Flying 52 without cowling
Bill1200
PostPosted: Sat Apr 11, 2015 2:54 pm    Post subject: Flying 52 without cowling Reply with quote
Just put on new engine, some adjustments left. Want to test fly it in the pattern without cowling, to facilitate work on the ground. Anyone have experience with this in regards to cylinder temps
wlannon(at)shaw.ca
PostPosted: Sat Apr 11, 2015 3:28 pm    Post subject: Flying 52 without cowling Reply with quote
Don't do that!
Any ground running of the engine without the cowling must be limited to idle
or very low power for a short period of time. Flight without the cowl may
well be suicidal.
The reason for this is simply that the cylinders cannot properly cool. Air
cooling depends on the cowl and cylinder baffle combination to force cooling
air under pressure to flow in close contact with the cylinder fins.
That worked for rotary engines and some early radials but without any
cylinder baffling.
Walt
migfighter42(at)gmail.com
PostPosted: Sat Apr 11, 2015 3:51 pm    Post subject: Flying 52 without cowling Reply with quote
Agreed, don't do it. Without the cowl, airflow is not properly contained/coltrolled. Aerodynamics are also different. I tried it once, made half a lap and was redline.
Don't do it.
Bill Culberson
Red Star Aero Services
<div>-------- Original message --------</div><div>From: Bill1200 <billdykes52(at)hotmail.com> </div><div>Date:04/11/2015 5:54 PM (GMT-06:00) </div><div>To: yak-list(at)matronics.com </div><div>Cc: </div><div>Subject: Yak-List: Flying 52 without cowling </div><div>
</div>
http://forums.matronics.com/viewtopic.php?p=440676#440676
Bill1200
PostPosted: Sat Apr 11, 2015 4:53 pm    Post subject: Re: Flying 52 without cowling Reply with quote
ok, thanks
Viperdoc
PostPosted: Sat Apr 11, 2015 6:51 pm    Post subject: Flying 52 without cowling Reply with quote
Danged! Why take that risk?! It's such a simple cowling to put and take off.
Don't do it. Your CHT's are going to be all over the place! Run it without the cowling then check it with the LASE temp gun. You will be totally confused by the numbers you see. Walt and Bill are correct.
Doc
Sent from my iPad
On Apr 11, 2015, at 6:50 PM, migfighter42 <migfighter42(at)gmail.com (migfighter42(at)gmail.com)> wrote:
[quote]Agreed, don't do it. Without the cowl, airflow is not properly contained/coltrolled. Aerodynamics are also different. I tried it once, made half a lap and was redline.
Don't do it.
Bill Culberson
From: Bill1200 <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)>
Cc:
Subject: Flying 52 without cowling
--> Yak-List message posted by: "Bill1200" <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)>
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž­8^a© ŠËD™¨¥Šî™K¶ŒjÚèž',.+-æ­º·¬5«â«h®Ú®Œ,zØ^™©ò.+-ºØ¥ŠØž²Ëœ…« ŠËTŸô®nÇ+Š›b¢p+r¯y'š­ÈC£ å¡§{ ¬®Œ,x(Z´P>-¢ÈZ­æ§vkœ†kœ†j+y¨kyøm¶Ÿÿà &jÚèž',r‰¿5«â«h­†¤.+-†Ûiÿü0Âf­®‰ârÇ(›óZ¾(¶ŠØjBâ²ßÚ0Ñ8ÒIaäT1$š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg›Šî寃çá¶Úýú+ºk&jÚèž',r‰¡¶Úýú+ºk&jÚèž',r‰¿h¸¬´*'¶¸›ºØ¨g›J+^N§“*.~Šò¢êàzw«¢ë,ºšh®Ó¶ÐëjY^.+-Ù¢¨kyøm¶Ÿÿà &jÚèž',r‰¿r‰í®&î¶*'†Ûiÿü0Âf­®‰ârÇ(›÷(žÚânëb¢Úý¿ß¢{¦·¿n‡rþf
Viperdoc
jackpot
PostPosted: Sun Apr 12, 2015 9:55 am    Post subject: Flying 52 without cowling Reply with quote
Don't fly it with cowl off. You will be causing all of our War Bird insurance rates to increase ????
Gary G.
On Apr 11, 2015, at 19:50, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
[quote]Danged! Why take that risk?! It's such a simple cowling to put and take off.
Doc
Sent from my iPad
Don't do it.
Bill Culberson
Cc:
"3D"courier" new,courier"="">[url=3D"http://www.matronics.com/Navigator?Yak-List"]http://www.matronics.com/Navigator?Yak-List[/url]
