Alternator failure. Info provided (B&C value reliability)
gmcjetpilot(at)yahoo.com
PostPosted: Sat Jul 01, 2006 1:32 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
There have been many many many B&C alternator and
voltage regulator failures. Don't take my word on it just
check these archives. It happens.
I already wrote that there are failures in my post. In fact
one acquaintance got tired of the B&C voltage regulator that
burned out and replaced it with a $9.00 Ford VR.
I can point to 1000's of other ND's sold by Van's aircraft
and Niagara that have gone and are still are going for over
a 1000 hours with out problems.
Mike and his multi failures is a mystery and don't know
any details.
What alternator?
Where did he buy it?
How is it installed? Wiring? Belt?
Does he cycle the alternator on and off under load?
Does he have cooling air going to it?
Did he use the warning light
Is the battery in good condition?
This is not going to be productive. You are just two
people which is not a statistically meaningful sample,
BUT it is a data point and you and MIKE have two
differnt outcomes that we might make a conclusion.
However I bet there are several 1000 more stock ND's
flying than B&C's. Even if we hear from the Mike's less
than good results  there are many more that have the
bragging rights you have. However for the $600-$700
you would expect it to be better by a factor of 3 or 4.
I will concede that quality of some ND aftermarket and
rebuilt Alts is an issue. I do think the vendor Van had
used in the past was not the best. Well now they
changed their product. The #14684 is a new aftermarket
unit of a differnt (better?) brand. I think the quality
issue will get better. They also added the Plane
Power units as well.
To be fair to Van's a/c, builders do some not so smart
things with their alternator and incorrectly wire
them. The classic was the O/V module (crow bar)
and b-lead relay that people intentionally tripped
while the alternator was running. Many of the
Alts where fried.  They are not designed to be
disconnected from the battery while running.
The same with cycling the ALT switch, which
as you know I have said many times is a bad
idea. I guess you can say your B&C is more
tolerant of mis use?
Nothing against B&C, except the price.
Again B&C is great but to claim near perfection
is just silly. I think B&C is being miss quoted. I
know if you ask pointed questions they will tell
you the reasons parts have come back in the past.
However if you had a product and reputation you
would protect that.
>From: Fiveonepw(at)aol.com (Fiveonepw(at)aol.com)
OK, George- here's some data:
I have had NO failures on my B&C and Mike's had FIVE
on his whatever else- Not opinion, FACT.  Maybe not a big
sample, but I've yet to hear of a B&C alternator failure on
this forum or anywhere else for that matter.  Have YOU?
brian
PostPosted: Sat Jul 01, 2006 8:03 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
On Jul 1, 2006, at 5:22 AM, <gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com)> <gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com)> wrote:
Sure, everything fails. Some things just take a really long time to do so. And I don't think there have been "many many many" failures.
Have you ever looked at a B&C alternator? Their castings and machinings are quite nice -- first rate. They take pains to use good bearings and balance the rotor. It is a precision piece of hardware. I would expect to pay more for it. I would also expect it to go to TBO without a failure.
would protect that.
Bill has always been up-front about how he builds things and about how things work. I suspect he would be happy to provide people with a list of failures and reasons. I suspect he can tell you how many he has sold, how many are in service, how many have failed, and why they have failed. Good solid information is how you convince people to trust you. Building a product that is as good as it can be doesn't hurt either.
I think everyone knows that B&C produces a first-class product. None of us know the real failure numbers so any argument is pointless. I am convinced in my own mind that they make the best alternator product out there but that is only my opinion. I know it is expensive but if it just works and doesn't fail, it is worth the extra money to me. Your mileage may vary.
If someone wants to know the exact failure numbers they should go ask Bill Bainbridge. If someone does and he answers, perhaps they will be so good as to post the information here.
Brian Lloyd                         361 Catterline Waybrian-yak AT lloyd DOT com          Folsom, CA 95630
+1.916.367.2131 (voice)             +1.270.912.0788 (fax)
— Antoine de Saint-Exupéry
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
Terry Watson
PostPosted: Sat Jul 01, 2006 8:29 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
You are trying to change the subject, George. The subject (see subject line above) was ALTERNATOR failures; specifically failure (or lack thereof) of B&C alternators. So now you say “There have been many many many B&C alternator and voltage regulator failures,” and go on to talk about voltage regulators.
