dan(at)syz.com Guest
Posted: Wed Aug 05, 2015 4:39 pm Post subject: IO-540 mount ears nuts |
Hi everyone. I got a Lycoming IO-540 for my RV-10 through Vans, and when it arrived the mounting ears were in a box, not installed on the engine. From what I've read in this message group, it seems that's typical. However, I haven't been able to find the nuts and washers required to mount them on the engine - they're not in the box the ears were in, nor have I found them anywhere else. Can anyone provide insight on where they found theirs when the engine arrived? Either I've just been unsuccessful at hide and seek, or they really are missing, in which case I'll have to sort out exactly what I need and get them.
Thanks!
Dan
Dan Charrois
President, Syzygy Research & Technology
Phone: 780-961-2213
Posted: Wed Aug 05, 2015 6:01 pm Post subject: IO-540 mount ears nuts |
They should be in the Lycoming crate - someplace. Look in the injector box
and such.
Carl
Posted: Wed Aug 05, 2015 11:47 pm Post subject: IO-540 mount ears nuts |
Bingo - I think you nailed it. I'd thought the hardware in there was for the injector, but it does appear as though nuts and washers matching the description of those I've seen mentioned earlier in this maillist for the mounting ears are in there - that must be them. Thanks!
Dan
[quote] On 2015-Aug-05, at 7:57 PM, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
and such.
Carl
jchang10
