rvdave
Posted: Sun Apr 26, 2015 5:34 am Post subject: Windshield install & defrost fans |
About ready to install windshield but realizing this would best time to plan for install of defrost fans. Is 4" a standard size? Am I just needing a 4" diam hole ? Or should it be more or less? Thinking about cutting holes now since I haven't yet settled on cfm output yet nor acquired fans. Looking for dimension placement relative to windshield--- as close as possible? 2" from ?
_________________ Dave Ford
Cadillac, MI |
bhoppe2
Joined: 09 Apr 2015 Posts: 15 Location: Nolensville, TN
woxofswa
Posted: Sun Apr 26, 2015 2:30 pm Post subject: Re: Windshield install & defrost fans |
I have two suggestions.
1. Pretty obvious, but use a metal grill. A plastic one will melt.
2. A high quality fan will save effort because a cheap fan won't last long. First one lasted about 10 hours. I then got a much higher quality ball bearing one. A little noisier which I actually like because it tells me its on but I can't hear it once the engine is running. I run mine continuously on an integrated switch breaker and a resister to step the speed down so it lasts longer. Second fan has 140 hours on it with zero issues.
Although I installed it solely for avionics cooling and defrost purposes, just yesterday I spent over a half hour in IMC and for a brief period got speckles of windshield ice most everywhere except above the fan. I would stop short of calling it anti-ice, but it definitely keeps that part of the windshield warmer.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
