max8992
Posted: Sat Mar 21, 2015 11:42 pm Post subject: water drain |
Hi there All,
Who uses water drain? Who as ever seen water in the fuel there (I use Mogas only)?
Cheers,
Max Cointe
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 540 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1660 heures
_________________ Max8992
Europa XS #560 F-PMLH |
stabelvej9(at)gmail.com Guest
Posted: Sat Mar 21, 2015 11:51 pm Post subject: water drain |
Hi Max
I fly on mo-gas and use water-drain - never seen a drop of water.
I always leave the ac with full tank.
AC parked in hangar during the summer, and in my isolated shop from November to April.
Regards Gert
Gert Dalgaard,
Denmark
OY-GDS
Europa Mono/914/750 hrs.
| Quote: | Den 22/03/2015 kl. 08.41 skrev Max Cointe (Free) <mcointe(at)free.fr>:
Hi there All,
Cheers,
Max Cointe
Posted: Sun Mar 22, 2015 2:11 am Post subject: water drain |
Have never seen any water in 13 years, even though I do not regularly fill tank before putting plane away. Regards, David Joyce, GXSDJ
On 2015-03-22 07:41, Max Cointe (Free) wrote: [quote] | Quote: | --> Europa-List message posted by: "Max Cointe (Free)" <mcointe(at)free.fr (mcointe(at)free.fr)>
Hi there All,
Cheers,
Max Cointe
F-PLDJ Dyn'Aéro MCR 4S
ics.com
.matronics.com/contribution
| [b]
ptag.dev(at)talktalk.net Guest
Posted: Sun Mar 22, 2015 3:22 am Post subject: water drain |
Hi all !
I had an incident of substantial ingress of water once while parked overnight at Zell Am See in torrential down pour most of the night.
I have adjusted the “pinch” on the filler “o” Ring and mostly tape up the filler cap if left outside ever. The aircraft is always kept in it’s covered trailer and I try to fly exclusively on Mogas but don’t leave it full but I have water drains to both sides of the tank ALSO Mini Andair filters on both fuel flow lines.. Of course everyone will remember my misfortune of a restriction at the finger filters once, at which time Neville Eyre suggested “I shave the dog” ! but the dog has long gone and I have “improved the tank finger filter arrangements” . However I have also in the past discovered some contamination in the thimble filters in the Electric Pumps ( the removal of these for inspection requires extreme care , can only be repaired by complete replacement of the Pumps !) Hope I’m not tempting providence by writing all this !
Bob Harrison G-PTAG. 914 Rotax.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of davidjoyce(at)doctors.org.uk
Sent: 22 March 2015 10:11
Subject: Re: water drain
On 2015-03-22 07:41, Max Cointe (Free) wrote: | Quote: | | Quote: | | --> Europa-List message posted by: "Max Cointe (Free)" <mcointe(at)free.fr (mcointe(at)free.fr)> Hi there All, Who uses water drain? Who as ever seen water in the fuel there (I use Mogas only)? Cheers,Max CointeF-PMLH Europa XS_TriGearKit #560-2003 912ULS/AirmasterAP332 540 hours | 0123456789012Hi there All, | 34567890123456789 | Quote: | | Who uses water drain? Who as ever seen water in the fuel there (I use Mogas only)? | 0
rlborger(at)mac.com Guest
Posted: Sun Mar 22, 2015 5:09 am Post subject: water drain |
Max,
Fly only AvGas. No drains. Have gascolator before pump. No inline filters. Keep the tank full whenever possible. Use a cover if I ever have to park outside when traveling.
Have never seen evidence water in the tank.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
[quote]On Mar 22, 2015, at 1:41 AM, Max Cointe (Free) <mcointe(at)free.fr (mcointe(at)free.fr)> wrote:
--> Europa-List message posted by: "Max Cointe (Free)" <mcointe(at)free.fr (mcointe(at)free.fr)>Hi there All,Who uses water drain? Who as ever seen water in the fuel there (I use Mogas only)?Cheers,Max CointeF-PMLH Europa XS_TriGearKit #560-2003 912ULS/AirmasterAP332 540 hoursF-PLDJ Dyn’Aéro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1660 heures
dpark748(at)icloud.com Guest
Posted: Sun Mar 22, 2015 9:10 am Post subject: water drain |
Use Mogas occasional Avgas, never seen water.
