				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| graeme.hart(at)onecoolkat Guest
				|  Posted: Sat Sep 12, 2015 3:05 pm    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| Hi All
 I am the proud new owner of Europa XS Tri-gear kit A-101.
 Today I was going through the kit and I found some unopened cans of this miracle glue.
 The cans were manufactured in 2005 and are labelled with an expiry date 6 months later in early 2006.
 In the perfect world I would just buy new adhesive but as this glue is hard to obtain (at a reasonable price) I'm considering using the glue I have.
 The cans show no sign of corrosion and are unopened.
 Does anyone know what the realistic shelf life of this product is?  Alternatively if anyone knows of a source in New Zealand or Australia so I can minimise dangerous goods shipping charges that would be very helpful (I'm already in an email conversation with Huntsman in Australia). Â
 Graeme
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| Fred Klein
				|  Posted: Sat Sep 12, 2015 3:37 pm    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| From past discussion on this forum, I’d ignore the expiry date...I’d suggest opening the containers and determining whether or not crystals have formed…if they have, warm the Redux container in a pot of water on the stove, stirring until crystals have dissolved, then proceed w/ a test strip or two to determine current bond strength.
…just my thoughts on what I’d do…
 Fred
  	  | Quote: |  	  | On Sep 12, 2015, at 4:04 PM, Graeme Hart <graeme.hart(at)onecoolkat.com (graeme.hart(at)onecoolkat.com)> wrote: Hi All
 Graeme
  	  | Quote: |  	  |
 class="">http://www.matronics.com/Navigator?Europa-List
 class="">http://forums.matronics.com
 class="">http://www.matronics.com/contribution
		| Back to top |  |
		| spcialeffects
				|  Posted: Sat Sep 12, 2015 4:44 pm    Post subject: Re: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| Just keep in mind " When your at the start of the runway, about to power up, do you want that little niggle in the back of your mind saying should I have..........."
 Just one of the things I keep in mind every time I go into my workshop. Just my thoughts
		| Back to top |  |
				|  Posted: Sat Sep 12, 2015 8:31 pm    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| Thanks Fred, I appreciate the suggestions.  Do you have any suggestions about how to test the bond strength?
 Thanks spcialeffects for your input too, while the use of old glue is definitely a concern for me at least I am able to test and verify performance.  The bigger concern for me is that I'm building from a kit that has had at least three previous owners.  I will check their work as far as I can but there are some areas of the aircraft where I am unable to see what they have done.
 Ultimately any aircraft is a collection of trade offs and compromises and this is just one of many.  Hopefully Huntsman will come through on Monday with a reasonable price for 1.4kg of Araldite 420 and I can just buy it from them.
 On Sun, Sep 13, 2015 at 11:36 AM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
 [quote]From past discussion on this forum, I’d ignore the expiry date...I’d suggest opening the containers and determining whether or not crystals have formed…if they have, warm the Redux container in a pot of water on the stove, stirring until crystals have dissolved, then proceed w/ a test strip or two to determine current bond strength.
 Fred
 Hi All
 Graeme
  	  | Quote: |  	  |
 arget="_blank">http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| Fred Klein
				|  Posted: Sat Sep 12, 2015 9:24 pm    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				|  	  | Quote: |  	  | On Sep 12, 2015, at 9:30 PM, Graeme Hart <graeme.hart(at)onecoolkat.com (graeme.hart(at)onecoolkat.com)> wrote: Do you have any suggestions about how to test the bond strength?
 Graeme…I’ll stick my neck out and suggest the following:
 I always kept all cut-outs and scraps of materials from trimming of moulded parts, etc. Find a couple of scraps of (say) 3 ply BID and bond them together w/ the Redux…using a suitable set up of leverage and grip, attempt to pull them apart…if the fiberglas fails before the Redux bond, I’d feel good to go.
 But I would certainly invite anyone with real knowledge and experience in this area to step up and either take issue with or confirm my suggestion.
 Fred
		| Back to top |  |
				|  Posted: Sat Sep 12, 2015 10:04 pm    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| On Sun, Sep 13, 2015 at 5:23 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
  	  | Quote: |  	  |
 That was pretty much what I was thinking Fred.  I don't have any cut-outs or scraps that I can use but I've got a lot of spare glass cloth and I can easily make some test samples.  I'll do this once I've done a complete inventory of the work to date and after ordering the mod kits and possibly other parts I need from Europa.Â
		| Back to top |  |
		| bill.sue(at)orcon.net.nz Guest
				|  Posted: Sat Sep 12, 2015 11:56 pm    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| Hi Graeme,
 Seeing your ref to Australia and New Zealand I was just wondering where you are based.
 Cheers
 Bill Sisley
 Mono 914/Airmaster
 ZKCHV
 [quote] On 13/09/2015, at 4:30 pm, Graeme Hart <graeme.hart(at)onecoolkat.com> wrote:
		| Back to top |  |
				|  Posted: Sun Sep 13, 2015 12:39 am    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| Hi Bill
 I am based in Wellington.  I bought the kit from a guy in Auckland who imported it from USA about 10 years ago.
 Graeme
 On Sun, Sep 13, 2015 at 7:55 PM, Bill Sisley <bill.sue(at)orcon.net.nz (bill.sue(at)orcon.net.nz)> wrote:
 [quote]Hi Graeme,
 Cheers
 Bill Sisley
 Mono 914/Airmaster
 ZKCHV
		| Back to top |  |
		| pestar
		| Back to top |  |
				|  Posted: Sun Sep 13, 2015 2:17 pm    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| Thanks Peter, I am already a member of SAANZ and the Wellington chapter of SAANZ.
I also attended the intro to home building course held recently.
 Unfortunately there are no Europa builders I have been able to find near Wellington but there are a few that have built other composite aircraft.
 >> --> Europa-List message posted by: "pestar" <peter(at)reivernet.com (peter(at)reivernet.com)>
 >> Now if not already be a good boy and join the Sport Aircraft Association of NZ (SAANZ) where they are great guys ready to help including Bill Sisley Europa owner and President of the SAA.  For other folk the SAA is the equivalent of the LAA, EAA.
 >> Cheers Peter
 >> Peter Armstrong
 >> Auckland, New Zealand
 >> DynAero MCR-4S (Do not shoot me
 >> http://forums.matronics.com/viewtopic.php?p=447044#447044
 rum -
 ator?Europa-List">http://www.matronics.com/Navigator?Europa-List
 ONICS WEB FORUMS -
 bution Web Site -
 ibution">http://www.matronics.com/contribution
		| Back to top |  |
		| ptag.dev(at)talktalk.net Guest
				|  Posted: Mon Sep 14, 2015 3:18 am    Post subject: Araldite 420A/B (Redux) Realistic Shelf Life |   |
				| Hi! Frank,
On a lighter note one of the more re-assuring things is to consider this
 item as "bonding material" rather than "GLUE" !
 Regards to all
 Bob Harrison G-PTAG
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
