kearney
Posted: Mon Jul 27, 2015 9:23 am Post subject: Soundproofing |
Hi
Now that I have a few hours on my -10, I am thinking about installing some soundproofing. At KOSH I saw a demo of the Sound-Ex soundproofing at the Plane Patterns booth. IT seemed like a very effective and light product.
Given that I don't have access to the floor wells, I was wondering if anyone can provide guidance on where retrofitted soundproofing has proven the most effective (ie. cabin side firewall / side panels etc, under front seats etc.
Is the Sound-Ex product effective?
Cheers
Les
jdriggs49(at)msn.com Guest
Posted: Mon Jul 27, 2015 9:49 am Post subject: Soundproofing |
I used it in my -10 and it helped a bunch
Now that isn't saying that it's gonna be as quiet as an airliner but it helps
| Quote: | Subject: RV10-List: Soundproofing
Date: Mon, 27 Jul 2015 10:23:29 -0700
To: rv10-list@matronics.com
--> RV10-List message posted by: "kearney" <kearney@shaw.ca>
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=445264#445264
_-============================================================
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RV10-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
rv10flyer(at)live.com Guest
Posted: Mon Jul 27, 2015 9:50 am Post subject: Soundproofing |
Les;
For what its worth.
The best soundproofing I have found is where I can hear it. I bought Zulu 2
headsets and the plane is as quiet as I will ever make it.
With that said. I used heat insulation and a spray on sound insulator that
dissipated the noise significantly but in the end, weight and ease wise, I
determined that the headset investment was the best route.
Pascal
kearney
Posted: Mon Jul 27, 2015 11:38 am Post subject: Soundproofing |
Hi
Since I posted this I started working through the VAF archives etc. I ended up researching Abesco FP200 foam that I read about on the VAF forums.
This would seem to be a good product to install under the floor pans as it is an expanding fire stop foam and does have some noise damping properties as well. The lightening holes would provide installation access. When cured it is a very light foam.
Has anyone on the list used this?
As I understand it, one limitation is that it should not be used in places where temps normally exceed 150-200C on an ongoing basis. Does anyone have any idea as to what the skin temps are near the exhausts?
Lastly, here is an interesting demo of the differences between fire-blocks vs fire-stops. https://www.youtube.com/watch?v=djB4dmfHhQk
Cheers
Les
Bob Turner
Posted: Mon Jul 27, 2015 3:04 pm Post subject: Re: Soundproofing |
I'm with RV10Flyer; the best sound reduction/pound is from a good headset.
Start there, then decide if you need more. (My personal answer was "no".)
However, I did have to do something about the draft in the back; passengers in the back had cold heads and hot feet.
_________________ Bob Turner
RV-10 QB |
kearney
Posted: Mon Jul 27, 2015 3:48 pm Post subject: Soundproofing |
What did you do for the back pax?
Cheers
Les
| Quote: | On Jul 27, 2015, at 17:04, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=445282#445282
Bob Turner
Posted: Mon Jul 27, 2015 4:04 pm Post subject: Re: Soundproofing |
| kearney wrote: | Bob
Cheers
Les
Bob Turner
RV-10 QB
Well, mostly I turned the pilot's intercom volume down so I don't have to hear the complaints!! ha ha. Seriously, I stuffed some insulation into all the corregations in the aft baggage bulkhead. That helped some. As a test, I have taped some cardboard in front of the rear heat outlets, taped on 3 sides but canted at 45 degrees up, to encourage the heat to go up instead of out to their feet. That helped some. So do wool hats. Since the side walls and baggage bulkhead are not insulated, they are going to be cold when in flight, if it's cold outside. I suspect that a small amount of stick-on insulation, on those side walls and baggage bulkhead, would fix the problem more permanently, but I haven't been motivated enough yet to try it. Oddly the front seat occupants don't seem to have the same complaint of hot feet, cold head.
RV-10 QB |
Posted: Mon Jul 27, 2015 4:19 pm Post subject: Soundproofing |
If you mean headsets? same for back Pax
if you mean hot feet and cold heads?, the answer lies on the vent doors on
the firewall-
http://www.planeinnovations.com/product/heater-bypass-valves-hbv-03/
I was blessed to be given the chance to help design them. They have tabs
that totally block any heat from entering and are stainless/stiff so doors
don’t warp when opening and closing. result-no hot tunnel and two young
daughters (one very temperature sensitive) that have been quite happy with
no hot feet (during summer) and warm in winter- I used a PVC 45 degree pipe
on the back holes to force the heat up versus right to feet.
Pascal
Posted: Mon Jul 27, 2015 4:57 pm Post subject: Soundproofing |
Back passengers get cold if the doors aren't well sealed. The air in the cabin is sucked out around the door hinges and is replaced from tailcone air through the corregations in the rear baggage wall. If you have this problem, try sealing around the hinges better.
Regarding noise, door seals hugely reduce the noise level in the cabin. A plane I worked on with inflatable door seals went from the loudest -10 to probably the quietest -10 I have flown when the door seals were finished and inflated.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
| Quote: | On Jul 27, 2015, at 7:43 PM, Les Kearney <kearney(at)shaw.ca> wrote:
Cheers
Les
> Bob Turner
> RV-10 QB
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Mon Jul 27, 2015 5:06 pm Post subject: Soundproofing |
It also helps to seal and insulate the aft bulkhead in the baggage compartment. As Jesse said, lots of air comes forward into the cabin from the tailcone.
grumpy
N184JM
| Quote: | On Jul 27, 2015, at 7:53 PM, Jesse Saint <jesse(at)saintaviation.com> wrote:
Jesse Saint
352-427-0285
> Bob
> Cheers
> Les
> Sent from my iPhone
>> Bob Turner
>> RV-10 QB
Greg McFarlane
Joined: 12 Apr 2012 Posts: 58 Location: Albany Western Australia
Posted: Tue Jul 28, 2015 4:53 am Post subject: Re: Soundproofing |
As Jesse has said, any air leakage around the door seals/hinges will encourage airflow from the baggage V holes into the cabin, however those V holes are actually for airflow OUT of the cabin. Not a good idea to block these holes up to keep rear passengers ears warm as a potential build up of any Carbon Monoxide will probably be the result. Cheers from Western Australia
johngoodman
Posted: Tue Jul 28, 2015 6:25 am Post subject: Re: Soundproofing |
| kearney wrote: | Hi
Cheers
Les |
Les,
I used several cans of Abesco FP200, and love it. I put it under all the floors. The floors feel solid, are cool, and I assume there is sound reduction. The best part is that it's a positive fire barrier. It's a great product.
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Tue Jul 28, 2015 6:34 am Post subject: Soundproofing |
I used Abesco FP200 under both the front and rear floorboards as I riveted them in place.
It has quite a bit of force as it expands, and I'd recommend being careful to either spray the foam under the floorboards before you rivet them down, let it cure, trim the excess, and then install the floorboards, or if the floors are already down, make sure you don't overfill the voids.
A nice side effect is that the floorboards have a very nice solid feel with the foam in there.
On Mon, Jul 27, 2015 at 6:43 PM, Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote]--> RV10-List message posted by: Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Cheers
Les
> On Jul 27, 2015, at 17:04, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
> --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
> Bob Turner
> RV-10 QB
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