Dave G-LDVO
Sent from my iPad
| Quote: | On 22 Mar 2015, at 07:41, Max Cointe (Free) <mcointe(at)free.fr> wrote:
Hi there All,
Cheers,
Max Cointe
ward.t(at)xtra.co.nz Guest
Posted: Sun Mar 22, 2015 10:51 am Post subject: water drain |
Hi
Same, use Mogas occasional Avgas, never seen water.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
| Quote: | On 23/03/2015, at 6:09 am, david park <dpark748(at)icloud.com> wrote:
grahamhall123(at)gmail.co Guest
Posted: Sun Mar 22, 2015 11:57 am Post subject: water drain |
Since getting my ppl in the late 80's I have always checked fuel drains as part of pre-flight, even when pushed to get going on business trips. On one occasion one tank of my 182 was clear fluid which did not smell like fuel and did not evaporate. Transpired I had about 2 liters rainwater in one tank. I will always check water drains- it only takes a minute and from my own experience is a minute well spent. 'to fail to look is to look to fail'.
On Mar 22, 2015, at 7:41 AM, "Max Cointe (Free)" <mcointe(at)free.fr> wrote:
Hi there All,
Cheers,
Max Cointe
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Sun Mar 22, 2015 12:32 pm Post subject: Re: water drain |
I had a small number of occasions when I found a few drops of water in my mogas. My aircraft was parked outside for several years and had Jaxida covers. But the fabric got old and needed to be washed and treated with water-proofing liquid more frequently.
Rarely after heavy prolonged rain storms, I would find a few drops in the fuel sample. The cap and 'O' ring were tight enough, but I guessed that the fabric of the covers in contact with the tank breather tube was acting like a wick to convey water into the breather. When I taped plastic over the tube before putting on the cover, there was no water ingress.
klinefelter.kevin(at)gmai Guest
Posted: Sun Mar 22, 2015 1:13 pm Post subject: water drain |
Me too, almost all Mogas (with up to 10% ethanol) and never seen water.
| Quote: | On Mar 22, 2015, at 11:50 AM, Timward <ward.t(at)xtra.co.nz> wrote:
Hi
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
ken carp
Joined: 31 Oct 2008 Posts: 29 Location: Knoxville, TN
Posted: Sun Mar 22, 2015 2:01 pm Post subject: water drain |
Never in twelve years found water in Europa, 100LL or Mogas. Did find water in 182 after it left out in rain with original cap not tight. Went to Monarch caps and no further water but I still check if any plane been outside in rain. Fueling at strange fields will get you water as happened to me twice.
Sent from my iPad
Ken Carpenter
| Quote: | On Mar 22, 2015, at 3:56 PM, Grahamhall123(at)gmail.com <grahamhall123(at)gmail.com> wrote:
> Hi there All,
> Cheers,
> Max Cointe
_________________ ken carpenter |
nigel_graham(at)m-tecque. Guest
Posted: Mon Mar 23, 2015 12:45 am Post subject: water drain |
And the reason for that is probably there in that sentence.
The more ethanol in your fuel, the less likely you you will ever see
water at the drains.
Ethanol readily attaches itself to water meaning that any water
contamination is distributed throughout the fuel. Gone are the days when
it sat conveniently at the bottom of the tank waiting to be drained.
The truth is that there is probably already water in your fuel before
you ever put it into your aircraft.
Water is notoriously difficult to detect and even harder to quantify.
Fuel distribution companies dip their storage tanks with a crude
dipstick coated with a water sensitive paste that changes colour when
water is detected. More modern float detectors (carefully weighted to
float on water, but under the fuel) used in bulk storage tanks work to a
degree, but the non-predictable way that water distributes itself
throughout the fuel means that the indication is little better.
There is no pressing desire by these companies to improve the situation
since there is a healthy profit to be made by selling water at fuel
prices, (a trick that the poultry and pork industries learned many years
ago).
My only advice would be that if you ever do drain a significant quantity
of water from a tank known to contain ethanol fuel, discard the entire
contents as the water will still be attached to the ethanol that was
added to raise the octane rating and the remaining fuel could seriously
damage your engine.
Nigel
On 22/03/2015 21:13, Kevin Klinefelter wrote:
> Hi
> Tim
> Tim Ward
> 12 Waiwetu Street
> Fendalton,
> Christchurch, 8052
> New Zealand.