You claim there have been many, and that they are in the archives. I have been reading the Aeroelectric List since it was created and I don’t recall ever seeing a report of a B&C alternator failure. I just spent some time searching the archives under “alternator failure” and “B&C Alternators” and couldn’t find any hint of a failure of a B&C alternator. I did find mention of B&C voltage regulator design changes because of some problem, but nothing about B&C alternator failures.
You are the one making the claim, George. Give us some evidence, or give it up.
Terry
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of gmcjetpilot(at)yahoo.com
Sent: Saturday, July 01, 2006 2:22 AM
Subject: Re: Alternator failure. Info provided (B&C value reliability)
 <snip>
nuckollsr(at)cox.net
PostPosted: Mon Jul 03, 2006 9:27 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
value reliability)
Sender: owner-aeroelectric-list-server(at)matronics.com
Reply-To: aeroelectric-list(at)matronics.com
X-Antivirus: AVG for E-mail 7.1.394 [268.9.2/372]
"many many" . . . I forget. Is that out of
the Furlong-Stone-Fortnight measurement system?
What kinds of failures? Did any result in
uncontrolled runaways that damaged other systems
in the aircraft?
I've shared my personal observations of B&C failure
rates and reasons in the past . . . but I've not had
any first-hand experience with B&C in several years.
Perhaps you have more recent observations to share?
Have B&C's fortunes taken a sudden dive into the
crapper?
"Got tired"???? Multiple failures? B&C was unwilling
to deduce root cause and fix them? Your assertions
paint an ominous picture of B&C quality and/or
business practices. Can you enlighten us further?
If you know of a B&C customer that doesn't think
they got their money's worth from B&C, please have
them get in touch with me. My long standing promise
to drive up to Newton and jump in the "middle of
Bill's lap" is still operating.
1000 trouble free installations of ANY other brand doesn't
make B&C's "bad" or the 1,000 others "good." The bottom line is
that the risks for (1) failure to perform task and (2) failure
that migrates to other systems are not zero irrespective of
what product(s) one chooses to install. "Goodness" is a
customer perception issue. Get me in touch with a B&C customer
who thinks he got B&C "badness" in either hardware or service.
any details.
What alternator?
A WAG. The risks are still not zero . . . and perhaps
B&C IS better by a factor of 3 or 4. What measure tells
you they are NOT? May I humbly request CGS units of
measurement? Having dropped out of college I missed the
course on FSF units. Please forgive my ignorance.
I've had customers tell me of Figure Z-24
installations have halted a runaway alternator
and protected the airplane. You're stirring two
separate issues into the same pot.
(1) Alternator system ability to do intended task
(service life/reliability) and . .
(2) Alternator system failure mode effects and
features that prevent a runaway alternator
from getting loose (dark-n-stormy night
lights up really bright . . . for awhile).
The same with cycling the ALT switch, which as you know I
have said many times is a bad idea. I guess you can say
your B&C is more tolerant of misuse?
How mis-use? Somewhere on the order of 300,000
light aircraft have been built with alternator or
generator control switches. None of those systems I've
been associated with had any prohibitions or
cautions about turning the alternator or generator
on or off at any time under any conditions including B&C
products. Perhaps your experience is different.
I object to a characterization of "misuse".
Being able to control any aircraft alternator or
generator on airplanes from 150's to Hawkers at
will under any conditions is a DESIGN GOAL that
has been achieved by all the folks I work with. That's
not "misuse" but meeting the specifications
for the design. Please expand your assertions that
the design goal was a "bad idea" with the supporting
simple-ideas.
I will agree that the automotive IR alternators as-
supplied are not plug-n-play into the aircraft
venue without addressing new system integration
problems . . . but to hat-dance around integration
issues by labeling root cause of a failure as
"misuse" and then asserting that any-time/any-conditions
control as a design goal is a "bad idea" is specious.
Perhaps I missed it. What was the quotation?
And what have you observed that argues against any
B&C customer's perceptions of value?
I know if you ask pointed questions they will tell
would protect that.
Are you suggesting that they're lying? What
conversations have you had with them that would
indicate this? Inquiring minds thirst for understanding.
----- from another post --------
I am sure B&C sells a nice product.
I think B&C might(?) achieve better reliability,
but........
