Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Mon Sep 07, 2015 8:46 am Post subject: Arblast PV 50 Prop. CS Motor, |
Hi All.
My PV50 CS motor failed in the climb out, just maintained 80 kts, high nose attitude but made it home.
After landing found power reaching the motor, 11.9 volts, so its the motor that's failed.
Q1. Where do I get a new PV 50 CS electric motor from.
Q2. Which bit is the motor, or how do you take the motor out,
Long shaft with motor on the end of it, this piece of shaft with motor on it is secured with three small bolts to the prop, is this the complete unit to be replaced,
OR is it the little black motor on the end of the shaft only needs replacing. ie unsolder the two wire, and with a pair of grips turn and unscrew the motor off the end of the Shaft.
The motor is Swiss Made, and possibly a supplier in Germany may have them,
So a Swiss or German Europa pilot may be able to help and post name.
Alan
nigel_graham(at)m-tecque. Guest
Posted: Tue Sep 08, 2015 8:57 am Post subject: Arblast PV 50 Prop. CS Motor, |
Alan,
I think you will have difficulty sourcing a new replacement from the
factory as I understand that Arplast have ceased trading.
I do however have a spare "pre-owned" PV50 front end comprising good
motor, screwgear and pitch limit switch block. It's a pretty straight
forward job to swap it out but your work will need inspecting and
approving before your aircraft can be returned to service.
If you are interested, contact me off-list.
Nigel
Quoting Alan Carter <alancarteresq(at)onetel.net>:
Hi All.
Alan
http://forums.matronics.com/viewtopic.php?p=446864#446864
Alan Carter
Posted: Tue Sep 08, 2015 11:48 am Post subject: Re: Arblast PV 50 Prop. CS Motor, |
Hi, Nigel.
I will be in touch, when I get you number from the Europa Club.
Alan
kpeng
Posted: Tue Sep 08, 2015 1:55 pm Post subject: Arblast PV 50 Prop. CS Motor, |
Hi Guys,
Is anybody aware of anybody interested in supporting Arplast vp 50 owners in the UK ? There must be a fair few in service here.
Kevin
| Quote: | On 8 Sep 2015, at 17:56, nigel_graham(at)m-tecque.co.uk wrote:
Alan,
I think you will have difficulty sourcing a new replacement from the factory as I understand that Arplast have ceased trading.
I do however have a spare "pre-owned" PV50 front end comprising good motor, screwgear and pitch limit switch block. It's a pretty straight forward job to swap it out but your work will need inspecting and approving before your aircraft can be returned to service.
Nigel
> Hi All.
> Alan
kennethatkinson178(at)bti Guest
Posted: Mon Sep 14, 2015 2:12 pm Post subject: Arblast PV 50 Prop. CS Motor, |
Hi Guys,
Can anyone confirm the trading state of Arplast.
If they really are no longer trading and no one else takes over then all us Arplast propeller users are on our own!
I believe we can
----Original message----
To : europa-list(at)matronics.com
Subject : Re: Arblast PV 50 Prop. CS Motor,
Hi Guys,
Kevin
Alan,
Nigel
> Hi All.
> Alan
Posted: Mon Sep 14, 2015 2:38 pm Post subject: Arblast PV 50 Prop. CS Motor, |
Hi Guys,
Can anyone confirm the trading status of Arplast?
If they are not now trading then all of us that use the PV50 are without support.
We can service the hub easily enough as the bearings are standard and available.
The drive motor should be obtainable. If anyone has found a source I would like to obtain a spare or two?
The main problem could be blade replacement or refurbishment unless some new firm takes over from Arplast.
What thoughts do other PV50 users have?
Perhaps we can pool our knowledge and write up a decent user manual?
Cheers Ken G-CEKV
Hi Guys,
Kevin
Alan,
Nigel
> Hi All.
> Alan
kpeng
Posted: Sat Sep 19, 2015 10:49 am Post subject: Arblast PV 50 Prop. CS Motor, |
Hi Ken,
I have details of the motor / gear head / bearing / brass thread. I'm in the process of getting the bearing and thread mount turned part made tomorrow. I have had mine for 14 years and it's proved to be a good piece of kit. I haven't looked into blades yet as I have a spare set.
Kevin G-Kev
| Quote: | On 14 Sep 2015, at 23:36, KENNETH ATKINSON <kennethatkinson178(at)btinternet.com> wrote:
Hi Guys,
Cheers Ken G-CEKV
> From : kpeng1(at)hotmail.co.uk
Date : 08/09/2015 - 22:52 (GMTDT)
Hi Guys,
Kevin
> Alan,
> Nigel
>> Hi All.
>> Alan
Posted: Sun Sep 20, 2015 11:31 am Post subject: Arblast PV 50 Prop. CS Motor, |
Hi Kevin,
I would appreciate
Hi Ken,
Kevin G-Kev
Hi Guys,
Cheers Ken G-CEKV
Hi Guys,
Kevin
> Alan,
> Nigel
>> Hi All.
>> Alan
Posted: Sun Sep 20, 2015 11:44 am Post subject: Arblast PV 50 Prop. CS Motor, |
Hi Kevin,
I would appreciate the details of the PV50 motor.Do you know where to obtain a replacement?
I also have some spare blades but they are not matched to my hub, therefore ,if I needed to use them I would need to carry out some serious balancing.
If you succeed in manufacturing the drive screw and nut you may find that there are some potential customers out here!
Cheers Ken.
Hi Ken,
Kevin G-Kev
Hi Guys,
Cheers Ken G-CEKV
Hi Guys,
Kevin
> Alan,
> Nigel
>> Hi All.
>> Alan
