Kelly McMullen
Posted: Wed Jun 03, 2015 6:14 pm Post subject: Missing step? 18-5 Fuel Tanks |
Phil,
The difference is the top and bottom fairings join at the top, where you have the dimpled nutplates, while the rest of the holes go through more layers and can be countersunk.
There is no skin joint on the bottom, just at the forward spar attach on top.
Kelly
On Wed, Jun 3, 2015 at 6:41 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
Just curious. I'm trimming up my wing root fairings and am running into a problem. Going back, I think I've found it.
Attached is a photo of 18-5. They call for a dimple in the T-1005B (upper) shim. But the plans don't call for dimples in the T-1005C (lower) shim.
The skin is dimpled (as called for under in the wing attach section), but this substructure isn't.
Am I missing something in assuming these bottom shims need to be dimpled too? Or is there something I don't know/understand.
Phil
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
A&P/IA, EAA Tech Counselor
KCHD |
Rocketman1988
Posted: Wed Jun 03, 2015 6:21 pm Post subject: Re: Missing step? 18-5 Fuel Tanks |
I am at the root fairing step and had to read and re read the plans to figure that one out...the holes that are not dimple get counter sunk to accept the dimpled root fairing...
philperry9
Posted: Wed Jun 03, 2015 6:41 pm Post subject: Missing step? 18-5 Fuel Tanks |
Do you remember where that step can be found? That was going to be my plan.
| Quote: | On Jun 3, 2015, at 9:21 PM, Rocketman1988 <Rocketman(at)etczone.com> wrote:
http://forums.matronics.com/viewtopic.php?p=442968#442968
Kelly McMullen
Posted: Wed Jun 03, 2015 7:26 pm Post subject: Missing step? 18-5 Fuel Tanks |
Phil,
I just looked for it and didn't find the step. I'm not sure if I just decided to go ahead and do the countersinking as I was doing the wing attach or if I ran across it somewhere. PG 44-10 figure has mention of machine countersinking of the tank skin and shows the rest of the holes on the stub spar as though they were already done.
Kelly
On Wed, Jun 3, 2015 at 7:37 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
> On Jun 3, 2015, at 9:21 PM, Rocketman1988 <Rocketman(at)etczone.com (Rocketman(at)etczone.com)> wrote:
> --> RV10-List message posted by: "Rocketman1988" <Rocketman(at)etczone.com (Rocketman(at)etczone.com)>
KCHD |
fehdxlbb(at)gmail.com Guest
Posted: Thu Jun 04, 2015 1:30 pm Post subject: Missing step? 18-5 Fuel Tanks |
