				 Posted: Wed Jul 29, 2015 1:11 pm    Post subject: Signs of corrosion on tail cone |
				I'm beginning to see signs of corrosion between the top skin and the
 side skins of my tailcone.  The corrosion is happening underneath the
 paint.  Inside the tailcone there are a few 'wisps' of grayish corrosion
 coming up from the same joint which is riveted to the angle longerons.
 Anyone else experiencing this?  What are you finding, what have you done?
 Plane is hangared except when traveling and only occassionally sees salt
 air - and I wash it down after each encounter.
		cooprv7(at)yahoo.com Guest
				 Posted: Wed Jul 29, 2015 1:59 pm    Post subject: Signs of corrosion on tail cone |
				I’m not sure if this will help with corrosion already there, but I sprayed the tailbone with Corrosion X and the film is still there after 7 years and 720 hours.  I appreciate you bringing this up though as it wouldn’t hurt to apply again.  One gotcha, do NOT apply this until after you paint your airplane, otherwise it will be a bear to get the paint to adhere properly.
 Marcus
  	  | Quote: | 	 		   On Jul 30, 2015, at 12:05 AM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
  I'm beginning to see signs of corrosion between the top skin and the side skins of my tailcone.  The corrosion is happening underneath the paint.  Inside the tailcone there are a few 'wisps' of grayish corrosion coming up from the same joint which is riveted to the angle longerons.
  Plane is hangared except when traveling and only occassionally sees salt air - and I wash it down after each encounter.
				 Posted: Wed Jul 29, 2015 2:14 pm    Post subject: Signs of corrosion on tail cone |
				Is this a quick build?
 Carl
  	  | Quote: | 	 		   On Jul 29, 2015, at 2:05 PM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
				 Posted: Wed Jul 29, 2015 5:53 pm    Post subject: Signs of corrosion on tail cone |
				Yes, but I build the tailcone.  No relationship between the two I would
 think.
 On 7/29/2015 6:11 PM, Carl Froehlich wrote:
  Carl
  Checked by AVG - www.avg.com
		rv10pro(at)gmail.com Guest
				 Posted: Thu Jul 30, 2015 6:11 am    Post subject: Signs of corrosion on tail cone |
				#1 Surface preparation.  Many on this list talk of Acetone or Alcohol cleaning.  Aluminum begins Aluminum Oxide within an hour of scotchbrighting.  Doing the work in a high humidity environment or an area under the influence of Salt vapor can impact the surface prep in short order.  Correction: do an evaporation test of the solvent used on a piece of clear glass and see if after evaporation, deposits form.  Prime within 15 minutes of scotchbrighting never hours or days.
 #2 Galvanic action by use of the airframe as the ground path from adjacent electrical circuits is another.  Run a separate return path from lighting components forward to a more substantial frame member not in contact with exterior skin if using single wire power runs.
 #3 Use of chemicals which promotes Hydrolysis.  The old Simple Green before they reformulated Aviation grade was notorious.  Wicking action is best reduced by wet sealing the two skins with a roller of thin proseal.  RTV is not a cure all.
 #4 "Faying action" between two close sheet metal items attached together wick most alkaline cleaners into the joints mentioned.  Clear rinse the joints with de-ionized water and pay particular attention to the areas showing signs.  Oxidation once started must be removed.  The cause corrected and the treated skin recoated with an Alodine or similar treatment.  It is remotely possible the primer had some impact on the outcome.
 Least desireable Corrective Action: remove the skin and treat before the corrosion reaches 10% in skin depth.
 Note:  Cessna had a very large batch of aircraft twenty years ago with Filiform corrosion which showed YEARS later.  The research found they were parking the prepped aircraft outside overnight provided Acid Rain vapor to condense on the material.  The skin was dry and "Clean" but the acid residual began working between the skin and final coats - after application.  Only solution, soda blast, properly reprep the surface and reapply a corrective topcoat.
 The type of corrosion found helps determine the cause and corrective action.  Just shooting blind on a sensitive issue.  Good Luck with the solution.
 John C.
 #40600
 On Wed, Jul 29, 2015 at 6:49 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
 [quote]--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
  Yes, but I build the tailcone.  No relationship between the two I would think.
   	  | Quote: | 	 		   --> RV10-List message posted by: Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)>
  Carl
   	  | Quote: | 	 		   On Jul 29, 2015, at 2:05 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
   FORUMS -
  b Site -
            -Matt Dralle, List Admin.
		Kellym
				 Posted: Thu Jul 30, 2015 6:42 am    Post subject: Signs of corrosion on tail cone |
				I will agree with all John wrote except the electrical ground issue.
 Given that type certified aircraft from the end of WWII on have used the
 airframe as a ground path, you would expect to see such problems if it
 were an issue, within say 30-40 years. Hasn't happened. My current
 aircraft is 50 yrs old. Not one bit of corrosion around any of the power
 consuming items that are grounded to the airframe, nor the ground attach
 points. IIRC Bob Nuckolls of AeroElectric connection says only
 electronics need central grounding, NOT lights, pitot heat, and other
 high current devices. Given he was the expert for Cessna, then Beech, I
 tend to listen to his opinions.
 I will not that where Vans uses aluminum angle for longerons, etc. that
 aluminum angle is NOT Alclad, and requires some form of primer or
 anodizing. I don't believe any of the material Vans supplies has any
 primer, except in the quick build components, and I'm not sure they do
 anything between the skins and the longerons. Heck, on mine they didn't
 even bother to countersink the longerons where they attached to dimpled
 skins.