There is NO DATA to back that up any claim
that B&C has superior reliability. I know B&C
and Bob N. have a strong opinions but no
real data.
I have more data than you sir. I spent a lot
of time in the employ of B&C in the early years
and worked their booth at OSH for 12 years running.
I am telling you of my first-hand knowledge that
FEW (meaning perhaps 1 return per month) alternators
would come back for any attention. All suffered
some form of user induced damage.
I never saw an alternator come back for failure or
wear-out. In years since, I'm aware of one alternator
that came back for overhaul when the engine was
being overhauled too. The brushes were worn beyond
serviceability. I think the alternator was still
working . . . but I'll check on that. The engine had
2000+ hours on it. We've had controllers get returned
too. Most needed owner induce damage repaired. Occasionally
we'd have one go inop for a solder joint but there's been
very few reasons to make changes in design since Voyager
flew the first LR-1's up and down the coast of California.
Return rates for any reason have been on the order of 1%
per year for the total fleet.
I'll see what the latest experience base is for alternator
returns. I've not updated in over a year. But do I understand
you correctly George? Are you asserting that whatever I share
with the group is to be mistrusted?
To say ZERO failures is disingenuous at best,
with all do respect to B&C, but when you sell
a product that cost 3 or 4 times as much I
guess you have to distinguish yourself.
However you have to be intellectually
honest and admit that things fail and there
is NO guarantee, regardless of the price
paid.
If the alternator cited came back working but
worn, then to the best of my first hand knowledge,
the failure rates for other than external damage
have thus far been zero. Nobody is guaranteeing
anything . . . but B&C's service history is a whole
lot better that the competition in place when their
products were introduced. That was 20 years ago.
Capabilities of the current contenders haven't had
enough time in the marketplace to claim anything in
comparison with B&C.
I know of several B&C products to fail both first hand and
second hand, just check the archives.
Give me dates. I've been on this List about as long
as anybody. I cannot recall any discussions
on un-resolved B&C hardware issues. You're claiming
posted incidents to substantiate your learned advice
just as I have for other cases in times past. You pasted
me with that "no data" mantra, how come it applies to
my arguments and not to yours? I'm not going to
spend time looking. You tell us where to find them.
There are many B&C failures that don't make news, web
fourms or even get reported to B&C.
There's that "many" again. If these terrible
experiences by B&C customers are un-reported
even to B&C, how is it that you know about them?
How and when did we arrive at a condition in OBAM
aviation that customers who pay good money for
expensive hardware are going to shrug off any
opportunity for getting their money back on
bad product? Until you produce names times and
places for B&C to investigate and rectify,
your assertion as to shortcomings of their products
and/or business practice is suspect.
They are experimental and these is no tracking
of reliability. I am sure B&C is aware of failures . . .
You're telling us that B&C has lied to me when
I've inquired about failures? Please cite your
supporting evidence.
and Bob N. has been somewhat forthright . . .
Just "somewhat"????? In what manner and at
what time did you find my explanations lacking?
Pleased be specific. I've been mistaken and
sincerely appreciated correction but I've NEVER
deliberately cut corners in my explanations about anything
to anybody. If you had my permission to insult me,
I could get really upset about your statement . . .
but nobody has that permission.
. . . with problems regarding the voltage regulator that
has lead to improvements. There are still issues.
Name them. . . . If you're aware of outstanding "issues"
then speak up. I know exactly what, when and why changes
were made in the LR-series devices. Let us compare notes.
Please state which of those changes casts doubt
on either the quality our products or integrity of
our companies.
You're either citing facts that can be substantiated
or your blowing blue smoke. Neither I, nor B&C nor
our potential customers need to take notice of your
counter-marketing rhetoric until we've have had an
opportunity to address specific grievances or shortcomings.
You have to include the alternator and regulator
as a whole system when comparing it to a ND unit
with integral Voltage regulator.
B&C alternators are made 98% from ND parts
or clone aftermarket ND parts. They DO anodize
and claim . . .
You doubt the claim?
. . . . to balance it within a hair on Nat's
bee-hind, but the benefit of this blue printing is a
raging debate to be had another time.
You'll get no "rage" from me and I doubt from B&C either.
It's not worth debating unless you have an explanation
supported by simple-ideas as to how it's a no-value-added
thing to do.
