Propeller/engine vibration
JohnFrance
PostPosted: Mon Jul 13, 2015 12:29 pm    Post subject: Propeller/engine vibration Reply with quote
Hi All,
during a recent flight I experienced (propeller!) vibration at the start of the descent when I reduced power. This was after about two hours in cruise flight. The frequency was quite high and I could feel a tingling sensation in the feet in contact with the rudder pedals which makes me think the vibration is coming from the propeller/engine combination.
Upon landing I made a close inspection of the propeller and everything seemed normal except for some flies and bugs. After cleaning, during the next flight I experienced the same problem. The vibration is at its worst at 4800 rpm and reduces slightly at 5000 but it is still noticeable.
Before I start taking everything to pieces does anyone have an idea what could cause this sudden change?
John
Europa mono Nr 192
dg.watts(at)talktalk.net
PostPosted: Mon Jul 13, 2015 1:24 pm    Post subject: Propeller/engine vibration Reply with quote
John
I have been chasing this exact problem since May 20th and finally it looks like it may be cured, but without actually finding anything wrong.
I will explain.
At 4900 rpm and 25" manifold pressure it was smooth as you could want. At 4900 rpm and 24" map down to 18" map and really severe vibration.
Over the next few weeks I checked and test flew
Carb balance
Replaced the carb needles and jets
Changed both the carbs to a couple of spares
Flew using only one then the other mag
Checked the whole exhaust system
Replaced the whole exhaust system for an old spare setup
Checked over the whole Airmaster propeller assembly
Checked cylinder pressures
Checked the engine mounting rubbers
Checked for anything touching or loose
All of these things made absolutely no difference to the manner or severity of the vibration.
Finally after advice from a Rotax expert service agent in the UK I removed the gearbox and took it to him. He took it apart but couldn't find anything wrong.
I got him to replace the bellville washers and the front bearing as it was all apart.
Upon reassembly it now runs smooth again, so probably or maybe it was the gearbox.
I am still very wary at the moment but I am hoping the problem is solved.
Dave Watts
G-BXDY Classic MonoWheel
2150 hrs airframe 1150 hrs 912S Rotax engine
On 13 Jul 2015, at 21:29, JohnFrance <77alembert(at)gmail.com> wrote:
Hi All,
John
Europa mono Nr 192
http://forums.matronics.com/viewtopic.php?p=444702#444702
rlborger(at)mac.com
PostPosted: Mon Jul 13, 2015 3:06 pm    Post subject: Propeller/engine vibration Reply with quote
John,
I agree with Dave Watts. First place I’d look is the gearbox. Have a good Rotax tech go through the various checks in the maintenance manual. I bet you need new Bellville springs. Hopefully, nothing further needs replacing.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jul 13, 2015, at 3:29 PM, JohnFrance <77alembert(at)gmail.com> wrote:
Hi All,
John
Europa mono Nr 192
JohnFrance
PostPosted: Mon Jul 13, 2015 11:49 pm    Post subject: Re: Propeller/engine vibration Reply with quote
Dear Dave and Bob,
thank you for your feedback regarding the vibration problem.
Dave, did your vibration appear "out of the blue" like mine did?
My engine is a Rotax 912 UL with only 334 hours on it and according to the serial number it is one of the few fitted with a 15 degree clutch and has a TBO of 1200 hours. If I get the gearbox shaft changed at the same time it would extend TBO to 1500 as all other work has been carried out.
Not the best time to be down, right at the height of the flying season!
John
Europa mono Nr 192
PostPosted: Tue Jul 14, 2015 12:54 am    Post subject: Propeller/engine vibration Reply with quote
John,
Yes the vibration appeared "out of the blue" on the 20th May and it got no worse and no different from the moment it started until last week, when it seems that it may now be cured.
My Rotax agent thought it may be the splines on the gearbox prop shaft and although he showed me that they still appeared to be perfect he is now of the opinion that just reassembling them on different splines may have cured my problem. (This though makes me feel that there may be some slight undetectable wear in the splines that will rear it's ugly head again in the future!!!)
Dave Watts
G-BXDY
On 14 Jul 2015, at 08:49, JohnFrance <77alembert(at)gmail.com> wrote:
Dear Dave and Bob,
John
Europa mono Nr 192
http://forums.matronics.com/viewtopic.php?p=444726#444726
budyerly(at)msn.com
PostPosted: Tue Jul 14, 2015 3:02 am    Post subject: Propeller/engine vibration Reply with quote
John,
During a descent especially the prop to gearbox/engine combination causes a vibration when the prop windmilling force and drive force are nearly equal.
If the slop in the gearbox due to a worn slipper clutch or just the gear lash becomes too much you get vibration and noise all the time. On taxi even.
To test: If all is smooth at cruise and takeoff when the prop is pulling, simply hold your speed constant and reduce power (throttle) until the vibration starts. On the Airmaster AC200, go to MANUAL and move the prop to a course setting. If it stops the vibration, as the prop begins to pull, it is just normal gear box lash.
In a descent, my Airmaster/914 will vibrate and I either pull more power off to force the windmilling prop to compression brake, or change the pitch to a course setting to allow the prop to pull.
