Low resistance measurement
rnjcurtis(at)charter.net
PostPosted: Wed Sep 16, 2015 9:44 am    Post subject: Low resistance measurement Reply with quote
Bob,
I am interested in constructing a low resistance measurement adaptor. I have a LM337. Can I use this device, in place of the LM317, with a small modification to your schematic?
Roger
PostPosted: Wed Sep 16, 2015 10:31 am    Post subject: Low resistance measurement Reply with quote
At 12:38 PM 9/16/2015, you wrote:
Bob,
Roger
Sure, any of the 3-terminal, adjustable regulators
can be adapted to this service. Here's the schematic
for the AEC9008-3 adapter
[img]cid:7.1.0.9.0.20150916132723.0609fe38(at)aeroelectric.com.0[/img]
If you choose to include the 1.0 Amp excitation
option, be aware that the regulator chip warms
up rapidly. Make QUICK measurements or include
appropriate heat sink. 0.1A measurements
require no heat-sink.
 Filesize:  65.67 KB
 Viewed:  2266 Time(s)
PostPosted: Wed Sep 16, 2015 11:27 am    Post subject: Low resistance measurement Reply with quote
At 01:54 PM 9/16/2015, you wrote:
The LM337 being a negative regulator, can this circuit be used by reversing the battery polarity, or there other issues?
Roger
Ooops . . . missed that. Yes, you can turn the battery
around and it will work fine . . .
Bob . . . [quote][b]
