ChrisJ
Posted: Wed Jun 10, 2015 2:15 pm Post subject: E-bus feed switch rating |
I'm using the Z-12 electrical schematic to wire my airplane, and I had a question about the E-bus feed switch rating. My E-bus will draw 22-30 amps depending on transient loads like flaps or boost pump. My diode will handle that just fine, but the toggles I bought from B&C are only rated to 15A. Do I need to hunt down an appropriately rated switch for this application? I searched the archives and didn't really find the answer. I can't be the first guy to put a few too many things on the E-bus can I??
Posted: Wed Jun 10, 2015 3:36 pm Post subject: Re: E-bus feed switch rating |
Wire the eBus per Z-32
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z32K.pdf
Notice that the relay has a diode arc suppressor. An external diode can be connected. Or buy a relay with a built in diode. If the relay has a built-in diode, then polarity matters.
http://www.digikey.com/product-detail/en/1432793-1/PB1773-ND/1236843
The advantages of using a relay are remote control (shut off power at the source instead of running a hot wire into the cockpit). And a relay can be used to handle more current than a small switch can handle.
_________________ Joe Gores |
rossmickey(at)comcast.net Guest
Posted: Wed Jun 10, 2015 7:53 pm Post subject: E-bus feed switch rating |
What does the arc suppressor do?
Ross Mickey
541-954-7521
jmjones2000(at)mindspring Guest
Posted: Thu Jun 11, 2015 2:34 am Post subject: E-bus feed switch rating |
I used one of these.
http://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr2.php?clickkey=11597
http://forums.matronics.com/viewtopic.php?p=443368#443368
Posted: Thu Jun 11, 2015 3:53 am Post subject: Re: E-bus feed switch rating |
| Quote: | What does the arc suppressor do?
Ross Mickey |
When current though an inductor (coil) is shut off, the collapsing magnetic field induces a high voltage that makes current flow in SAME direction as it was originally flowing. This principle is used to power spark plugs in engines. An analogy is to quickly shut off the flow of water in a pipe. The water tends to keep flowing due to inertia. Without some type of shock absorber, the pipes will hammer and bang. This principle is used to pump water without external power (hydraulic ram pump).
Anyway, when current to a relay is shut off, the high induced voltage will arc across the open switch contacts, shortening the life of the switch. A diode connected across the coil will short out induced current and limit the voltage to about 1V. The arrow on the diode should point towards positive. The diode will not conduct while the relay is energized, but it will conduct induced current when the relay is de-energized.
Joe
Posted: Thu Jun 11, 2015 5:09 am Post subject: E-bus feed switch rating |
At 05:15 PM 6/10/2015, you wrote:
| Quote: | --> AeroElectric-List message posted by: "ChrisJ" <dangerplane(at)mac.com>
I'm using the Z-12 electrical schematic to wire my airplane, and I had a question about the E-bus feed switch rating. My E-bus will draw 22-30 amps depending on transient loads like flaps or boost pump. My diode will handle that just fine, but the toggles I bought from B&C are only rated to 15A. Do I need to hunt down an appropriately rated switch for this application? I searched the archives and didn't really find the answer. I can't be the first guy to put a few too many things on the E-bus can I?? |
That is NOT an E-BUS . . .
E stands for 'endurance'. The e-bus is intended
to offer a fast-configuration to Plan-B . . . battery
only, alternator-out operations . . .or perhaps
reduced capabilities supported by a standby alternator
like Z-13/8.
The e-bus alternate feed offers a means by which
the airplane can be powered-down to the minimum
equipment needed for comfortable continuation of
flight . . . preferably to the airport of intended
destination. It's an energy management tool that
must calls for (1) developing the minimalist list
of support equipment and (2) planning for the energy
needed. If you're battery-only, then your well advised
to install and maintain a battery of KNOWN capacity
that will support your e-bus loads for the endurance
design goals. I like to plan to run out of fuel before
I run out of watt-seconds.
With no standby alternator, the typical ebus loads
are 2-5 amps. With an SD-8 second alternator,
e-bus can run 8+ amps . . . perhaps more and still
SAVE the battery for descent and approach to landing.
With an SD-20, you install Z-12 and don't even
need an e-bus.
Bob . . . [quote][b]
Posted: Thu Jun 11, 2015 5:29 am Post subject: E-bus feed switch rating |
At 05:33 AM 6/11/2015, you wrote:
Why a breaker/switch? Those are loaded with mechanical
monkey motion to combine the functions. Rube Goldburg
would be proud . . . if you don't NEED the circuit
protection, then a plain vanilla switch is the better
choice.
[img]cid:7.1.0.9.0.20150611082213.0205e990(at)aeroelectric.com.0[/img]
148.95 KB |
7773 Time(s) |