I can imagine there's a positive, but how much affect on reliability
I don't know.
Then of what value is it to express your doubts
for the claim? First you "blow the smoke" and then
say "I don't know". How are readers of this discussion
to make a considered judgment of your advice?
I can say if any alternator is bolted to a wild shaking
Lycoming, producing endless vibrations and 50 G
shaking at start and shut down like a wet dog, it's
going for a WILD RIDE anyway. It is like measuring
it with a microscope and cutting with an AX. Same
with balance, does it matter? May Be?
Stock alternators are NOT without some balance.
There are million and millions of ND alternators
(stock) running 24 hours, 7 days, year after year
WORLD wide in cars and industrial equip with
extreme reliability under demanding conditions.
Both my Acura's have ND alternators. One is at
130K with no issue and the other 185K, with a
combined +24 years of combined use.
But those are not Lycomings and your cars
don't cruise the alternators at over 10,000
rpm. You're comparing apples to plums and then
buying pears. You don't design, build, or
sell anything. You don't have a dependence on
the happy customer. You've cited no personal experience
with the company and products you're down-grading.
Your advice lacks substance.
Why debate it? Balancing is a feature of their product.
Can you can cite a B&C bearing failure attributable
to ANY decipherable root cause OTHER than balance?
If not, it's just as credible to assign bearing longevity
to bearing quality, care in assembly, balancing,
a sprinkling of pixie dust or any combination
of the above. Frankly, if their service history on LYCOMINGS
in OBAM aircraft continues at the present pace, I think
it matters not what manufacturing features are
cited in the marketing hype . . .
For a dozen years I worked in the booth at OSH and
when asked "Whats the warranty" I said, "No unhappy
customers." Bill was standing right beside be me when
I said it. I've had no reason presented to me by an
unhappy customer to prove Bill a fraud or me
as mis-informed. Can you enlighten us in this regard?
The issue with many ND alternators builders use is
the fact they came from a supplier selling less than
great aftermarket NON nippondenso units. As this
15-18 year old design gets older, you will only
find aftermarket alternators. The good news is
there are good aftermarket parts. The bad news is
there are BAD ones as well. Aftermarket ND parts
are make in Taiwan and China by 4 or more big
companies. Not all are of the same quality.
Not all aftermarket parts are the same. The same
applies to re-builds at the Auto Zone or Pep-Boys.
At least many offer a good warranty. The bad news
is that chain of auto parts store may not be in your
area when doing a cross country and it fails. If
you can't go to the same store, you can't take
advantage of the warranty replacement. I suspect
if Auto-Parts-R-Us gets wind its on a plane, they
may protest and deny your warranty claim anyway.
If a B&C regulator or alternator fails, it is a custom
alternator that only B&C can really work on. There
is something to be said with over the counter auto
parts.
But who NEEDS parts to work on a B&C alternator?
Who was told that B&C alternators only work with
B&C controllers? There are diagrams in the
'Connection that illustrate alternate controller
options designed to enhance the customer's
purchasing experience with the offerings of both
B&C and the 'Connection.
I am sure B&C is good, but not as great as their hype.
"Good" . . . "not as great" . . . please cite
in CGS units . . . But in spite of "good", are
we to understand that Bill lies and Bob is less
than completely forthcoming?
If you read B&C's web site it is full of hyperbole and
rhetoric. I read the B&C sales pitch and it is so
strongly worded, like a novel, One dark and stormy
night stories, they just turn me off. It plays on
emotion not facts. I got a cold sweat and thought I
was going to die of an electrical failure sitting in my
office in front to my PC. It's a great sales pitch but
it's overstated. The owner or B&C is a super nice
guy and think he believes in his product. This is
just my opinion about what I think of sale's pitches
that play on emotion not the product.
If one chooses to join a hype-slinging match between
B&C and Plane Power's sites, there's plenty of stretched
semantics to go around. See:
http://www.plane-power.com/Comparing_Amps.htm
This alternator output curve doesn't state pulley
sizes nor test conditions under which the two curves
are plotted. It implies that Prestolite is fraudulent
in their product labeling. But the two curves are
parallel to each other . . . do you suppose if one
adjusted the Prestolite pulley down in size that the
curves would lay on top of each other? If I were to
publish curves like this, any statement made concerning
the value of the data would be supported by a
test report.
