dlm34077
Bob Turner
Posted: Wed Sep 30, 2015 1:00 pm Post subject: Re: oxygen bottle |
One suggestion: I highly recommend the "conserving" cannulas, because they make the bottle last much longer. Unless you never make long, high trips where running out of O2 before you get home to your inexpensive refill source might be an issue.
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Wed Sep 30, 2015 2:18 pm Post subject: oxygen bottle |
While not as cheap as a medical E bottle, a size M is around 12" shorter, 1" bigger diameter and holds exactly the same 22 cu. ft. It will need less of the tunnel space and should be about right height for an armrest.
On Wed, Sep 30, 2015 at 2:00 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=447568#447568
FORUMS -
b Site -
-Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
