versoelectric(at)GMAIL.CO Guest
Posted: Sat Jun 27, 2015 5:34 pm Post subject: Alternator problem? |
On Jun 27, 2015, at 4:40 PM, "user9253" wrote:
Quote: | The over-voltage and low voltage features of the LR3 are not needed in your application if the VP-X provides over-voltage and the EFIS gives low voltage warning.
Does the VP-X initiate a crowbar in the presence of over-voltage, or simply report it through alarm output?
Eric
millner(at)me.com Guest
Posted: Sat Jun 27, 2015 7:22 pm Post subject: Alternator problem? |
In our '70's Cardinals, Cessna installed an electrolytic capacitor across the OV unit to minimize such trips...
Paul
Posted: Sun Jun 28, 2015 8:18 am Post subject: Alternator problem? |
Quote: |
You just went over my head with "brush-bounce".  |
The term "bounce" is probably inappropriate . . .
"discontinuity" is probably a better description.
Brush bounce is a real phenomenon usually promoted
by out-of-round slip rings or gross contamination
of the surface.
An artfully crafted slip ring receives final
finish with the armature shaft captured between
centers and cut with a diamond tipped tool with
cutting depth and rates so tiny that the finish
is mirror smooth.
Now, press a chunk of carbon to that surface while
it romps along at 200 inches per second . . . and
that 'smoothness' can take on a new character
as tiny bits of material transfers from the brush
to the slip-ring. Over time measured in hours,
a 'film' is formed on the copper. The charcater and
rate of deposition is a function of current magnitude
and direction in the brush, moisture, brush material makeup,
pressure, and probably a few other things the sub-microscopic/
molecular level. See: http://tinyurl.com/q9q62eb
It ALWAYS happens and is built into the nature of
machines with brushes. Problems can manifest when
some feature of associated electronics is
sensitive to the discontinuity. The 30 year arm
wrestling match with the TC regulator has roots
in just such a sensitivity
Quote: | I'm all for grins! Can you give me an idea where to get or how to build this filter? |
What is the center-to-center distance for
the F1 to F2 terminals on your alternator?
I crafted a filter to conduct some experiments
on the problem aircraft that seemed to 'fix' the
problem . . . more appropriately 'mask' the
problem. It didn't fix the design descrepancy
in the regulator . . . only broke the propagation
mode between the antagonist (perfectly normal
brush behavior) and the victim (an uber-sensitive
OV sense mechanism).
As a quick, interim experiment, try connecdting a high
quality, 1 uF capacitor from F1 to F2 on your alternator.
NOT an electrolytic but a some form of metal-film device.
I've got a few hundred laying around . . . can send
you one of those right away.
Bob . . . [quote][b]
Posted: Sun Jun 28, 2015 9:41 am Post subject: Alternator problem? |
At 06:40 PM 6/27/2015, you wrote:
Directions for making a filter:
http://www.sanantoniohams.org/tips/whine.htm
Alternators have bushes that ride on slip rings. If the rings are not concentric, the brushes will move up and down in their holders.
. . . and under some conditions, experience
periodic disconnections from the slip ring . . .
Which is probably not the phenomenon were
working with here . . . as described in my
recent post, the discontinuity of interest
may have more to with quality of brush-track
than from mechanical imperfections in surface
or concentricity . . . but in any case SHOULD
NOT be a component of root cause for OV trips
in a well design OV sense system.
By the way, it's been a persistent notion in some
circles for decades that 'automotive' hardware
with brushes are ill-suited to use on aircraft due
to effects of altitude leading to mis-interpreted
assumptions that atmospheric pressure has a profound
effect on brush performance. As pointed out in the
the article I cited earlier, MOISTURE is a high-influence
predictor of brush performance . . . and failure to
perform at altitude has a lot to do with humidity
and nearly nothing to do with altitude.
