Alternator B-lead circuit protection
dan(at)syz.com
PostPosted: Fri Aug 07, 2015 12:43 am    Post subject: Alternator B-lead circuit protection Reply with quote
Hi everyone. I have a quick question with regards to protecting alternator B-leads.
A lot of people do so with ANL fuses, yet I know some aircraft (like my C150) do so with a circuit breaker. Of course, a disadvantage of the ANL is that if it blew while on a trip, after fixing whatever caused the problem, a person would have to source a new fuse which could result in the aircraft being grounded waiting for one to be shipped (are ANL fuses that easy to find? I'm in Canada, so my usual sources of parts are Aircraft Spruce, which doesn't seem to carry them, or "chain" stores like Canadian Tire, which doesn't seem to either. Though it does appear that Digikey carries them, so at least there is a source here without having to go through the customs hassles of ordering from somewhere like B&C). The natural advantage of a circuit breaker, of course, is that it can be reset without replacing things once the problem is fixed.
But I don't like much the idea of bringing B-leads into the area behind the panel, or even into the cockpit for that matter, and am unsure as to whether a circuit breaker would cause more problems than it prevents due to nuisance trips. I know it's not "conventionally" done, but is there any problem with locating a B-lead circuit breaker under the cowling in the engine compartment if a person were to go the circuit breaker route? After all, if a B-lead were to have a current spike tripping the fuse or breaker, the cowling would likely have to be pulled anyway to see what's going on.
Or is it better to just go the fuse route? And if so, any advantages of ANL over MIDI style?
Thanks for any advice!
Dan
Dan Charrois
President, Syzygy Research & Technology
Phone: 780-961-2213
email(at)jaredyates.com
PostPosted: Fri Aug 07, 2015 4:33 am    Post subject: Alternator B-lead circuit protection Reply with quote
My tool bag carries them!  They are cheap enough and small enough to bring a spare or two along, as to help mitigate that concern.
[quote]could result in the aircraft being grounded waiting for one to be shipped (are ANL fuses that easy to find?  I'm in Canada, so my usual sources of parts are Aircraft Spruce, which doesn't seem to carry them, or "chain" stores like Canadian Tire, which doesn't seem to either.  [b]
yellowduckduo(at)gmail.co
PostPosted: Fri Aug 07, 2015 5:02 am    Post subject: Alternator B-lead circuit protection Reply with quote
I've used a circuit breaker or maxi fuse with 40 amp alternators when
the battery is in the fuselage.
I would hesitate to use a C/B on the hot side of the FW since they are
likely more sensitive to the surrounding environment than fuses or an ANL.
Many automotive audio system vendors stock ANLs and they can always be
hotwired making them into essentially a fusable link.
Ken
Dan
Dan Charrois
Phone: 780-961-2213
rene(at)felker.com
I used a CB mounted in the engine compartment.
I had a 60 amp alternator and went to a 70 amp alternator. I did not change
the CB (you see what is coming). On a long trip back East (from Utah), I
had the CB trip twice in flight. I did not think I could draw 60
amps......but I can. So when I got back I upgraded to a 70 amp CB.....no
trips since.
I have two batteries on board and on reduced load can go an entire flight
without the alternator.
Rene'
801-721-6080
user9253
PostPosted: Fri Aug 07, 2015 5:23 am    Post subject: Re: Alternator B-lead circuit protection Reply with quote
If the ANL fuse is sized right and the terminals are kept tight, it should never blow unless there is a bigger problem. There is less to go wrong with a fuse compared to a circuit breaker. I would use a fuse located near the contactors.
The protective device does not have to be resetable for once in a lifetime event.
Joe
Joe Gores
tomhanaway
PostPosted: Fri Aug 07, 2015 5:41 am    Post subject: Alternator B-lead circuit protection Reply with quote
I agree that if a properly sized ANL fuse blows, you've probably got bigger problems.
However, I just carry a spare one in my kit
Sent from my iPad
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=445669#445669
RV-10. Built and sold
RV-8a. Building
ARGOLDMAN(at)aol.com
PostPosted: Fri Aug 07, 2015 11:50 am    Post subject: Alternator B-lead circuit protection Reply with quote
Uh- Yep
When discharged the battery will immediately take all of the available alternator current if you have underrated the breaker, it will break.
The breaker, in any circuit should be sized to protect the wire, not the deliverer of electrons nor those things that use them.
Rich
In a message dated 8/7/2015 8:03:45 A.M. Central Daylight Time, rene(at)felker.com writes:
--> AeroElectric-List message posted by: "Rene" <rene(at)felker.com>
trips since.
Rene'
801-721-6080
-----Original Message-----
From: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dan
Charrois
Sent: Friday, August 07, 2015 2:41 AM
Subject: Alternator B-lead circuit protection
--> AeroElectric-List message posted by: Dan Charrois <dan(at)syz.com>
B-leads.
over MIDI style?
Dan
Dan Charrois
Phone: ================================================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
