		genie(at)swissmail.org Guest
				 Posted: Mon Sep 28, 2015 8:10 am    Post subject: Inverted Fuel and Christen Lubrication System for RV-6 Lycom |
				As I possess a Van's RV-6 with a Lycoming O-320 which has never     flown aerobatics and whose fuel and lubrication systems are not     adapted to this purpose I would be grateful if you could enlighten     me on the following:
             -          What modifications are necessary for the carburettor for         aerobatics, whether it can be modified or needs replacement
 -          How can a Christen oil system be installed for lubrication for         aerobatics
 -          Which companies in Europe can do such modifications or upgrading
 -          Approximately how much would such modifications/upgrading cost         (just in case you have any idea, as I can ask any qualified         companies myself).
       This is sent both in the RV-6 and Lycoming lists.
      Thanks.
      Kind regards,
      George Nielsen
      RV-6 PH-XGN
      The Hague, the Netherlands      [quote][b]
  |  | - The Matronics RV6-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV6-List |
		stein(at)steinair.com Guest
				 Posted: Mon Sep 28, 2015 8:28 am    Post subject: Inverted Fuel and Christen Lubrication System for RV-6 Lycom |
				Hi George,
 Having done this on RV6’s several time ourselves, I can tell you it’s not too bad. Here are the details:
 <![if !supportLists]>1)      <![endif]>Carb – you can’t use a standard “carb” unless you get a “pressure carb”. Preferred method is just to use fuel injection.  Remember wither you use a pressure carb or FI, you’ll need a flop tube in one of the fuel tanks. Vans used to have a kit for that.
 <![if !supportLists]>2)      <![endif]>The Christen/Raven/Clone type systems are easily installed.  You need to put a pickup in the sump, put a pickup on the vent (accessory case), then mount the ball valve and breather can as well as route the hoses.
 <![if !supportLists]>3)      <![endif]>I have no idea who in Europe would do that, but I’d contact someone in the Aerobatic community (or IAC clubs).  They would know.
 <![if !supportLists]>4)      <![endif]>No clue on cost…
 Cheers,
 Stein
 From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of George Nielsen
 Sent: Monday, September 28, 2015 11:09 AM
 To: rv6-list(at)matronics.com
 Subject: Inverted Fuel and Christen Lubrication System for RV-6 Lycoming O-320
 As I possess a Van's RV-6 with a Lycoming O-320 which has never flown aerobatics and whose fuel and lubrication systems are not adapted to this purpose I would be grateful if you could enlighten me on the following:- What modifications are necessary for the carburettor for aerobatics, whether it can be modified or needs replacement
 Thanks.
 Kind regards,
 George Nielsen
 RV-6 PH-XGN
 The Hague, the Netherlands http://forums.matronics.com[/url]         - List Contribution Web generous nbsp;                        --> http://www.matronics.com/c=[/b] [/quote]
