Tim Olson
Posted: Mon Sep 21, 2015 12:28 pm Post subject: PCU5000X Governor vs Hartzell |
Hi all, sorry to cross-post to 2 forums. Generally I don't do
that, but the RV-14 forum doesn't get any posts so at least
this one will go there.
As with all the other kits for the RV-14, Van's is taking
what in builders lifetimes is "forever" getting their FWF kit
out. I need to get some things fitted up, now that I have
my engine hung, such as the prop control cable.
So I want to buy my prop governor, and start working on that.
For the IO-390, it uses a .895:1 ratio governor, and on one
of the Van's planes they used the Hartzell S-1-79. The lever
comes clocked to 180 degrees. From a bit of googling, it
sounds like *perhaps* the Hartzell's are an older design, but
I hear conflicting things like the S-1 series were developed
for Van's, and have more oil flow.
Then, there is the PCU5000X P-520-029/A-947, that is the proper
gear ratio and model for the IO-390 that I've installed.
They claim to be newer designed, with high oil flows too.
Seeing as though Van's is so ultra-slow in getting the FWF kit
together, they don't have stock of the governors for the IO-390
at all. I'd like to get one ordered, and can get a PCU5000X
for about the same price as the Hartzell's that Van's sells.
I know some people love the PCU5000X. I know many who
have a Hartzell. Does anyone have any info on either that
would push me in one direction or the other?
I love pictures, if you have any, too.
RV-10 N104CD (2006 to present)
RV-14 (FWF/Finishing)
dmaib@me.com
Posted: Mon Sep 21, 2015 1:32 pm Post subject: PCU5000X Governor vs Hartzell |
I got my PCU 5000X through a group buy at VAF, too. 7 years and a bit over 700 hours it has been flawless. I would not hesitate to install one.
David Maib
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Bob Turner
Posted: Mon Sep 21, 2015 2:45 pm Post subject: Re: PCU5000X Governor vs Hartzell |
I think that, generally speaking, governors are important in the sense that a failure is bad. Consequently, they tend to be built as bullet proof as possible, so it would be rare that one was "really better" than another, unless there is a fit problem with baffling, etc.
I put the Hartzell governor (sorry, I don't have the model number handy) on my IO-540/RV-10, and it has been flawless, just as I would hope. It is very easy to move the clocking of the arm around, if that is what you were asking.
_________________ Bob Turner
RV-10 QB |
rleffler
Posted: Mon Sep 21, 2015 3:24 pm Post subject: PCU5000X Governor vs Hartzell |
I have a Hartzell S-1-32 on my RV-10. I've not had any issues with the governor. I did have to get a slightly longer arm to work with the per the plans hole on the baffle ramp.
bob
_________________ Bob Leffler
N410BL - Phase I
Bob Turner
Posted: Mon Sep 21, 2015 3:53 pm Post subject: Re: PCU5000X Governor vs Hartzell |
| rleffler wrote: | I have a Hartzell S-1-32 on my RV-10. I've not had any issues with the governor. I did have to get a slightly longer arm to work with the per the plans hole on the baffle ramp.
bob
Strangely enough I did not need to change the arm. Maybe Vans switched to a longer arm? Or push-pull vs quadrant (I have push-pull)? I don't know.
RV-10 QB |