Common areas to feel this: High speed descent with small power reduction or in the pattern at 4000 RPM / 17 inches turning base leg. Either ceases with power lever movement to get the prop to fully brake, or pull.
Bud Yerly
Sent from my iPad
On Jul 13, 2015, at 7:06 PM, Robert Borger <rlborger(at)mac.com> wrote:
John,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
Hi All,
John
Europa mono Nr 192
ptag.dev(at)tiscali.co.uk
PostPosted: Tue Jul 14, 2015 3:17 am    Post subject: Propeller/engine vibration Reply with quote
Hi! John /David /All ,
If your engine/gearbox set up includes a propeller strike engine protection
drive clutch(Slipper Clutch) you may find that the peaks of the drive lobes
have eroded spots of the flame hardening on the mating surfaces in the
valleys which is part of the gear pinion machining. (Entire gear and pinion
pair replacement usually needed about £1Kfor parts alone!) I believe that
the mating surface loading of this device when under light loading, with the
lobe peaks centred has too small surface contact, is not getting adequate
high pressure lubrication from the approved engine oils.
For instance under heavy thrust loading in normal flight the lobe surface
has a much larger contact surface having moved up the drive slopes from out
of the valley's . On throttling back the lobes move back to the limited
surface area contact position giving the intense surface pressure loading
where the erosion is happening . ( This has all been reported to the LAA
with photographs with no response .) I had the services of the ROTAX service
engineer in dismantling and reassembling but chose to carefully dremel the
offending places of erosion before reassembly and torque setting.
On any engine oil change I am now adding a full can of Holts STP high
contact pressure additive by carefully mixing it hot with the new engine oil
before pouring it into the oil tank . All sign of metal contaminant on the
magnetic plug have now stopped(Multiple checks and also at EVERY oil change)
and the vibration is now minimal . The engine has completed in excess of
200 hours with this set up but the vibration (although very much minimised
and probably un-noticeable by anyone else!) is slightly there in a very
light load condition (just above idle). No further contamination has been
detected on the magnetic plug.
Flight engine RPM landing control is the key to keeping away from the very
light loading position and an full idle setting to lose speed on approach
rather than a low power setting is in my opinion the answer.
My first notice of vibration prompted me to check the magnetic plug and
conduct an investigation since it failed the visual check.
Best regards to all
Bob Harrison G-PTAG Rotax 914
PostPosted: Tue Jul 14, 2015 4:43 am    Post subject: Propeller/engine vibration Reply with quote
Hi Bob
The parts you seem to be describing are not the slipper clutch, although I
and everyone I have spoken to during the period of my vibration problem,
assumed that it was.
These parts are the dog drive system and are present on all the 912UL and
912ULS and 914 engines. They are held in contact by the Bellville washers
and incorporate the 15 or 30 degrees of movement that we have to regularly
check for in the Friction Torque Test.
On engines with a slipper clutch the output part of the dog drive system is
much larger and incorporates a clutch drive system within it, a bit like a
motorcycle clutch. This output dog drive is splined on to the Propeller
Drive Shaft.
When I had my gearbox at the Rotax Service Agent I asked him to show me how
it all worked and with the parts on the bench it all became very clear.
Dave Watts
G-BXDY
PostPosted: Tue Jul 14, 2015 5:44 am    Post subject: Propeller/engine vibration Reply with quote
Hi! David,
You may be right, except the torque loading to which you refer as well as
loading the clutch also contains the lobes of the dogs within their working
range and it is this resultant surface contact pressure which in my opinion
is too high for the PEAKS of the lobes giving a concentrated surface point
load when in the valley much reduced when up the driving slope.
Really antiquated principles .....my 1936 Vellocette OHC has a similar drive
between engine sprocket and gear box drive sprocket, protecting shock of the
cylinder power stroke through the primary drive chain.
For the many, the understanding of what I wrote was more intended as a guide
where to look for surface erosion and a remedy.
Without my dogged refusal to put my hand in my pocket the agent was content
to order a pair set of gears and Rotax would be £1000 in pocket as a result
Bob H G-PTAG.
paul.the.aviator(at)gmail
PostPosted: Tue Jul 14, 2015 7:33 am    Post subject: Propeller/engine vibration Reply with quote
Hi John,
I had something similar happen. Out of the blue I started getting vibrations when I throttled back and it turned out to be the carbs being out of balance.  I don't know why it suddenly turned up but I balanced them and life was good.
Paul
JohnFrance
PostPosted: Sun Jul 19, 2015 2:00 am    Post subject: Re: Propeller/engine vibration Reply with quote
Here is an update on my vibration problem. I checked balance of the carburettors they were perfect, checked all engine mounts, carburettor mounts electrical connections on ignition circuit including ht leads and air box and everything looks fine. I cleaned the propeller (again) very thoroughly and went for a flight. The vibration has disappeared! Just the normal area where it is not so smooth at 4800 rpm. The vibration through the rudder pedals has also disappeared.
I must admit I am confused as I have not identified a cause. Regards John
Europa mono Nr 192