Let us consider this paragraph from Plane Power's website:
The full line of Plane-Power alternators not only give you
unprecedented choice, but also provide a vastly improved product.
Years of research & development have gone into making Plane-Power
alternators:
* Generate substantially higher power at lower engine RPM,
* Generate significantly less heat while generating rated power,
* Generate rated power at typical aircraft cruise RPM
(believe it or not, your current alternator does not!)
* Generate more power at higher altitudes (all testing to 28,000'!)
* Weigh up to four pounds less , and
* Perform much more reliably than comparable OEM models
Gee, lookit al those un-quantified adjectives! Oh, yeah,
those must be FSF units of measure. But who are they
comparing themselves to? Obviously not B&C alternators.
Here's an interesting bit: See:
http://www.plane-power.com/AL12_50C.htm
If I read the webpage correctly, this alternator is
CAPABLE of 70A of output but with the following
modifier:
*Aircraft electrical system will be limited by existing
wiring and output breaker not to exceed 50 amps. The
Plane-Power alternator can produce all 70 amps if
proper size wiring and circuit breaker is installed
and approved.
Hmmm . . . how does the downsizing of b-lead and
b-lead breaker de-rate the alternator? Sounds to me
like a set-up for nuisance tripping. If this is a 70A
machine, it needs wire and b-lead protection sized
for that capability IRRESPECTIVE of what the original
installation called for.
On a cost to benefit analysis I doubt you will see
a cost benefit from the B&C in your or anyone's
lifetime. My only gripe with B&C is the outrageous
price they charge. If you want an alternator kit
check out Plane Power.
Gripe all you want . . . and please, don't
buy a B&C or 'Connection product based on anything
Bill or I has to say about it. And don't buy it
if you've found one of our customers that has been
left with a hunk of junk because Bill or I has
told him to "lump it." If you DO buy our products,
know that we both strive to give fair value.
If you bring a product back for any reason, we
both expect to know the specifics of your problem
and we're both ready to make it right with you.
If the marketing techniques fraudulently
drove your choice to purchase the product and
you're dissatisfied with value-received, then
it's a simple matter to cite your experiences,
voice your displeasure and collect your refund.
I've had two or three folks write over the years to
say that the 'Connection was not what they expected
whereupon they got their money back . . . and were
told to keep the book. It just doesn't make sense
to be less accommodating with a customer. No news
travels faster than bad news and I strive to keep
bad news from happening. I'm sure you understand how
I might get my shorts bunched by fabricated bad news.
I'll suggest that any claims about me and the 'Connection
contrary to demonstrated policy are fabrications. I'll
stand corrected about Bill if I talk to the B&C customer
that got "shafted".
I think if you buy a good quality after-market stock
ND alternator and install and operate it properly,
you can achieve the same reliability as any DESIGNER
brand alternator. Proper operation is don't
cycle the ALT switch with the engine turning and
don't overload it.
Hmmm . . . last time I ran an alternator, it was
inherently current limited . . . if it's cooled
sufficiently to run at 100% of rated load, then you
can't "overload" it.
Proper installation is install the warning light
. . . I presume your talking about the warning
light common to internally regulated alternators.
Have you seen a schematic of how this light functions?
The schematic I've seen shows that this feature is
not worthy of name for aircraft use. But if you
have a schematic that shows something different,
we'd all be pleased and relived to know that someone
has done due-diligence in rectifying the deficiency.
. . . and provide heat shield and cooling air.
Both Plane Power and B&C offer value but I think of
the two, Plane Power has the value edge:
- High Altitude brushes
High altitude brushes in alternators is blue
smoke. Slip ring service at 3A is a whole different
animal than commutator service at 30 amps plus . . .
Further, there are no RV's I'm aware of that
cruise at 25,000 feet and up. See:
http://www.aeroelectric.com/articles/BrushesForAircraft.pdf
- Proper Fan cooling direction
B&C's go the wrong way?
- Additional O/V protection (elegant**)
(** additional OV is integrated not an ADD on B-lead relay)
Hmmm . . . I have postings you've made stating that
IR alternators didn't need ov protection. Now you say
the addition is "elegant".
Have you seen a schematic of this system? And what
does the b-lead contactor ov system have to do with B&C's
alternators and regulators? The B-lead disconnect
contactor was a system integration solution published
in the 'Connection for adding OV protection to an automotive
alternator without getting inside the alternator to
modify it. This has nothing to do with B&C's products.
