		Richard Pike
				 Posted: Mon Apr 06, 2015 2:20 pm    Post subject: Better than Seafoam? |
				Cleaning out the rings & ring lands on the 582, it's been a while, and the lower one was stuck on one side near the locator pin, both pistons. Scraped and scraped, looked pretty good, put the rings back in and was not real happy, Still sticking a little bit on that same side. Went to scrape some carbon off the underside of the head and think about it.
 Scraped a bit, and then just for the heck of it, shot the head with some PB Blaster. WOW! That stuff dissolves soft carbon like crazy. Let it sit for a while, wiped it off with a paper towel. Went online and researched it, saw some posts where other people had good results, but one post said to keep it away from seals, it can make them swell.
 Packed the base of the pistons with shop rags, drenched the rings and piston lands with the stuff, letting it sit overnight. Will post again tomorrow. But I did see dissolving carbon running down the sides of the pistons. That would seem to be a good sign.
 But unlike Seafoam, I really don't see putting this stuff in the gas tank.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
		rowedenny
				 Posted: Mon Apr 06, 2015 4:59 pm    Post subject: Better than Seafoam? |
				PB Blaster is the best liquid wrench I've ever used. Breaks loose unbelievably tough rusted bolts and even galled threads.
 Dennis "Skid" Rowe
 Mk3, Rotax 670,
 Leechburg, PA
  	  | Quote: | 	 		   On Apr 6, 2015, at 6:20 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
  Cleaning out the rings on the 582, it's been a while, and the lower one was stuck on one side near the locator pin, both pistons. Scraped and scraped, looked pretty good, put the rings back in and was not real happy, Still sticking a little bit on that same side. Went to scrape some carbon off the underside of the head and think about it.
  Richard Pike
  Kingsport, TN 3TN0
  There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.'
  http://forums.matronics.com/viewtopic.php?p=440341#440341
		George Alexander
				 Posted: Mon Apr 06, 2015 5:16 pm    Post subject: Re: Better than Seafoam? |
				Richard:
 Maybe you can convince the mfg to add wordage to the label, right alongside the statement about fixing leaky toilets.  8>)
 I agree with Dennis, it's good stuff.
  	  | rowedenny wrote: | 	 		  PB Blaster is the best liquid wrench I've ever used. Breaks loose unbelievably tough rusted bolts and even galled threads.
 Dennis "Skid" Rowe
  	  | Quote: | 	 		   On Apr 6, 2015, at 6:20 PM, Richard Pike <thegreybaron> wrote:
 . . . S N I P . . .
 . . . S N I P . . .
  Richard Pike
  Kingsport, TN 3TN0
  _________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
		zeprep251(at)aol.com Guest
				 Posted: Tue Apr 07, 2015 1:25 pm    Post subject: Better than Seafoam? |
				Had a chance to experiment on some old lawnmower engine cylinder heads
 Sea foam PB blaster carb cleaner. Not much gets after hard carbon
  	  | Quote: | 	 		   On Apr 6, 2015, at 8:59 PM, Dennis Rowe <rowedenny(at)windstream.net> wrote:
  Dennis "Skid" Rowe
  Mk3, Rotax 670,
  Leechburg, PA
 > Richard Pike
 > Kingsport, TN 3TN0
		Richard Pike
				 Posted: Wed Apr 08, 2015 5:29 am    Post subject: Re: Better than Seafoam? |
				Let it soak the rings & grooves overnight, helped a little. My conclusion: it works great on soft carbon, not as much on hard carbon, still better than nothing.
 OTOH, Seafoam only has one purpose, and if it doesn't clean the carbon off your pistons and rings, it is pointless. PB Blaster works great on loosening rusted stuff even if it doesn't clean the carbon off the rings as good as I wish.
Kingsport, TN 3TN0
		GeoB
				 Posted: Thu Apr 09, 2015 2:32 am    Post subject: Re: Better than Seafoam? |
				 	  | Richard Pike wrote: | 	 		  | Let it soak the rings & grooves overnight, helped a little. |
 Wonder if anyone uses oven cleaner?
  _________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
				 Posted: Thu Apr 09, 2015 2:49 am    Post subject: Better than Seafoam? |
				Oven cleaner?  I think that is a great idea!  Does anybody have an old piston, and the urge for an experiment?  The stuff is definitely designed to remove baked on carbon.
                                                   Bill Sullivan
 do not archive.
 On Thu, 4/9/15, GeoB <gab16(at)sbcglobal.net> wrote:
  Subject: Re: Better than Seafoam?
  Date: Thursday, April 9, 2015, 6:32 AM
  "GeoB" <gab16(at)sbcglobal.net>
  little.
  GeoB
  corporate sponsors"
  http://forums.matronics.com/viewtopic.php?p=440483#440483
  Forum -
     - MATRONICS WEB FORUMS -
  List Contribution Web Site -
                -Matt
  Dralle, List Admin.
		ceengland7(at)gmail.com Guest
				 Posted: Thu Apr 09, 2015 9:56 am    Post subject: Better than Seafoam? |
				On April 9, 2015 6:43:52 AM EDT, william sullivan <williamtsullivan(at)att.net> wrote:[quote] [quote]--> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net>  Oven cleaner?  I think that is a great idea!  Does anybody have an old piston, and the urge for an experiment?  The stuff is definitely designed to remove baked on carbon.                                                  Bill Sullivando not archive.On Thu, 4/9/15, GeoB <gab16(at)sbcglobal.net> wrote: Subject: Re: Better than Seafoam? To: kolb-list(at)matronics.com Date: Thursday, April 9, 2015, 6:32 AM  --> Kolb-List message posted by: "GeoB" <gab16(at)sbcglobal.net>   Richard Pike wrote: 	  | Quote: | 	 		  |  Let it soak the rings & grooves overnight, helped a | 	   little.   Wonder if anyone uses oven cleaner?[b]
  For rust, a 50-50 mix of acetone & ATF is pretty impressive (and inexpensive).
