		dlm34077(at)gmail.com Guest
				 Posted: Mon Aug 31, 2015 5:46 am    Post subject: ADS-B |
				I am using the hybrid system at the present time; a TT31 mode S with ADS-B
 out and a Skyradar dual receiver. Skyradar has changed the name (I forget
 it). I still need to get the GRT position source for 2020. GRT and Dynon
 have committed to produce a position source only for about $600. I currently
 use both, the Garmin sensor in my Sport backup or the Crossbow sensor in the
 Chelton AHRS. The reason for getting the dual band receiver is availability
 of traffic directly only on the transponder frequency. In the future users
 transmitting on transponder frequency only will only provide direct traffic
 to your aircraft receiver if you are dual band. Otherwise the UAT
 transmissions must go to an ATC facility to receive the 978Mh UAT who then
 rebroadcasts. Stated differently, aircraft A (1090 equipped) does not talk
 directly to your aircraft with UAT only receive capability. Your aircraft
 will be tracked by ATC and your location will be rebroadcast and you can
 then "see" aircraft A on your display. With my setup, any "out' equipped
 aircraft is immediately "seen" by my equipment directly without waiting for
 a rebroadcast from ATC radar since I "listen" continuously for both 978 and
 1090. Hence an "out" equipped aircraft departing a remote airport will be
 "seen" by my equipment even if it is below radar coverage.
		Kellym
				 Posted: Mon Aug 31, 2015 6:28 am    Post subject: ADS-B |
				Dynon announced at Osh a GPS receiver module that meets all the TSO
 requirements without the actual approval. Direct plug-in for both AFS
 and Dynon Skyview equipment, around $590. Eliminates need for certified
 panel mount GPS if your mission doesn't include IFR GPS flights.
 On 8/31/2015 6:42 AM, DLM wrote:
KCHD |