 On 7/30/2015 7:08 AM, John Cox wrote:
  	  | Quote: | 	 		   #1 Surface preparation.  Many on this list talk of Acetone or Alcohol
KCHD |
				 Posted: Thu Jul 30, 2015 7:13 am    Post subject: Signs of corrosion on tail cone |
				Improper surface prep can and does lead to issues.  Did someone state Van's preps parts??  Not the company I know so well.  I will assume Bill did everything "Top Notch".  Washing of aircraft is another issue not discussed on this forum, yet.
 Can give examples of electrolysis doing corrosion damage but was not intending to counter the disciples of Mr. Nuckholls.  SFAR88 has manufacturers rethinking due to FAA mandate the issues of electric current beyond electronics.  On our airliners which get 4400-4500 hours per year, the damage is accelerated.  Just a perspective.  Maybe Acid Rain can be blamed since Mr Nuckoll's was not retired at the time at Cessna when the filliform was such a large issue.
 Not a supporter of Mr. Scott's mantra "Just Build It".    Build it safe, enjoy flight, live LONG.
 jc
 On Thu, Jul 30, 2015 at 7:38 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
 [quote]--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
  I will agree with all John wrote except the electrical ground issue. Given that type certified aircraft from the end of WWII on have used the airframe as a ground path, you would expect to see such problems if it were an issue, within say 30-40 years. Hasn't happened. My current aircraft is 50 yrs old. Not one bit of corrosion around any of the power consuming items that are grounded to the airframe, nor the ground attach points. IIRC Bob Nuckolls of AeroElectric connection says only electronics need central grounding, NOT lights, pitot heat, and other high current devices. Given he was the expert for Cessna, then Beech, I tend to listen to his opinions.
  I will not that where Vans uses aluminum angle for longerons, etc. that aluminum angle is NOT Alclad, and requires some form of primer or anodizing. I don't believe any of the material Vans supplies has any primer, except in the quick build components, and I'm not sure they do anything between the skins and the longerons. Heck, on mine they didn't even bother to countersink the longerons where they attached to dimpled skins.
   	  | Quote: | 	 		   #1 Surface preparation.  Many on this list talk of Acetone or Alcohol cleaning.  Aluminum begins Aluminum Oxide within an hour of scotchbrighting.  Doing the work in a high humidity environment or an area under the influence of Salt vapor can impact the surface prep in short order.  Correction: do an evaporation test of the solvent used on a piece of clear glass and see if after evaporation, deposits form.  Prime within 15 minutes of scotchbrighting never hours or days.
   FORUMS -
  b Site -
		Kellym
				 Posted: Thu Jul 30, 2015 7:30 am    Post subject: Signs of corrosion on tail cone |
				Vans quick build components do get primer, I believe AFTER they are
 assembled.
 Cessna's corrosion had nothing to do with electrics. It had to do with
 your mention of the overnight outside AND they eliminated one of the two
 components of the primer they were using. It was supposed to be done on
 two phases, not a single coat.
 On 7/30/2015 8:09 AM, John Cox wrote:
  	  | Quote: | 	 		   Improper surface prep can and does lead to issues. Did someone state
  jc
  <mailto:kellym(at)aviating.com>> wrote:
      <kellym(at)aviating.com <mailto:kellym(at)aviating.com>>
      FORUMS -
      b Site -
KCHD |
		Bob Turner
				 Posted: Sat Aug 01, 2015 9:01 am    Post subject: Re: Signs of corrosion on tail cone |
				I'd suggest getting a spray can of Corrosion X or ACF-50 and spraying along that joint and the angle. That stuff penetrates everywhere. It will not repair damage done but may stop or slow further damage.
  _________________ Bob Turner
RV-10 QB |
				 Posted: Sat Aug 01, 2015 12:09 pm    Post subject: Signs of corrosion on tail cone |
				Thanks John, a lot of good stuff there!
        Looks like I have some form of filiform  corrosion.  I sure looks       like 'something' leaked out from the seam after painting.
        I primed the tail feathers with epoxy primer, the tailcone with       Dupont wash primer, finished off the QB kit with rattle can       primer, I did not prime the angle longerons (!)
        The paint job included PreKote, epoxy primer and a Dupont       Polyurethane.
        My plan of action looks like 1) mechanically remove paint where       corrosion is evident, 2)remove corrosion, clean, (conversion?), 3)       prime and paint.  Then apply one of the penetrating corrosion       protection products to the inside of the tail cone along the seam.
        On 7/30/2015 10:08 AM, John Cox wrote:
      [quote]       #1 Surface preparation.  Many on this list talk of         Acetone or Alcohol cleaning.  Aluminum begins Aluminum Oxide         within an hour of scotchbrighting.  Doing the work in a high         humidity environment or an area under the influence of Salt         vapor can impact the surface prep in short order.  Correction:         do an evaporation test of the solvent used on a piece of clear         glass and see if after evaporation, deposits form.  Prime within         15 minutes of scotchbrighting never hours or days.
          John C.
          #40600
             	  | Quote: | 	 		  -->             RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
                Carl
              FORUMS -
              b Site -
              rel="noreferrer"             target="_blank">http://www.matronics.com/contribution
 No virus         found in this message.
          Date: 07/30/15     [b]