"Altitude rated" brushes are really "low humidity
rated" devices with chemistry added to the brush-makeup
that compensates for reduced atmospheric moisture at
altitude. But even those effects are much more pronounced
on high current density brushes that ride on commutators
as opposed to 3A max, 1A normal loads on alternator
slip-rings. The collective experience of both TC
and OBAM aviation communities have demonstrated that
altitude effects are VERY low on the totem-pole
of stresses that raise risk.
> can you give me some idea of where I may have a disconnection in the "discontinuity in assembly of simple-ideas that govern performance
I get the impression that Bob is inferring that he does not trust the VP-X.
Didn't say that. What I'm saying is that I do
not have enough information about the VP-X OV
protection philosophy to discount the possibility
that NORMAL alternator-noises are participating in nuisance
trips.
I suggest that instead of pulling the alternator, that you replace the voltage regulator with a generic Ford VR166 or equivalent. There is a list in Bob's book. The over-voltage and low voltage features of the LR3 are not needed in your application if the VP-X provides over-voltage and the EFIS gives low voltage warning.
An excellent experiment. If the VR-166 style
regulators are presently fitted with OV protection,
it's performance benchmarks are certainly going
to be different than an LR3. If the nuisance
trips go away with THAT regulator, then there
is reason to investigate the LR-3 more closely.
If they continue, then the difficulty will be
have root cause in features found elsewhere.
donjohnston
Posted: Sun Jun 28, 2015 10:21 am Post subject: Re: Alternator problem? |
Quote: | I suggest that instead of pulling the alternator, that you replace the voltage regulator with a generic Ford VR166 or equivalent. There is a list in Bob's book. The over-voltage and low voltage features of the LR3 are not needed in your application if the VP-X provides over-voltage and the EFIS gives low voltage warning.
have root cause in features found elsewhere. |
I thought that voltage regulators were voltage specific? Are these generic VR's available in 28v versions?
Posted: Sun Jun 28, 2015 11:53 am Post subject: Alternator problem? |
Quote: | I thought that voltage regulators were voltage specific? Are these generic VR's available in 28v versions? |
OOPS! You caught us with our perceptions down . . .
yes, the VR166 is 14v only. Scratch that idea.
Joined: 28 Mar 2008 Posts: 1938 Location: Riley TWP Michigan
Posted: Sun Jun 28, 2015 12:34 pm Post subject: Re: Alternator problem? |
Oops, my mistake. I forgot about the 28 volt system. I do not know of any generic 28 volt regulators.
_________________ Joe Gores |
ceengland7(at)gmail.com Guest
Posted: Sun Jun 28, 2015 6:42 pm Post subject: Re: Alternator problem? |
24 volt Voltage regulator, eBay item number:151689173831, is only $10. Has anyone ever tried to adapt an internal voltage regulator for external use?
Joe
Posted: Sun Jun 28, 2015 7:04 pm Post subject: Alternator problem? |
On 6/28/2015 9:42 PM, user9253 wrote:
Joe
Joe Gores
I wondered about that, as well. Shouldn't be too big a deal for someone
handy with a soldering iron.
rnjcurtis(at)charter.net Guest
Posted: Mon Jun 29, 2015 4:07 am Post subject: Alternator problem? |
I converted a Denso alternator to external using the instructions published on the EAA site. It is not difficult, but takes a bit of time.
Roger
Sent from: YOGA TABLET 10 HD+
> Joe
> Joe Gores
Posted: Mon Jun 29, 2015 4:34 am Post subject: Alternator problem? |
In rereading the posts, It appears that the conversation was referring to removing an internal regulator and using it externally. I don't know of anyone doing this.
Roger
Roger
Posted: Mon Jun 29, 2015 4:40 am Post subject: Alternator problem? |
I think Joe is referring to actually using the regulator that's made for internal regulation as an external regulator. A bit more involved than adapting an external regulator to a '1-wire' alternator (but not a lot more).
