brettg101(at)comcast.net Guest
Posted: Mon Apr 27, 2015 6:33 pm Post subject: CJ-6 Gill Shutters |
I’m looking for some advice on tightening the Gill Shutters on a CJ-6. Any assistance would be appreciated.
Thank you,
Brett
cjpilot710(at)aol.com Guest
Posted: Mon Apr 27, 2015 6:40 pm Post subject: CJ-6 Gill Shutters |
Brett,
Are you sure the gills shutters are not just worn out? I am not sure there is a way to "tightening" them up.
Jim "Pappy" Goolsby
In a message dated 4/27/2015 10:34:18 P.M. Eastern Daylight Time, brettg101(at)comcast.net writes:
| Quote: | --> Yak-List message posted by: Brett Grooms <brettg101(at)comcast.net>
Thank ========================bsp; e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Viperdoc
Posted: Mon Apr 27, 2015 6:49 pm Post subject: CJ-6 Gill Shutters |
Doug has replacement shutter too.
Doc
Sent from my iPad
On Apr 27, 2015, at 9:37 PM, cjpilot710(at)aol.com (cjpilot710(at)aol.com) wrote:
[quote] Brett,
Jim "Pappy" Goolsby
In a message dated 4/27/2015 10:34:18 P.M. Eastern Daylight Time, brettg101(at)comcast.net (brettg101(at)comcast.net) writes:
| Quote: | --> Yak-List message posted by: Brett Grooms <brettg101(at)comcast.net (brettg101(at)comcast.net)>
ist"">http://www.matronics.com/Navigator?Yak-List
//forums.matronics.com
_________________ Viperdoc |
Posted: Mon Apr 27, 2015 6:54 pm Post subject: CJ-6 Gill Shutters |
Hum, well maybe that’s why we can’t figure out how to tighten them. : )
Might have to check with Doug and see what his stock and cost are on shutters then.
Thank you -
Brett
On Apr 27, 2015, at 10:48 PM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
DocSent from my iPad
| Quote: | Brett,
Jim "Pappy" Goolsby
dougsappllc(at)gmail.com Guest
Posted: Mon Apr 27, 2015 7:00 pm Post subject: CJ-6 Gill Shutters |
Please be more specific."Tighten the gills", as in they are loose on the nose case studs?
Shutters themselves are loose?
Center rings are worn, loose in this area??
Need more info
Doug Sapp
On Mon, Apr 27, 2015 at 7:32 PM, Brett Grooms <brettg101(at)comcast.net (brettg101(at)comcast.net)> wrote:
[quote]--> Yak-List message posted by: Brett Grooms <brettg101(at)comcast.net (brettg101(at)comcast.net)>
Thank you,
Brett
List" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
Posted: Thu Apr 30, 2015 10:15 am Post subject: CJ-6 Gill Shutters |
Doug,
I spend time looking at the Gill Shutters the other day to better understand the mechanism. This is the best I can describe, the shutters themselves (almost all of them have some play but probably typical as the ’slots’ don’t appear to be worn), the nose case studs appear to be fine, the center ring has some play/movement in it. Here’s the scenario, during flight with the shutters closed about halfway the air pressure tends to push them closed further. I’m wondering if it has to do with the teleflex cable or spring tension on the knob in the cockpit then the actual shutters????
Thoughts????
Thank you,
Brett
On Apr 27, 2015, at 10:59 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Need more info
Doug Sapp
JL2A
Posted: Mon May 11, 2015 11:56 pm Post subject: Re: CJ-6 Gill Shutters |
| Quote: | Doug,
I spend time looking at the Gill Shutters the other day to better understand the mechanism. This is the best I can describe, the shutters themselves (almost all of them have some play but probably typical as the ’slots’ don’t appear to be worn), the nose case studs appear to be fine, the center ring has some play/movement in it. Here’s the scenario, during flight with the shutters closed about halfway the air pressure tends to push them closed further. I’m wondering if it has to do with the teleflex cable or spring tension on the knob in the cockpit then the actual shutters???? |
Hi Brett, I have replaced the shutters before due to excessive play - in my case and probably most others it is worn guides (part of each shutter) and the pins that ride in them. I know of some down under that have built these areas back up with welds and grinded back to shape! (Don't bother)
However the air pushing your shutters closed is probably due to the handle in the cockpit having worn out 'lobes'. Unscrew the handle in your cockpit and you will see what I mean. As far as I can you have to replace the whole rotary-into-linear-motion thingy behind the dash. But first, just unscrew the handle put a rubber grommet between the two lobe faces and it may provide enough friction to stop the handle rotating in flight. Depends on how worn they are.
Anatole[/quote]
