				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| ward.t(at)xtra.co.nz Guest
				|  Posted: Tue Sep 08, 2015 1:43 pm    Post subject: Vacuum Pump Blank |   |
				| Hi all,
I am changing from Analog to EFIS for my flight instruments and will have to remove my vacuum pump from the Rotax 912s engine. Has anyone got a blank that covers the connection of the pump to the engine?
 Tim Ward
 12 Waiwetu Street
 Fendalton,
 Christchurch,  8052
 New Zealand.
 Ph 64 3 3515166
 Mob 0210640221
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| Rick Moss
				|  Posted: Sat Sep 12, 2015 2:51 am    Post subject: Re: Vacuum Pump Blank |   |
				| I believe that you can simply remove the vac pump; you will still have a rotatiing shaft sticking out of the rear of the gearbox, but that should pose no issue?
		| Back to top |  |
				|  Posted: Sat Sep 12, 2015 4:48 am    Post subject: Vacuum Pump Blank |   |
				| Thanks Rick.
Must look at the manuals.
 Tim Ward
 12 Waiwetu Street
 Fendalton,
 Christchurch,  8052
 New Zealand.
 Ph 64 3 3515166
 Mob 0210640221
  	  | Quote: |  	  | On 12/09/2015, at 10:51 pm, Rick Moss <Rkwmoss(at)gmail.com> wrote:
 http://forums.matronics.com/viewtopic.php?p=447018#447018
		| Back to top |  |
				|  Posted: Sat Sep 12, 2015 4:49 am    Post subject: Vacuum Pump Blank |   |
				| Thanks Rick.
Haven't looked at the removal yet nor the manuals so that would be excellent.
 Tim Ward
 12 Waiwetu Street
 Fendalton,
 Christchurch,  8052
 New Zealand.
 Ph 64 3 3515166
 Mob 0210640221
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Sat Sep 12, 2015 5:30 am    Post subject: Vacuum Pump Blank |   |
				| Tim, I just made a flat cover out of aluminum when I removed mine. - Paul
		| Back to top |  |
		| europapa
				|  Posted: Sat Sep 12, 2015 9:19 am    Post subject: Re: Vacuum Pump Blank |   |
				| years ago I removed the vacuum pump too and made a cover out of 4mm PTFE.
Simple.
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