  Sent from my Android device with K-9 Mail. Please excuse my brevity.  [quote][b]
				 Posted: Thu Apr 09, 2015 11:45 am    Post subject: Better than Seafoam? |
				Just the opposite of Charlie E's less expensive "stuff" is Kroil by KANO Labs in Nashville, TN.  This stuff is expensive, but works better than anything I have tried over the years for loosening stuck stuff.
 They have an air tight guarantee to give you back your money if you, at any time, are dissatisfied with their product.
 Don't let the prices scare you.  It works well.
 http://www.kanolabs.com/penLub.html
 From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England
 Sent: Thursday, April 09, 2015 12:56 PM
 Subject: Re: Re: Better than Seafoam?
 On April 9, 2015 6:43:52 AM EDT, william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote: 	  | Quote: | 	 		  | --> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)>  Oven cleaner?  I think that is a great idea!  Does anybody have an old piston, and the urge for an experiment?  The stuff is definitely designed to remove baked on carbon.                                                  Bill Sullivando not archive.On Thu, 4/9/15, GeoB <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)> wrote: Subject: Re: Better than Seafoam? To: kolb-list(at)matronics.com (kolb-list(at)matronics.com) Date: Thursday, April 9, 2015, 6:32 AM  --> Kolb-List message posted by: "GeoB" <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)>   Richard Pike wrote: Let it soak the rings & grooves overnight, helped a little.   Wonder if anyone uses oven cleaner?<![if !supportLineBreakNewLine]><![endif]>For rust, a 50-50 mix of acetone & ATF is pretty impressive (and inexpensive).<![if !supportLineBreakNewLine]><![endif]><![if !supportLineBreakNewLine]><![endif]>Charlie<![if !supportLineBreakNewLine]><![endif]>-- <![if !supportLineBreakNewLine]><![endif]> | 	  01234567890123456789 	  | Quote: | 	 		  |  Let it soak the rings & grooves overnight, helped a | 	  0 	  | Quote: | 	 		  |  Let it soak the rings & grooves overnight, helped a | 	  1 	  | Quote: | 	 		  |  Let it soak the rings & grooves overnight, helped a | 	  2 	  | Quote: | 	 		  |  Let it soak the rings & grooves overnight, helped a | 	  3 	  | Quote: | 	 		  |  Let it soak the rings & grooves overnight, helped a | 	  4 	  | Quote: | 	 		  |  Let it soak the rings & grooves overnight, helped a | 	  5
  _________________ John Hauck
Titus, Alabama |
		crad238(at)suddenlink.net Guest
				 Posted: Thu Apr 09, 2015 2:51 pm    Post subject: Better than Seafoam? |
				I think oven cleaner contains caustic soda  ( lye).  It dissolves
 aluminum.  Very important to test first.  Could test on any piece of
 aluminum
      Carl Radcliffe
		Jim Baker
				 Posted: Thu Apr 09, 2015 3:55 pm    Post subject: Better than Seafoam? |
				For what it's worth. Machinists often have to deal with some nasty situations. At
 least this article has some numbers, not just preferences or claims. Saw this
 some time ago -
 ____________________________________________
 I read a post on another website that said that an April/May 2007 edition of
 Machinist's Workshop did a study on penetrating oils to see which was the best
 at freeing rusted hardware. The results are indicated below:
 Penetrating oil . Average breakaway load ..   Price per fluid ounce
 None ................. 516 pounds .
 WD-40 .............. 238 pounds ..                          $0.25
 PB Blaster ......... 214 pounds ..                          $0.35
 Liquid Wrench ... 127 pounds ..                          $0.21
 Kano Kroil ........ 106 pounds ..                            $0.75
 ATF-Acetone mix.. 53 pounds ..                          $0.10
 According to this, a 50/50 mixture of Acetone and ATF was the best. Also,
 someone mentioned that "CRC Freeze-Off Super Penetrant" was pretty good
 with stuck bolts as the freezing effect tends to crack rusted surfaces.
 _________________________________________________
 Secondary source -
 http://www.saturnfans.com/forums/showthread.php?t=168033
 To:	<kolb-list(at)matronics.com>
 Subject:	RE: Re: Better than Seafoam?
 Date sent:	Thu, 9 Apr 2015 14:44:43 -0500
 Send reply to:	kolb-list(at)matronics.com
        Oven cleaner?
       Bill Sullivan
      do not archive.
       little.
                - The Kolb-List Email Forum -
         --> http://www.matronics.com/Navigator?Kolb-List
         --> http://forums.matronics.com
        Thank you for your generous support!
       --> http://www.matronics.com/contribution
 Jim Baker
 Sayre, PA
 405.426.5377 cell
