Kelly McMullen
Posted: Thu Apr 16, 2015 6:19 pm Post subject: Control stick bending |
After action report.
I had access to a 55 ton hydraulic press. It took some effort to create fixtures to securely hold the stick so it wouldn't go flying out of the press. The stick as delivered from Van's had approx 10 3/4" diameter between inside surfaces. Packed stick with sand. Went slowly with first one. Discovered needed 3/4" of compression before getting any permanent bend. Compressed it to slightly under 9" measurement, which after release of pressure gave a 9 3/4" dimension. That was just right, as I could see the tubing just beginning to slightly deform. Second stick came out within 1/8" dimension of first. Now have full up and down travel on elevator without stick grip hitting panel, although knuckles might get a little bruising if really need full nose down. Back to working on the 90% of remaining 5% or something like that.
On Fri, Apr 10, 2015 at 12:06 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
[quote]--> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)>
Guys as an ex-plumber, the sand idea gives the perfect support to prevent kinking. Use dry send and pack well
Warm regards
Patrick
> On 10 Apr 2015, at 03:50, Tomhanaway <tomhanaway1(at)gmail.com (tomhanaway1(at)gmail.com)> wrote:
> --> RV10-List message posted by: Tomhanaway <tomhanaway1(at)gmail.com (tomhanaway1(at)gmail.com)>
> When I did my 10, I got a pipe bender from harbor freight. Packed the tube with sand to prevent any kinks.
> Worked fine
> Tom h
> Sent from my iPad
A&P/IA, EAA Tech Counselor
KCHD |
rv10free2fly(at)yahoo.com Guest
Posted: Fri Apr 17, 2015 1:37 pm Post subject: Control stick bending |
Kelly
What panel are you using please?
Warm regards
Patrick
On 17 Apr 2015, at 11:46, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]After action report.
| Quote: | --> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)>
Warm regards
Patrick
> Worked fine
> Tom h
> Sent from my iPad
List"">http://www.matronics.com/Navigator?RV10-List
//forums.matronics.com
Kellym
Posted: Fri Apr 17, 2015 6:18 pm Post subject: Control stick bending |
Aerosport symmetrical panel with Tosten stick grips.
On 4/17/2015 2:34 PM, Patrick Pulis wrote:
| Quote: | Kelly
Warm regards
Patrick
> <rv10free2fly(at)yahoo.com.au <mailto:rv10free2fly(at)yahoo.com.au>> wrote:
> Warm regards
> Patrick
> <mailto:tomhanaway1(at)gmail.com>> wrote:
> <tomhanaway1(at)gmail.com <mailto:tomhanaway1(at)gmail.com>>
> > Worked fine
> > Tom h
> > Sent from my iPad
> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
KCHD |