On Mon, Jun 29, 2015 at 7:04 AM, rnjcurtis <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)> wrote:
[quote]--> AeroElectric-List message posted by: rnjcurtis <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)>
Roger
Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
>--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
>> --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
>> Joe
>> Joe Gores
>Charlie
donjohnston
Posted: Mon Jun 29, 2015 5:06 am Post subject: Alternator problem? |
At 07:31 AM 6/29/2015, you wrote:
Quote: | --> AeroElectric-List message posted by: rnjcurtis <rnjcurtis(at)charter.net>
In rereading the posts, It appears that the conversation was referring to removing an internal regulator and using it externally. I don't know of anyone doing this. |
There was an article, I think in Sport Aviation
some years ago about making electrical connections
to a dis-mounted replacement for an I-R alternator
regulator for use as a stand-alone external
regulator.
A straight-forward task . . . sometimes. Some
internal regulators utilize and AC voltage sense
path connected to on of the windings. Without
specific knowledge of this feature, the
activity is problematic. The article spoke
to a particular OEM part that was not so
equipped . . . finding one in 28v and knowing
it's pedigree would be difficult.
Posted: Mon Jun 29, 2015 6:53 am Post subject: Alternator problem? |
At 07:45 AM 6/29/2015, you wrote:
Quote: | --> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
I appreciate the suggestions. But I'm not sure if trying to MacGuyver a voltage regulator is good way to troubleshoot my current issue. [Laughing]
Vertical Power has offered to bench check the VP-X but removing it won't be the easiest thing and I'm looking at a 10-day turnaround.
So buying a new LR3C-28 at $198 may be a relatively easy and timely (although not very cost effective) step. If it turns out not to be the VR, I guess I'll have a spare.
At that point, it would most likely be the VP-X and then I could send that out. |
It's all most a given that both the LR3 and the
VPX will bench check okay . . . as would the
alternator. Everything is probably performing
as their designers intended.
Let's do the filter thingy first. Need a mailing
address.
donjohnston
Posted: Mon Jun 29, 2015 7:54 am Post subject: Re: Alternator problem? |
I couldn't figure out how to do a private message here. So I sent you an email yesterday with my mailing address.
-Don
Edit: Bob, I figured it out. Sent you a PM.
Posted: Mon Jun 29, 2015 9:03 am Post subject: Alternator problem? |
Cheap troubleshooting by substitution (only), as implied by the previous suggestion of using a COTS Ford regulator to substitute for the existing unit (not possible due to existing unit being 28v instead of 14v).Â
Turning alternators on/off is a completely different issue, and begs the question: Why?
On Mon, Jun 29, 2015 at 7:47 AM, <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)> wrote:
Quote: | In doing this, wouldn’t one be just moving the problems that have been discussed in great detail, of why we should not use internally regulated alternators. The internal regulators do not react kindly to turning the alternator on and off.
Roger
Posted: Tue Jun 30, 2015 7:14 am Post subject: Alternator problem? |
Quote: | In doing this, wouldn’t one be just moving the problems that have been discussed in great detail, of why we should not use internally regulated alternators. The internal regulators do not react kindly to turning the alternator on and off. |
It's not a matter of 'not taking kindly' . . . its the
conditions surrounding a failure modes. Off the shelf, internally
regulated alternators have a runaway failure mode wherein the
alternator CANNOT be shut off from outside. This is why
some folks remove the built in regulator (B&C) and others
wire around the regulator (Plane-Power) to effect positive
external control of field excitation for the purpose of
turning it ON or OFF at will, or shutting it down if
the regulator goes TU.
A myth commonly circulated throughout the vehicular
DC power systems world is that it is undesirable,
dangerous, deleterious, or (as has been articulated
here on the List) just plain stupid to turn an
operating alternator ON and OFF at will. It's
a well circulated, overly fertilized myth easily
demonstrated to be horse-pucky. The desirability
for and effects of random or purposeful control
of an alternator at will are completely benign
to the alternator and equipment it powers.
But if the regulator wanders into the weeds,
you gotta have a method to turn the thing OFF
(or disconnect it from the airplane) in a timely
fashion while minimizing smoke and flames.
