dennisfox(at)persona.ca Guest
Posted: Tue Mar 24, 2015 7:28 pm Post subject: Wheels and Brakes |
Hi Fred: my preference would be the Grove wheel with the ball bearings for the nose gear, I got the standard Matco with my kit and then had it retrofited with the ball bearings. The high seal drag and timken bearings in the matco wheel a to cause some problems when not adjusted exactly right for preload, preload is not an issue with ball bearings provided the internal spacer is correct dimension.
My kit had cleveland main wheels and brakes which I am using with no modification.
Sent: Tuesday, March 24, 2015 8:56 PM
To: Undisclosed recipients:
Subject: Wheels and Brakes
I have ordered the finishing kit for my 8A and am considering alternatives to Van's supplied Matco wheels and brakes. Are there opinions and user experiences out there that would favor Matco vs Cleveland vs Grove, or are they all similar quality?
fredh gull9914(at)aol.com (gull9914(at)aol.com)
RV-8A QB
href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
edwclg
Posted: Wed Mar 25, 2015 7:35 am Post subject: Wheels and Brakes |
I am also using Cleveland wheels and brakes on my 8. Have had no issues and have 585 hours and over 1100 landings.
Ed Clegg
On Tue, Mar 24, 2015 at 11:27 PM, Dennis Fox <dennisfox(at)persona.ca (dennisfox(at)persona.ca)> wrote:
[quote] Hi Fred: my preference would be the Grove wheel with the ball bearings for the nose gear, I got the standard Matco with my kit and then had it retrofited with the ball bearings. The high seal drag and timken bearings in the matco wheel a to cause some problems when not adjusted exactly right for preload, preload is not an issue with ball bearings provided the internal spacer is correct dimension.
RV-8A QB
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27647 Location: Toledo Washington (KTDO) USA
Posted: Wed Mar 25, 2015 8:10 am Post subject: Wheels and Brakes |
My RV-8 Version 1.0 came with Cleveland wheels and brakes and they worked fine. RV-8 Version 2.0 came with Matco wheels and brakes. While I haven't actually flown with the Matco's yet, I have to say they seem better built and more "manly". Time will tell.
Attached are a pair of pictures from my Cleveland installation and another pair of pictures from my Matco installation for comparison.
RV-8 #82880 N998RV "Ruby Vixen"
http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log
http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
RV-6 #20916 N360EM "The Flyer"
http://www.mattsrv6.com - Matt's RV-6 Revitalization Log
Status: 220+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Matt's Livermore Airport Live ATC Stream!
Check out the live ATC stream directly from my hangar at the Livermore
Airport. Includes both Tower and Ground transmissions. Archives too!
For entertainment purposes only. http://klvk.matronics.com
At 08:34 AM 3/25/2015 Wednesday, you wrote:
| Quote: | I am also using Cleveland wheels and brakes on my 8. Have had no issues and have 585 hours and over 1100 landings.
Ed Clegg
On Tue, Mar 24, 2015 at 11:27 PM, Dennis Fox <<mailto:dennisfox(at)persona.ca>dennisfox(at)persona.ca> wrote:
Â
Â
fredh <mailto:gull9914(at)aol.com>gull9914(at)aol.com
RV-8A QB
| Description: |
| Filesize: |
194.06 KB |
| Viewed: |
8427 Time(s) |
| Description: |
| Filesize: |
189.18 KB |
| Viewed: |
8427 Time(s) |
| Description: |
| Filesize: |
97.73 KB |
| Viewed: |
8427 Time(s) |
| Description: |
| Filesize: |
100.97 KB |
| Viewed: |
8427 Time(s) |
_________________ Matt Dralle
rotorheadrob(at)charter.n Guest
Posted: Wed Mar 25, 2015 8:40 am Post subject: Wheels and Brakes |
😎👍 Replaced the Matco brakes off my "used" -8A and replaced them with Grove's setup. Robbie Grove personally helped me install them while I was in San Diego doing fire standby. He has a lifetime of experimental AC. I am impressed with the smooth breaking and solid feel. Each wheel now has two Pistons pushing against the brake pad, the Matco's are single Pistons. When side by side, you can simply see the better quality and superior design. The -8A uses more braking action to maneuver on the ground than their brothers with the little wheel in back. They are a bit more $ but I decided they where worth it, but than again I'm not too bright😜,,,, good luck and enjoy flying your -8A. Over 700 hrs now with miles of lost taxing around various unfamiliar aerodromes. -Rotor 🚁💦🔥
On Mar 25, 2015, at 8:34 AM, edward Clegg <edwclg(at)gmail.com (edwclg(at)gmail.com)> wrote:
[quote]I am also using Cleveland wheels and brakes on my 8. Have had no issues and have 585 hours and over 1100 landings.
Ed Clegg
| Quote: | Hi Fred: my preference would be the Grove wheel with the ball bearings for the nose gear, I got the standard Matco with my kit and then had it retrofited with the ball bearings. The high seal drag and timken bearings in the matco wheel a to cause some problems when not adjusted exactly right for preload, preload is not an issue with ball bearings provided the internal spacer is correct dimension.
RV-8A QB
ist"">http://www.matronics.com/Navigator?RV8-List
//forums.matronics.com
