cht sensors
Bill Cutshaw
PostPosted: Mon Aug 03, 2015 4:34 pm    Post subject: cht sensors Reply with quote
ANYONE HAVE A SOURCE FOR 914 CHT SENSORS ITS A VDO 150 C
h&jeuropa
PostPosted: Tue Aug 04, 2015 4:55 am    Post subject: Re: cht sensors Reply with quote
Bill,
These do not seem to be available any longer. Perhaps someone will have a spare you can purchase.
If not, there are other VDO sensors with the same internals but different threads. You could purchase one of those that is a larger diameter and machine the threads.
Jim Butcher
erichdtrombley(at)juno.co
PostPosted: Thu Aug 06, 2015 12:10 pm    Post subject: cht sensors Reply with quote
Bill,
Just went through this exercise. I was able to find the Rotax sensor, just not willing to spend $150 + for what should be a $25 part. I ended up purchasing VDO 323-801-010-003K which is threaded for 12mm hole. All other specifications are essentially the same as Rotax part. Using a lathe I turned down the threads and rethreaded for 10mm. Works great.
Erich
Classic Mono 914
Time: 05:56:09 AM PST US
Subject: Re: cht sensors
Bill,
you can purchase.
threads.
Jim Butcher
____________________________________________________________
Old School Yearbook Pics
View Class Yearbooks Online Free. Search by School & Year. Look Now!
classmates.com [quote][b]
nigel_graham(at)m-tecque.
PostPosted: Mon Aug 10, 2015 12:25 am    Post subject: cht sensors Reply with quote
That's an ingenious solution Erich, but VDO offer their sensors in a range of thread sizes (including 10 mm).
I've attached their catalogue for a bit of night-time reading.
A quick search shows that they are also available in Europe for around E25. I never cease to be amused by Rotax's adventurous pricing.
Nigel
On 06/08/2015 21:07, Erich Trombley wrote:
Bill,
Erich
Classic Mono 914
Bill,
you can purchase.
threads.
Jim Butcher
classmates.com
VDO_Data_Sheets_temp_pressure_speed_sensors.pdf
 Filename:  VDO_Data_Sheets_temp_pressure_speed_sensors.pdf
 Filesize:  2.74 MB
 Downloaded:  978 Time(s)