Keep in mind too that the B&C alternator controller
has LV warning built . . . which reduces the
delta-dollars of Plane-Power over B&C by $60 or so.
If one chooses a 'Ford' regulator and external OV protection
with the B&C alternator, then it's less expensive than
Plane Power.
- High Quality installation hardware ($375)
B&C's installation hardware is not high quality? And this
costs extra? Gee, B&C's alternators come with the mounting
hardware. See:
http://bandc.biz/L60desc.html
Does this mean folks should steer clear of Plane Power?
Don't see why. Should folks steer clear of B&C because
of your un-substantiated assertions? Give us a list of
shafted customers who were lied to by Bill or misinformed/
lied to by me.
Bottom line: Does a product deliver what the customer wants
for his project and does he get honorable support from the
supplier when things are not going right? Tell us where B&C
(or the 'Connection) has fallen short of this time honored
free-enterprise recipe for success.
brian
PostPosted: Mon Jul 03, 2006 3:11 pm    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
You know George, I have spent a fair bit of time talking with Bill in
person at OSH and on the phone. I have looked at his products and I
have been impressed with the quality. (I used to design and build
mission-critical computer networking devices and have a bit of a clue
on how to build and support high-quality products.) I also understand
quality support from competent people. B&C provides quality support
from competent people who truly understand their product.
As I said, I will be installing a B&C alternator in my CJ6A for two
reasons:
1. I don't think anyone makes a better product at any price;
2. it is a bolt-on solution for the M14P engine (which shakes a good
deal more than any Lycoming). I expect that the B&C alternator will
make it to TBO even under aerobatic conditions.
But it takes all kinds to make a horse race. I know which horse I
plan to put my money on. And I sure do get tired of hearing people
try to sell one product by running down its competitor. It is one
thing to show how your product is better but a different thing to use
FUD to try to scare people away from a competing product. I am sure
Plane-Power and ND can stand on their own merits without you trying
to run down B&C.
Brian Lloyd
PostPosted: Tue Jul 04, 2006 2:15 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
Bob I was waiting for your to chime in.
Could you provide facts and not endless talking
in circles with vague and not so vague personal
insults. I wrote everything I needed to say,
and there is no need to repeat myself.
I was hoping you would have something useful
to contribute, but those hopes have been
dashed. When you have nothing to say
you attack the person and their choice of
words, not the facts.
I don't expect you to be un-bias, since you
where the main band leader of faults and
totally unsubstantiated urban legends about
the horrors of internal regulators for years.
I begged you to give facts so many times.
I have given up. You can be hypocritical
to an extrodinary and audacious degree.
I don't think you are intentionally duplicitous.
I just think you LOVE to argue. I am bored
of arguing with you. We where having a
nice friendly discussion on the topic before
you came along. We have MANY, MANY,
MANY smart people on this forum who
can filter your bogosity.
When you can prove B&C alternators and
voltage regulators have ZERO failure rate
please write me, and please don't try
that Failure Mode and Effect Analysis
claim you tried on me before, I know what
that means. I know you have no such
data. That was the day I lost a little
respect for you Bob, when you tried to
BS me. I still like you and think you
contribute lots of good, but when you
get like this you are less than useless.
My bladder is empty, you can pee
further, you win, you are right again,
I am wrong again. OK.
I am now going outside to talk to my mail
box since that will be about as useful as
corresponding with you right now.
Have a nice 4th of July, independence
day of the greatest democracy ever.
She may not be perfect but I would not
want to live anywhere else in the world.
Cheers George M.
>posted by: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
How low will we go? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
lhelming(at)sigecom.net
PostPosted: Tue Jul 04, 2006 4:50 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
With all respect that is due to the contributions you have otherwise made to this list, George, please consider letting this personal challenge between you and Bob thing die.  You have proven you know a lot about some things and one of them is how to never give up on a point even when concrete evidence (first hand witnesses) is missing.  I think anyone with any knowledge and deduced common sense knows that B&C alternators are proven, perhaps the best and if anyone reading this list had a failure for some reason other than installation induced, they surely would have chimed in by now.  Why would not those with failures due to installation errors have chimed in by now with all the attention you have pointed at this??
