Kelvin Weston
Joined: 14 Apr 2010 Posts: 90 Location: Hampshire, UK
Posted: Fri Oct 30, 2015 9:53 am Post subject: Tri Gear Main Wheels |
Hi All
Just fitted the Tri Gear main wheels to the main gear legs for the first time.
However, the slotted main axle nut spins on so far that it is completely clear of the pre-drilled split pin hole. Picture attached.
Anyone else have this problem?
I assume the answer is to drill a new hole for the split pin but how easy will that be in the hardened steel axle.
I have a pillar drill and some cobalt drills but have experienced problems with hardened steel before.
Any advice on a solution?
48.7 KB |
5856 Time(s) |
_________________ Regards
Kelv Weston
Kit 497
kelv@kdweston.co.uk |
Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Fri Oct 30, 2015 10:15 am Post subject: Tri Gear Main Wheels |
How about just adding another washer behind the nut
| Quote: | On 30 Oct 2015, at 17:53, Kelvin Weston <kelv(at)kdweston.biz> wrote:
Hi All
Kelv Weston
Kit 497
http://forums.matronics.com/viewtopic.php?p=448386#448386
http://forums.matronics.com//files/axle_117.jpg
_________________ Richard Wheelwright
G-IRPW
First Flight 24th July 2013 |
hagargs(at)earthlink.net Guest
Posted: Fri Oct 30, 2015 11:07 am Post subject: Tri Gear Main Wheels |
Make a spacer dude!
rlborger(at)mac.com Guest
Posted: Fri Oct 30, 2015 12:34 pm Post subject: Tri Gear Main Wheels |
Keiv,
Go to ACS or one of the wheel/brake manufacturers (MATCO, etc.) and obtain suitable spacers.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
| Quote: | On Oct 30, 2015, at 6:53 PM, Kelvin Weston <kelv(at)kdweston.biz (kelv(at)kdweston.biz)> wrote:
--> Europa-List message posted by: "Kelvin Weston" <kelv(at)kdweston.biz (kelv(at)kdweston.biz)>Hi AllJust fitted the Tri Gear main wheels to the main gear legs for the first time.However, the slotted main axle nut spins on so far that it is completely clear of the pre-drilled split pin hole. Picture attached.Anyone else have this problem?I assume the answer is to drill a new hole for the split pin but how easy will that be in the hardened steel axle.I have a pillar drill and some cobalt drills but have experienced problems with hardened steel before.Any advice on a solution?--------RegardsKelv WestonKit 497kelv(at)kdweston.biz (kelv(at)kdweston.biz)
Kelvin Weston
Posted: Fri Oct 30, 2015 12:54 pm Post subject: Re: Tri Gear Main Wheels |
Hi Richard
I did consider packing it out with washers but the newer nut design, with the integral flange, does not specify the use of any washers.
I believe the integral flange of the nut is being used to stop the bearing grease seal rotating and I was a little concerned that this might not be achieved with a stack of washers.
The MATCO procedure is to tighten the axle nut until the grease seal does not rotate, although Europa specify a torque value of 150 in lbs for the nut in the build manual.
I will try a stack of washers or a spacer and see what happens.
If I can achieve the stationary grease seal then it is certainly easier than drilling the axle.
Thanks for the reply.
Kelv Weston
Kit 497
AirEupora
Posted: Sat Oct 31, 2015 5:36 am Post subject: Re: Tri Gear Main Wheels |
If you do have to drill get a large number of cobalt drills and start with the small number 40 or smaller. Then drill it out to sized. It took me two or three hours with a hand drill.
Rick Stockton
N120EJ
