philperry9
Posted: Thu Oct 08, 2015 10:18 am Post subject: Fuel Sender - Installation/Sealing |
(I think) I'm getting ready to start the engine and one of my last remaining tasks is to flush the tanks and install the fuel senders.
What have most of you used to seal the senders when you installed them, and how well has it worked? I'd prefer not to pro-deal them in and I'm wondering is something like Permatex #2 form-a-gasket might be a good choice.
Just wondering how well it has performed and especially how well it has performed in cold weather when sealants like that tend to shrink a bit allowing the opportunity for leaks to occur in cold weather and disappear in warmer weather.
Phil
Posted: Thu Oct 08, 2015 10:31 am Post subject: Fuel Sender - Installation/Sealing |
Fuel-Lube in my 6A.
Sealed great and wasn't a mess when the sender failed.....
rene(at)felker.com Guest
Posted: Thu Oct 08, 2015 10:34 am Post subject: Fuel Sender - Installation/Sealing |
Sorry.....pro-seal. No problems, but I know that is not what you want to
hear.
Rene'
801-721-6080
Posted: Thu Oct 08, 2015 11:03 am Post subject: Fuel Sender - Installation/Sealing |
We usually just use the rubber gasket that comes with the sender.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
| Quote: | On Oct 8, 2015, at 1:14 PM, Phillip Perry <philperry9(at)gmail.com> wrote:
Phil
Kelly McMullen
Posted: Thu Oct 08, 2015 11:11 am Post subject: Fuel Sender - Installation/Sealing |
Gross over kill I don't know if they are readily available, but rubber gaskets work well. That is what the senders in my Mooney tanks use. Everything else is pro-sealed but not the sending unit.
On Thu, Oct 8, 2015 at 11:28 AM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
[quote]--> RV10-List message posted by: "Rene" <rene(at)felker.com (rene(at)felker.com)>
hear.
Rene'
[url=tel:801-721-6080]801-721-6080[/url]
A&P/IA, EAA Tech Counselor
KCHD |
dmaib@me.com
Posted: Thu Oct 08, 2015 3:23 pm Post subject: Re: Fuel Sender - Installation/Sealing |
I installed mine with the rubber gasket that comes with the sender. Put a little fuel lube on the gasket and the screws, but am not sure that is even necessary. 7 years and 800 hours with no leaks. During this time, I have removed each side once to replace the sender and the right side another time chasing a grounding problem. Very easy job.
I believe the secret is to go easy when tightening the screws. Don't over tighten them, and tighten them evenly. The senders are made to be installed with the rubber gasket.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
johngoodman
Posted: Fri Oct 09, 2015 5:28 am Post subject: Re: Fuel Sender - Installation/Sealing |
I used the rubber seal with some fuel lube - no problems after four years.
philperry9
Posted: Sat Oct 10, 2015 9:11 pm Post subject: Fuel Sender - Installation/Sealing |
Thanks for all the info. I'll just slather the rubber gaskets up with EZ Turn and give them shot.
Thanks again,
Phil
On Thu, Oct 8, 2015 at 6:23 PM, dmaib(at)me.com (dmaib(at)me.com) <dmaib(at)me.com (dmaib(at)me.com)> wrote:
[quote]--> RV10-List message posted by: "dmaib(at)me.com (dmaib(at)me.com)" <dmaib(at)me.com (dmaib(at)me.com)>
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=447764#447764
jchang10
Posted: Mon Oct 12, 2015 8:27 am Post subject: Fuel Sender - Installation/Sealing |
You have to be careful with EZ Turn and not use too much. otherwise, you
will find EZ Turn blobs potentially clogging your fuel lines and filters.
On 10/10/2015 9:48 PM, Phillip Perry wrote:
| Quote: | Thanks for all the info. I'll just slather the rubber gaskets up with
Thanks again,
Phil
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Lenny Iszak
Posted: Mon Oct 12, 2015 9:13 am Post subject: Re: Fuel Sender - Installation/Sealing |
I used a viton gasket and screws with built-in viton orings. McMaster has them. I can get you part numbers if you want to go with that setup.
A friend of mine uses these senders on boats he builds and he says the original rubber gaskets are junk.
Lenny
glastar(at)gmx.net Guest
Posted: Mon Oct 12, 2015 10:47 am Post subject: Fuel Sender - Installation/Sealing |
Lenny I would love to see the part numbers thanks. Just keep in mind
Avgas is not as bad to rubber then Mogas will....
Cheers Werner
On 12.10.2015 19:13, Lenny Iszak wrote:
rv10flyer
Posted: Mon Oct 12, 2015 7:00 pm Post subject: Re: Fuel Sender - Installation/Sealing |
I used proseal, just like we used in the military.
_________________ Wayne G. |
Lenny Iszak
Posted: Tue Oct 13, 2015 7:57 pm Post subject: Re: Fuel Sender - Installation/Sealing |
Here are the part numbers:
screws: Mcmaster 90825A387
gaskets: Mcmaster 9473K633
or Amazon: http://www.amazon.com/gp/product/B0075EBPKS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Lenny
| glastar(at)gmx.net wrote: | Lenny I would love to see the part numbers thanks. Just keep in mind
Cheers Werner
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
