rv6(at)earthlink.net Guest
Posted: Fri Jun 30, 2006 4:40 pm Post subject: RV10-List:Quick Build Wings Bottom skin |
To those that have completed the quick build wings,in which order did you
rivet the bottom skin on??? Did you start in the middle,or on what end??
John McMahon (RV6 863JJ)
coop85(at)bellsouth.net Guest
Posted: Fri Jun 30, 2006 7:02 pm Post subject: RV10-List:Quick Build Wings Bottom skin |
John,
I just did the left wing and have the right wing ready to go. I riveted
the center section directly in line with the outboard access hole first then
went outboard. I found I could rivet about halfway across each section
reaching above the rib (ie arm between the rib and skin by holding the skin
away from the wing) and then clecoed to the next rib and finished by
reaching in the holes in that rib.
Hope that helps, ask away if you have any questions.
Marcus
jhasbrouck(at)woh.rr.com Guest
Posted: Fri Jun 30, 2006 7:07 pm Post subject: RV10-List:Quick Build Wings Bottom skin |
John,
I did the slo'build wings but the bottom skins are the same. Followed
the sequence that is in the plans. Inboard skin first starting at the rear
spar about the middle as I recall. Take a look at the orientation of the
rib flanges and you'll see that the most inboard ones can be accessed from
the wing root. Outboard skin sequence per plans. Last three ribs outboard
can be reached with the skin curled back and through the holes in the
outboard ribs. I had help for the left wing but did the right wing myself.
Turned out great just took my time. Hope this helps....john