> Ph 64 3 3515166
> Mob 0210640221
Remi Guerner
Posted: Mon Mar 23, 2015 1:20 am Post subject: Re: water drain |
I have found a lot of water in one wing tank of a rented Robin DR400 after parking one night under heavy rain. It was about 30 years ago at Sandown, Isle of Wight. I would have been in trouble if I had taken off on that tank without prior draining. Since I fly my Europa (13 years and more than 1100 hours flown) I never found water while draining the tank using the optional drains. I never found water in the gascolator either. But I find drops of water in the carb bowls occasionally. So I keep draining.
In my opinion, the drains as designed in factory Mod 33, are not very effective because the water has first to overcome gravity to have a chance to get out and the volume trapped inside the hose between the bottom of the tank and the drain is way too big. I made my own mod to the mod using 4mm hose instead of 8mm. This reduces the trapped volume by 75%, but I still have some doubt about the effectivity of the system.
Remi Guerner
F-PGKL
max8992
Posted: Mon Mar 23, 2015 1:47 am Post subject: water drain |
Thks to each and everyone who took time to answer. Rémi (how are you doing?)
you've stolen my words! I'm currently replacing all the pipes and no
applying Mod 33 will save 6 connections (6 additional risks of leak) and one
meter long of pipe for a very contestable result...
Max Cointe
mcointe(at)free.fr
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de Remi Guerner
Envoyé : lundi 23 mars 2015 10:21
À : europa-list(at)matronics.com
Objet : Re: water drain
--> <air.guerner(at)orange.fr>
Remi Guerner
F-PGKL
http://forums.matronics.com/viewtopic.php?p=439756#439756
Posted: Mon Mar 23, 2015 4:12 am Post subject: water drain |
Well stated Nigel. That's why I made sure to mention ethanol.
I perform the test for ethanol on fuel I buy periodically, where you add a measured amount of water to a sampler, shake it up and the water level increases with the absorption of the ethanol.
I sure wish they didn't put that crap in fuel.
My Monowheel is based in eastern California (4100' desert climate) so moisture is not typically a condensation problem at home base. But I'm going to be heading to Florida for Sun&Fun soon !
Kevin
914/Airmaster
| Quote: | On Mar 23, 2015, at 1:44 AM, Nigel Graham <nigel_graham(at)m-tecque.co.uk> wrote:
The more ethanol in your fuel, the less likely you you will ever see water at the drains.
Ethanol readily attaches itself to water meaning that any water contamination is distributed throughout the fuel. Gone are the days when it sat conveniently at the bottom of the tank waiting to be drained.
The truth is that there is probably already water in your fuel before you ever put it into your aircraft.
Water is notoriously difficult to detect and even harder to quantify. Fuel distribution companies dip their storage tanks with a crude dipstick coated with a water sensitive paste that changes colour when water is detected. More modern float detectors (carefully weighted to float on water, but under the fuel) used in bulk storage tanks work to a degree, but the non-predictable way that water distributes itself throughout the fuel means that the indication is little better.
There is no pressing desire by these companies to improve the situation since there is a healthy profit to be made by selling water at fuel prices, (a trick that the poultry and pork industries learned many years ago).
My only advice would be that if you ever do drain a significant quantity of water from a tank known to contain ethanol fuel, discard the entire contents as the water will still be attached to the ethanol that was added to raise the octane rating and the remaining fuel could seriously damage your engine.
Nigel
>> Hi
>> Tim
>> Tim Ward
>> 12 Waiwetu Street
>> Fendalton,
>> Christchurch, 8052
>> New Zealand.
>> Ph 64 3 3515166
>> Mob 0210640221
Scudrunner
Posted: Mon Mar 23, 2015 9:36 am Post subject: Re: water drain |
I always refuel my Europa before my walk around and test for water at the end - allows time for any water to settle?. I also use a Mr Funnel water seperator funnel though. Fuel is mogas. I drain half a jam jar per side (perhaps it should be a full one?). Only recently (cold winter) have I seen a cloudy sample with "bubbles" that sink rather than float. Once settled, it was no more than half a teaspoon. I'm assuming that this was condensation in a 3/4 empty tank? (aircraft hangared).
Howard
Posted: Mon Mar 23, 2015 9:56 am Post subject: water drain |
Coulld be dilute water/alcohol which would sink?
Graham
Sent: Monday, 23 March 2015, 17:36
--> Europa-List message posted by: "Scudrunner" <howardbrooksster(at)gmail.com (howardbrooksster(at)gmail.com)>
Howard
http://forums.matronics.com/viewtopic.php?p=439782#439782
http://www.matronics.com/Navigator?Europa-Listhttp://forums.mat ; -->
