millner(at)me.com Guest
Posted: Mon Apr 13, 2015 4:51 pm Post subject: OAT Probe Compatability |
On Apr 13, 2015, at 5:43 PM, Paul Millner <millner(at)icloud.com (millner(at)icloud.com)> wrote:
[quote]What color are the wires? If they're both red/white or red/yellow, likely yes.
On Apr 13, 2015, at 4:08 PM, bob noffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
| Quote: | just a long shot here. does anyone know if the oat probe for a dynon skyview is compatible with a grt mini? grt doesn't know and i wouldn't really expect they would. i have it in an rv 12 kit and i won't be using a skyview.
thanks for any info.
bob noffs
Kellym
Posted: Mon Apr 13, 2015 5:02 pm Post subject: OAT PROBE COMPATABILITY |
I assume you are building the RV-12 as an OBAM experimental and not as
an ELSA?
For those that don't know, you can not modify from the builder's kit
during construction of ELSA. It only becomes experimental and free to
mod after airworthiness certificate and the 5 hr phase one is flown off.
using a skyview.
bob noffs
KCHD |
bobnoffs
Joined: 04 Jul 2012 Posts: 137 Location: northern wi.
Posted: Mon Apr 13, 2015 5:46 pm Post subject: OAT PROBE COMPATABILITY |
that's true.
bob
On Mon, Apr 13, 2015 at 8:00 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote]--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
I assume you are building the RV-12 as an OBAM experimental and not as an ELSA?
For those that don't know, you can not modify from the builder's kit during construction of ELSA. It only becomes experimental and free to mod after airworthiness certificate and the 5 hr phase one is flown off.
bob noffs
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
Joined: 28 Mar 2008 Posts: 1972 Location: Riley TWP Michigan
Posted: Mon Apr 13, 2015 7:11 pm Post subject: Re: OAT Probe Compatability |
It is worth a try. According to the manuals of each brand, polarity of the two wires does not matter. If your Dynon probe has 3 wires, then use the yellow and blue, but not the red (insulate it).
_________________ Joe Gores |
Posted: Tue Apr 14, 2015 4:12 am Post subject: Re: OAT Probe Compatability |
This paper talks about thermistors.
http://ww1.microchip.com/downloads/en/AppNotes/00685b.pdf
If the GRT and Dynon probe thermistors have different temperature coefficients, then the displayed temperature will not be accurate. The accuracy can be checked by exposing the probe to known temperatures like ice water and ambient air.
Joe
Posted: Tue Apr 14, 2015 5:42 am Post subject: Re: OAT Probe Compatability |
| Quote: | | does anyone know if the oat probe for a dynon skyview is compatible with a grt mini? |
http://www.vansairforce.com/community/showpost.php?p=455620&postcount=3
Per Dynon Support: "Dynon's OAT's are a custom made part. It's a thermistor resistor between ground and the sense wire, with a 10K resistor from sense to +5V. The thermistor is 10Kohm (at) 25C, with a .25% tolerance, -4.39%/C alpha (at)25C, and a 3892 0C/50C beta."
When provided with the above information, GRT should be able to say if the Dynon OAT probe is compatible with the GRT mini or not.
