tie breaker
cjhukill(at)cox.net
PostPosted: Sun May 31, 2015 7:20 am    Post subject: tie breaker Reply with quote
If you have dual AHDRS with auto monitoring, and dual screens, the need for a tie breaker is debatable . My dual Skyview provides this capability as do other EFIS systems. You may not realize this, but you already have a tie breaker, as they call them in jets, if you have an IPhone 5 or newer. Use the compass ap that came with the phone, and go to the second page of the ap, and therein is a very accurate pitch and roll display, and it won’t tumble. I have played around with it , maneuvering in my RV8 and have no problem returning to strait and level and maintaining that, using that as a sole reference, (under a hood with a safety pilot). You don’t get airspeed or altitude info, but target pitch and power is all you need to fly anyway while you sort things out. Turn the IPhone's auto lock feature to “never” and velcro the phone to the panel. If you fly lots of hard IFR, then go ahead and get the real deal in your panel. If all you fly is light IFR, like getting above a marine overcast on departure or down thru one with an approach, then dual AHDRS with auto monitoring, and the IPhone tie breaker may be all you need. There are probably better aviation aps that use the ADRS chip in the IPhone or IPad or whatever devise you have with you , but you may already have all the tie breaker that you need. Just saying....
Lew Gallagher
PostPosted: Sun May 31, 2015 8:16 am    Post subject: tie breaker Reply with quote
Cool, Chris. Never new I had that!
Later, – Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
bbreckenridge(at)gmail.co
PostPosted: Sun May 31, 2015 8:25 am    Post subject: tie breaker Reply with quote
I just grabbed my wife's iPhone 6 Plus - amazing!  Can't wait to put it in the plane and try it out.  Thanks!
On Sun, May 31, 2015 at 8:17 AM, Chris Hukill <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
[quote] If you have dual AHDRS with auto monitoring, and dual screens, the need for a tie breaker is debatable . My dual Skyview provides this capability as do other EFIS systems. You may not realize this, but you already have a tie breaker, as they call them in jets, if you have an IPhone 5 or newer.  Use the compass ap that came with the phone, and go to the second page of the ap, and therein is a very accurate pitch and roll display, and it won’t tumble. I have played around with it , maneuvering in my RV8 and have no problem returning to strait and level and maintaining that, using that as a sole reference, (under a hood with a safety pilot). You don’t get airspeed or altitude info, but target pitch and power is all you need to fly anyway while you sort things out. Turn the IPhone's auto lock feature to “never” and velcro the phone to the panel. If you fly lots of hard IFR, then go ahead and get the real deal in your panel. If all you fly is light IFR, like getting above a marine overcast on departure or down thru one with an approach, then dual AHDRS with auto monitoring, and the IPhone tie breaker may be all you need. There are probably better aviation aps that use the ADRS chip in the IPhone or IPad or whatever devise you have with you , but you may already have all the tie breaker that you need. Just saying....
tp://forums.matronics.com
EdKranz
PostPosted: Sun May 31, 2015 8:41 am    Post subject: tie breaker Reply with quote
That is cool.
One thing to be careful of in that app. After 45 degrees in either roll
direction, it "flips" to think you're holding the phone in portrait vs
landscape. My guess is that the aviation based apps like this would be much
better.
On Sun, May 31, 2015 at 11:20 AM, Bruce Breckenridge <
bbreckenridge(at)gmail.com> wrote:
[quote] I just grabbed my wife's iPhone 6 Plus - amazing! Can't wait to put it in
Ed Kranz
RV10
Finishing
www.edandcolleen.com
Tim Olson
PostPosted: Sun May 31, 2015 8:55 am    Post subject: tie breaker Reply with quote
I just tried this. That's where his key words of setting your phone to rotation lock is important. I always keep my phone rotate locked and it worked properly that way, but yes, if you turn that off it could be very problematic
Lenny Iszak
PostPosted: Tue Jun 02, 2015 2:41 pm    Post subject: Re: tie breaker Reply with quote
I would not rely on that as a tiebreaker. Once you get into a turn the centripetal forces start messing with the attitude solution much like your own senses, which we all know better not to rely on. The steeper the turn the bigger the error.
To correct for the centripetal error you need to factor in speed, and I don't think the compass app does that, but I could be wrong, I never tried the app in flight.
Lenny
cjhukill(at)cox.net
PostPosted: Wed Jun 03, 2015 5:57 am    Post subject: tie breaker Reply with quote
Lenny
The purpose of a "tie breaker" is to verify which of your attitude
indications are correct when two systems are in disagreement. It is mostly
redundant information in modern EFIS systems as the EFIS will compare it's
attitude information with pitot- static and GPS data and figure out which
one is in error from that. It then alerts the pilot with it's determination
of which attitude system is in fault. The pilot only has to verify that
recommendation and the EFIS will run both screens on the good AHDRS . This
all happens in a few seconds. The pilot should have a means of verifying the
attitude information during those few seconds, hence a tie breaker. Any
precession error or centripetal forces aren't a factor as your only
interested in the displayed attitude of the tie breaker during the short
period of time that your verifying the EFIS's solution to the displayed
error. In VMC you could just look out the window, or in the bad old days you
could try to fly with needle ball and airspeed. Heck we had to be able to
fly an approach using only an airspeed indicator, altimeter, and an electric
turn and bank even with all of it's precession errors. A modern standby
suite should be able to give you all the info a needle, ball and airspeed
gives you, but the panel real estate dedicated to those old dials would be
better spent on a second screen with it's second, monitored AHDRS. Your
IPhone velcroed to the panel with it's attitude info displayed could then be
your tiebreaker.
Chris
Time: 03:45:12 PM PST US
Subject: Re: tie breaker
centripetal
error.
don't think
flight.
Lenny
