cpayne(at)joimail.com Guest
Posted: Wed Sep 30, 2015 2:35 am Post subject: Spinner Nut |
Yes, agonizing at first to start the nut. Takes practice. I use a couple of wooden paint sticks taped together for length, since you will need some offset anyway. Then a bit of double sided tape on the end that will hold the nut in place while you start by pulling the thin-guage safety wire. Once a turn is started the long handled screwdriver can get a 1/2 turn on.
Then is time for the homemade aluminum wrench to get it snug. Do not tighten with the steel wrench until all nuts are started and snug because the backplate halves may need to be moved around slightly to line up.
Hence the easy chair and nearby refrigerator.
Craig Payne
ronpenrose
Joined: 16 Jul 2014 Posts: 15 Location: Kansas City Metro (KLXT)
Posted: Fri Oct 23, 2015 11:28 am Post subject: Re: Spinner Nut |
I figured I would post this so anyone else looking will see similar but slightly different solution. I found the very thin (1/32) aluminum worked very well for me.
180.08 KB |
3130 Time(s) |
_________________ Ron Penrose
YAK-52 N352BW |