Please give us all a break and favor by showing you are a gentleman and just walk away until you get uncover (if there is any) some real evidence.
I might suggest you buy one of their alternators new, and see for yourself how they treat and service customers.  Just be sure to properly install it so IF it fails you can tell the world you were right.  For you, the higher the price, the more it might be worth it.
Thank you for your consideration.  Larry in Indiana
willslau(at)alumni.rice.e
PostPosted: Tue Jul 04, 2006 5:36 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
I think it's abundantly clear who's the one who loves to argue here, George. I don't know why you have such a vendetta against Bob and/or B&C, both of whom have built their sterling reputations over decades. If they were as duplicitous as you claim, the word would be out by now. No one cares what kind of alternator you want to use, but I'm sure lots of people on this list are extraordinarily tired of your constant attacks. Have you noticed that no one seems to be chiming in to take your side? Don't you ever get tired of being the turd in the punchbowl? Give it a rest, George. Go spew your venom somewhere else.
William Slaughter
lists(at)stevet.net
PostPosted: Tue Jul 04, 2006 6:02 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
Larry in Indiana,
Your words for George are entirely correct, but you must understand that he has been admonished many many times before and just continues to believe that he is the one and only god of the alternator universe.  Don't waste your breath (or keyboarding).  If you are smart, just put a filter in your email program that just dumps his stuff in the trash.  Yes, there are some good things he has to say (occasionally) but most of that is available elsewhere.  It's just not worth the effort.
Best Regards,
Steve
jschroeder(at)perigee.net
PostPosted: Tue Jul 04, 2006 6:26 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
Once again, George-the-Vicious can't stand an honest request for proof and
resorts to slanderous comment. Bob is not the only one who has asked for
proof. But George seems to feel that he must play with, and take on, the
big boys. Yet, he simply doesn't have the maturity to do so. There is a
short circuit in there somewhere and it destroys his ability to use his
knowledge to make meaningful contributions to the forum. Pun intended.
DO NOT ARCHIVE
Cheers George M.
rates.
rvbuilder(at)sausen.net
PostPosted: Tue Jul 04, 2006 7:29 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
 Ah yes, there are people who know a lot and say just enough and there are those who know some and speak a lot to fill the gaps.  The former tends to be better than the latter.  Now then, who is who.
kayce33(at)earthlink.net
PostPosted: Tue Jul 04, 2006 7:43 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
Gee George,
 It surely would be nice to see your writings without personal complaints. Surely you could couch your criticisms in non personal terms and still get your point across. All you would have to say is I think this way might be better and explain why...then you'd have a dialogue, not a public row. This way all could benefit, and then we ill educated, vis a vis electronics could pick and choose our approach. We may not make the best pick, but at least we'd have the info. The facts are being obscured amid your charges.
Have a happy 4th,
Harold
PostPosted: Tue Jul 04, 2006 8:29 am    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
Larry,
I think your george filter idea is great, if everyone did that, that would reduce the clutter from trying to answer him. This could  be a refreshing future without the BS from one on an ego trip.
Harold
Jekyll
PostPosted: Tue Jul 04, 2006 10:59 am    Post subject: Re: Alternator failure. Info provided (B&C value reliabi Reply with quote
George adds substantial value to this forum. Each reader must decide if George is brash, rude, obnoxious or none-of-the-above. I know what to expect when I see him chime in on anything dealing with alternators or VR's HOWEVER, I also know that his entries have caused, and will always cause a greater discussion of the issues than would be had without him. This provides us all with a greater understanding.
Don't chase George away because he riles you. Welcome him because he instigates the forum to greater depths of discussion and research.
Out of chaos comes opportunity, out of heated discourse comes understanding and knowledge.
Jekyll
lists(at)stevet.net
PostPosted: Tue Jul 04, 2006 2:18 pm    Post subject: Alternator failure. Info provided (B&C value reliability) Reply with quote
Sorry, Jekyll, but controversy can be had without being a rude and
pompous !(at)#. Depths of discussion and research is possible without
personal attacks from someone who thinks he is clearly god's gift to
the earth. I still say - filter George to trash. After you've had a
couple of months with this guy, you will have had enough, too. There
are plenty of extremely knowledgeable, experienced people who know
how to be human beings who remain.
Best Regards,
Steve
