject: Water Coolant Sensor location? Reply with quote
Thanks Bob!
Martin
On 3/19/2015 9:18 PM, Robert Borger wrote:
[quote] Martin,
Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX  76208-5331 Cel: 817-992-1117 rlborger(at)mac.com (rlborger(at)mac.com)
--> Europa-List message posted by: Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)> Hi guys, Where do you think I should put the EIS water/coolant temperature sensor? I'm thinking in the long hose that runs from the radiator to the 'distributor pot' on top of the engine. Regards, Martin Tuck N152MT
christoph.both(at)acadiau
PostPosted: Fri Mar 20, 2015 6:00 am    Post subject: Water Coolant Sensor location? Reply with quote
I placed mine right after the cylinder coolant outlet as I want to sense the hottest spot.
Christoph
#223
On Mar 19, 2015, at 23:06, "Martin Tuck" <MJKTuck(at)cs.com> wrote:
Hi guys,
Martin Tuck
N152MT
dpark748(at)icloud.com
PostPosted: Fri Mar 20, 2015 8:11 am    Post subject: Water Coolant Sensor location? Reply with quote
Chris,
I did the same.
Dave G-LDVO
On 20 Mar 2015, at 13:59, Christoph Both <christoph.both(at)acadiau.ca> wrote:
Christoph
#223
> Hi guys,
> Regards,
> Martin Tuck
> N152MT
paul.the.aviator(at)gmail
PostPosted: Fri Mar 20, 2015 12:23 pm    Post subject: Water Coolant Sensor location? Reply with quote
I removed my coolant tank and TIG welded on some 10g aluminum, cut a thread
and installed the sensor. It sounds like a lot of messing around but it
isn't really and it's in the ideal place.
Installing a T means another connection in the coolant system along with
another failure point.
Remi Guerner
PostPosted: Sat Mar 21, 2015 1:31 am    Post subject: Re: Water Coolant Sensor location? Reply with quote
In spite of what Rotax say in their Manuals, I do not think that monitoring coolant temperature is necessary. This is why:
1. The coolant is heated by the cylinder heads. So obviously coolant temperature is always below cylinder head temperature.
2. Conventional water based coolant boils at 120°C at the 1.2 bar pressure, at sea level.
3. Anytime the hottest cylinder CHT exceeds 120°C, there will be at least some local boiling.
3.1. Then, if the engine is running at cruise RPM or more, the water pump insures a good flow through the cylinder heads, the bubbles are pushed downstream to the cooler and condense, so there is no boiling over.
3.2. If the engine is at idle on the ground, while you are waiting for your take off clearance, then it will boil over. Moreover, as soon as CHT reaches 110°C, you must either shut down the engine or take off quickly. If you wait a few more minutes and let the CHT reach 115°C, then the only choice is to take off immediately. Then the CHT will decrease instantly. If you shut down at this point, then the heat transferred from the hot engine to the coolant will make it to exceed its boiling point and you are facing a big mess.
So the only advantage of monitoring the coolant temperature would be to allow the CHT to slightly exceed 120°C, for example during a full power climb in very hot conditions, while the coolant temp would stay slightly below 120°C. It seems to me this is a very marginal and risky advantage.
So in my opinion, monitoring the CHT of the hottest cylinder and considering the redline is 110°C on the ground and 120°C in flight is good enough. This is especially true on the Europa where cooling is very good in flight but very marginal on the ground.
Remi Guerner
F-PGKL, XS Monowheel, 912ULS, 1195 hours
ward.t(at)xtra.co.nz
PostPosted: Sat Mar 21, 2015 3:39 pm    Post subject: Water Coolant Sensor location? Reply with quote
Absolutely agree with you Remi.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
2. Conventional water based coolant boils at 120�‹C at the 1.2 bar pressure, at sea level.
3. Anytime the hottest cylinder CHT exceeds 120�‹C, there will be at least some local boiling.
3.2. If the engine is at idle on the ground, while you are waiting for your take off clearance, then it will boil over. Moreover, as soon as CHT reaches 110�‹C, you must either shut down the engine or take off quickly. If you wait a few more minutes and let the CHT reach 115�‹C, then the only choice is to take off immediately. Then the CHT will decrease instantly. If you shut down at this point, then the heat transferred from the hot engine to the coolant will make it to exceed its boiling point and you are facing a big mess.
So the only advantage of monitoring the coolant temperature would be to allow the CHT to slightly exceed 120�‹C, for example during a full power climb in very hot conditions, while the coolant temp would stay slightly below 120�‹C. It seems to me this is a very marginal and risky advantage.
So in my opinion, monitoring the CHT of the hottest cylinder and considering the redline is 110�‹C on the ground and 120�‹C in flight is good enough. This is especially true on the Europa where cooling is very good in flight but very marginal on the ground.
Remi Guerner
http://forums.matronics.com/viewtopic.php?p=439699#439699
MJKTuck(at)cs.com
PostPosted: Sat Mar 21, 2015 3:48 pm    Post subject: Water Coolant Sensor location? Reply with quote
I have done without a coolant temp for years so I'm inclined to agree. I'm also tired of looking at at a row of blanks for coolant temp on my EIS. Just looking to get a reading on the display.
Martin
Sent from my iPad
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
> Remi Guerner
gsessare(at)hotmail.com
PostPosted: Thu Mar 26, 2015 5:09 am    Post subject: Water Coolant Sensor location? Reply with quote
hello everybody,
somebody knows how is the procces to leave this list?
regards
[quote] From: ward.t(at)xtra.co.nz
Subject: Re: Re: Water Coolant Sensor location?
Date: Sun, 22 Mar 2015 12:38:34 +1300
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
